Stuck on Electric Potential and Capacitors Problems?
The discussion revolves around problems related to electric potential and capacitors, specifically focusing on calculating power ratings, charge magnitudes, and potential differences in various scenarios involving electric circuits and fields.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the equations relevant to power, current, and electric potential. There are attempts to apply formulas for calculating power from charge and voltage, as well as for determining charge from potential differences. Some participants express uncertainty about their calculations and seek clarification on specific terms and concepts.
Some participants have made progress on certain problems, while others are still grappling with specific equations and concepts. There is ongoing clarification regarding the definitions of current and the variables involved in the equations. Guidance has been offered, but no consensus has been reached on the solutions to the problems.
Participants are working within the constraints of homework assignments, which may limit the information they can share or the methods they can use. There are indications of confusion regarding the application of formulas and the interpretation of variables.
moonlit
I have a few problems I'm stuck on, I'm not sure what equations to use...please help
1) An electric car accelerates for 6.4 s by drawing energy from its 300-V battery pack. During this time, 1800 C of charge pass through the battery pack. Find the minimum power rating of the car.
2) Location A is 2.70 m to the right of a point charge q. Location B lies on the same line and is 5.10 m to the right of the charge. The potential difference VB - VA = 40 V. What is the magnitude and sign of the charge?
3) The electric potential energy stored in the capacitor of a defibrillator is 97 J, and the capacitance is 160 uF. What is the potential difference across the capacitor plates?
1) The power rating, P, is:
[tex]P = IV[/tex]
The current, I, is:
[tex]I = \frac{dq}{dt}[/tex]
Therefore:
[tex]P = \frac{dq}{Vdt}[/tex]
2) The potential created by the charge q at a distance x from it is:
[tex]V = k\frac{q}{x}[/tex]
You can find this formula in your textbook. So the potential difference between two points that are distanced x1 and x2 from the point charge is:
[tex]\Delta V = k(\frac{q}{x_1} - \frac{q}{x_2})[/tex]
Rearrange and solve for q:
[tex]q = \frac{\Delta V}{k}\frac{1}{\frac{1}{x_1} - \frac{1}{x_1}}[/tex]
3) The electric potential energy of a charged capacitor is:
[tex]E = \frac{1}{2}cV^2[/tex]
Where V is the potential difference across the plates. So:
[tex]V = \sqrt{\frac{2E}{c}}[/tex]
Ok, I'm still not real sure how to solve numbers 1 and 3 and for the second problem I got an answer of 6.268x10^10 which I know is incorrect. I used 8.99x10^9(40/2.70-40/5.10). Where did I go wrong?
It is the potential difference that you know, not the charge of the particle. You used 40v as the charge, which is clearly wrong. I have edited my post for more clarification but this is as far as I can go.
Alright I've figured out problems 2 and 3 but I'm still stuck on the first one. What does the d mean in your equation?
means that the current is equal to the derivative of the charge with respect to time.
Have you had a course in calculus?
cookiemonster
The current, I, is defined as the amount of charge that goes through any given cross section in a given time period. So if 2c passed in 2 seconds, the current is 1A.
  • · Replies 30 ·
  • · Replies 22 ·
