What is the index of refraction of a gas in an interferometer?
  • Thread starter Thread starter Evergreen
    Interference
The index of refraction of a gas can be calculated using an interferometer by analyzing the phase shift caused by the gas in a cavity. In this discussion, a glass container with a depth of 1.19 cm is filled with gas, resulting in the observation of 209 dark fringes. The light wavelength used is 594 nm. The index of refraction is determined using the formula n = (N + ΔN)/D, yielding a value of approximately 175.63, indicating that the gas has an index of refraction 175.63 times that of vacuum.
  • Understanding of interferometry principles
  • Familiarity with phase shift concepts in optics
  • Knowledge of the index of refraction and its calculation
  • Basic proficiency in using formulas involving wavelength and fringe counting
  • Research the principles of light interference in optical systems
  • Learn about the calculation of phase shifts in interferometers
  • Explore different gases and their respective indices of refraction
  • Study the impact of varying wavelengths on fringe patterns in interferometry
Students and professionals in physics, optical engineers, and researchers interested in the properties of gases and their interactions with light in interferometric setups.
Evergreen
Interference question...
One of the beams of an interferometer, as seen in the figure below, passes through a small glass container containing a cavity D = 1.19 cm deep.
http://capa1.physics.sunysb.edu/CAPA/Pictures/gian2450.gif
When a gas is allowed to slowly fill the container, a total of 209 dark fringes are counted to move past a reference line. The light used has a wavelength of 594 nm. Calculate the index of refraction of the gas, assuming that the interferometer is in vacuum.
??some help
phase difference
As you add the gas, since it has an index of refraction greater than that of the empty cavity (assume a vacuum), you are essentially phase shifting the light in that leg of the interferometer. For every λ of shift, you will seen a fringe move past the reference line. To figure this out, you must calculate how much of a shift you get by replacing the vacuum with the gas.
Hint: compare the number of wavelengths in the cavity when it is filled with gas to the number when it is empty (filled with vacuum). Remember that the light passes through the cavity twice.
The index of refraction of the gas can be calculated using the formula n = (N + ΔN)/D, where n is the index of refraction, N is the number of fringes counted, ΔN is the change in number of fringes, and D is the depth of the cavity. In this case, N = 209, ΔN = 0 (since the reference line is not moving), and D = 1.19 cm. Plugging in these values, we get n = (209 + 0)/1.19 = 175.63. This means that the index of refraction of the gas is 175.63 times that of vacuum. Since the index of refraction of vacuum is 1, the index of refraction of the gas would be approximately 175.63. This value may vary depending on the type of gas used in the experiment.
  • · Replies 24 ·
11K
