Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Physics > Beyond the Standard Model
Reply
image entanglement entropy in Loop Quantum Gravity Share It Thread Tools Search this Thread image
Old Jul7-07, 04:56 PM       Last edited by marcus; Jul7-07 at 04:59 PM..            #1
marcus
marcus's Avatar
Astro Guru 2008
marcus is Offline:
Recognitions:
PF Contributor PF Contributor
I downloaded William Donnelly's talk, given at Loops'07
Entanglement Entropy in Loop Quantum Gravity
http://www.matmor.unam.mx/eventos/lo...B/Donnelly.pdf
maybe he will discuss it with us
I just had a look
Old Jul7-07, 11:09 PM                  #2
marcus
marcus's Avatar
Astro Guru 2008
marcus is Offline:
Recognitions:
Donnelly, if you feel like giving us a little intuitive idea of what the von Neumann entropy is or what the entanglement entropy is----and what the significance is that it turns out to be the same as usual black hole entropy---that would be great, if not that's OK too.
It's nice having people around here at PF who are going to conferences and giving papers.
Old Jul11-07, 01:17 AM                  #3
william donnelly
william donnelly is Offline:
Hi Marcus.
The von Neumann entropy is the natural generalization of entropy for quantum systems. It's defined in terms of the density matrix as
LaTeX Code: S(\\rho) = -\\text{Tr}(\\rho \\log \\rho)
This formula just means you take the eigenvalues of the density matrix LaTeX Code: p_1 \\ldots p_n and apply the usual Gibbs (or Shannon) entropy formula:
LaTeX Code: S(\\rho) = - \\sum p_i \\log p_i
The von Neumann entropy ranges from 0 for pure states, up to log(n) where n is the Hilbert space dimension.
The entanglement entropy is something that is unique to quantum mechanics. If you have a pair of quantum systems (A and B) in a pure state then the state of either subsystem is no longer described by a vector in a Hilbert space, but has to be described by a density matrix. This means that the entropy of the system (A and B) is zero, but the entropy of system A can be greater than zero. The von Neumann entropy of system A is called the entanglement entropy, because it quantifies the total amount of entanglement between systems A and B.
All this bears a resemblance to black hole entropy. A universe containing a black hole can be divided into two systems: everything inside the horizon, and everything outside the horizon. The combined system is in the vacuum state - which is a pure state with zero entropy - so the entire universe has zero entropy. But the observer outside the horizon sees a thermal state with positive entropy. So a natural explanation for this is phenomenon is that there is entanglement between the states inside the black hole and the states outside the black hole, which is causing the region outside the black hole to have entropy even when the total entropy of the universe is zero.
I think the idea that the entanglement entropy of the vacuum is the same thing as the mysterious Bekenstein-Hawking entropy was first proposed by Rafael Sorkin, but I haven't been able to find a copy of his original article. The first reference I have for this idea is described in this paper: http://prola.aps.org/abstract/PRD/v34/i2/p373_1
Hopefully this has clarified a few things. I'd like to talk about the connection to LQG, but it's probably best to wait until the paper is out.
William.
Old Jul11-07, 03:55 AM                  #4
olgranpappy
olgranpappy's Avatar
olgranpappy is Offline:
Recognitions:
Homework Helper Homework Helper
But what do you mean by "entanglement?" That word seems too vivid for it's own good.
Old Jul11-07, 07:26 AM       Last edited by George Jones; Jul11-07 at 08:50 AM..            #5
George Jones
PF Mentor
George Jones's Avatar
George Jones is Online:
Actually, there is a standard definition of entanglement in quantum theory.
Suppose the state space for physical system 1 is LaTeX Code: S_1 and the state space for physical system 2 is LaTeX Code: S_2. Then, the state space for the combined sytem is LaTeX Code: S = S_1 \\otimes S_2. . If the state in the combined system cannot be written as the product of a state in LaTeX Code: S_1 with a state in LaTeX Code: S_2 , then the system is said to be entangled.
For example consider the spins of two electrons. The state
LaTeX Code: \\left| \\psi \\right> = \\frac{1}{\\sqrt{2}} \\left( \\left| \\uparrow \\right> \\left| \\downarrow \\right> +\\left| \\downarrow \\right> \\left| \\uparrow \\right> \\right)
is an entangled state.
Old Jul11-07, 08:17 AM       Last edited by marcus; Jul11-07 at 08:23 AM..            #6
marcus
marcus's Avatar
Astro Guru 2008
marcus is Offline:
Recognitions:
I agree with George. it is old well-established term. Here is an encyclopedia article
http://en.wikipedia.org/wiki/Quantum_entanglement
I would guess the recognition of entanglement came before 1935.
that was when Einstein and a couple of buddies wrote a paper about it.
Einstein didn't like that feature of Quant. Mech. and scornfully called it
Spuckhafte Fernwirkung
Spooky Longdistance Working (spooky action at a distance)
that said, Grandfather, you have a valid point about VIVIDNESS.
there is a dilemma in scientific terminology about whether to say something clearly, in familiar words, or not
you are damned if you do and damned if you don't
if you say it clearly in words that make directly obvious what is happening (like entanglement of two widely separated objects with no obvious material connection)
then you might get accused of sensationalism
(but it is nature's fault for being sensational in her real everyday life)
or else you can use a LATIN OR GREEK word that doesnt directly convey the idea---that is not vivid or graphic or self-explanatory---and then you might get accused of being bookish, or of using jargon to alienate laymen and keep them in the dark.
An example is we say "hydrogen" and in German they say "Wasserstoff" (water-stuff, because if you burn it you get water).
We say "nitrogen" and they say "stink-stuff" because you can use it to make a lot of stinks. If I am mistaken will someone who knows better please correct me, or provide a better example.
this illustrates the two ways to go: you can be forthright direct or you can be Greeky-technical.
the main thing is once you have a term and it is accepted, never try to change it. trying to reform language only leads to more trouble
William Donnelly, thanks for your response. I assume you will be posting a preprint before long?
Old Jul11-07, 08:25 AM                  #7
Demystifier
Demystifier is Offline:
Recognitions:
The entropy of the outside Hawking radiation can be identified with the entropy of entanglement between outgoing and ingoing particles of pair creation. But this is the entropy of outside Hawking radiation, not of the black hole. This is why BH entropy does not seem to be the entanglement entropy. If it still is, there must be something very subtle about it.
Old Jul11-07, 08:42 AM                  #8
william donnelly
There really is a very good reason it is called entanglement entropy, which I completely glossed over. It's based on these theorems:
1. A pure state has zero entanglement entropy if and only if it is a product state. So the standard definition that George gave of "not entangled" is equivalent to "entanglement entropy zero". For the basic entangled state that George wrote down, the entanglement entropy is log(2), or 1 bit. This state is sometimes called an e-bit or "entangled bit".
2. Suppose Alice and Bob share n e-bits. Then they can (approximately) transform it into any state with entanglement entropy less than or equal to n. This is called entanglement of formation.
3. If Alice and Bob share a state with entanglement entropy n, then they can (approximately) transform it into n e-bits. This is called distillable entanglement.
These definitions are used most commonly in quantum computing. To someone building a quantum computer, entanglement is not a mysterious nonlocal force, but a useful resource for computation. And so it's important to know how much you have.
Old Jul11-07, 10:00 AM                  #9
Alamino
Alamino is Offline:
I guess I miss the point in one thing. If you consider the black hole and the universe as two entangled systems, measuring the state of the universe would mean that you know the microstate of the black hole, isn't it? If you are external to the black hole, this cannot be, right? If someone could clarify it to me.
Old Jul11-07, 02:15 PM       Last edited by olgranpappy; Jul11-07 at 04:35 PM.. Reason: further explaination--no responses yet            #10
olgranpappy
Recognitions:
ah, okay--but it's still a pure state. Is an entangled state always a pure state?
...furthermore, that state is nothing more that the usual state of total spin 1 and z-projection 0. Similarly the other independent linear combination (the |0,0> state) is also what you would call an "entangled" state, but I would simply call them "states with S_z=0." Apparently there is no difference, except that you have invented some new language that seems to serve no purpose.
Old Jul11-07, 04:17 PM                  #11
william donnelly
You're right that the entanglement entropy is the same as the entropy of the thermal atmosphere. But because the entanglement entropy is symmetric, it is also the entropy of the vacuum state restricted to the black hole interior. If we take this point of view, the entanglement entropy counts the states of the black hole interior that are correlated with the exterior.
Old Jul11-07, 06:14 PM                  #12
olgranpappy
Recognitions:
Originally Posted by marcus View Post
that said, Grandfather, you have a valid point about VIVIDNESS...
No need for formalities, call me "pappy."
As far as names go, "hydrogen" actually does translate to English as "water-stuff" and similarly "helium" translates as "sun-stuff."
Old Jul12-07, 04:42 AM                  #13
Demystifier
Recognitions:
This point of view seems fine.
But the entropy of the thermal atmosphere does not scale as the BH surface. Or doesn't it?
Old Jul12-07, 08:33 AM       Last edited by George Jones; Jul12-07 at 08:40 AM..            #14
George Jones
PF Mentor
I am not familiar with quantum entanglement of mixed states (William probably is), but there is a definition in this case as well, and it seems to be what I would expect. Scroll down to the Ensembles section from the wikipedia link given by Marcus in post #6.
In the example I chose, the state spaces are irreducible representation spaces of the (cover of) the rotation group. The product representation space is not irreducible, but can written as a direct sum of irreducible representation, i.e.,
LaTeX Code: D_{1/2} \\otimes D_{1/2} = D_0 \\oplus D_1 .
I just happened to chose a state in LaTeX Code: D_1 , but I didn't have to do this. I could have chosen
LaTeX Code: \\left| \\Psi \\right> = \\frac{1}{\\sqrt{2}} \\left| \\uparrow \\right> \\left| \\uparrow \\right> + \\frac{1}{2} \\left| \\uparrow \\right> \\left| \\downarrow \\right> - \\frac{1}{2} \\left| \\downarrow \\right> \\left| \\uparrow \\right>,
which, if I have done things correctly, is an entangled state that is a linear comnination of states from LaTeX Code: D_1 and LaTeX Code: D_0.
The state LaTeX Code: | \\Psi > is entangled ecause it cannot be written in the form LaTeX Code: | \\psi > | \\phi >.
Entanglement has nothing to with angular momentum per se, and so can't, in general, be described by the language of angular momentum. Although my example involved angular momentum, the original definition of entanglement that I gave did not involve angular momentum. The original EPR example did not involve angular momentum. The example using spins was popularized, I think, by David Bohm.
I didn't invent the language, so I would prefer that you say "except that new language has been invented that ..." I don't know when the term "entangled" came into use either in research or in texts. I have a text published in 1986 that I thought used the term, but upon checking I find that although it discusses entangled states, it doesn't call them entangled states. I do have a 1995 "text" that uses the term extensively.
In my opinion, the language does serve a useful purpose. Quantum entanglement is used in stuff like quantum teleportation and quantum cryptography, and is involved in a substantial amount of quantum "weirdness".
Old Jul12-07, 09:57 AM                  #15
william donnelly
It's true that by measuring one half of an entangled state you can learn about the other half. But entanglement can't be used to send signals, so there is no violation of causality. In particular, there's no way that someone on the other side of the horizon could send a message back to the exterior using entanglement.
Old Jul12-07, 11:14 AM                  #16
william donnelly
No. One can also define what it means for a mixed state to be entangled, but the theory is more complicated because there are several different useful measures of entanglement. For pure states the situation is much simpler, because these measures are all equal to the entanglement entropy.
image image
Reply
Thread Tools
Similar Threads for: entanglement entropy in Loop Quantum Gravity
Thread Thread Starter Forum Replies Last Post
Black Hole Entropy calculation by Loop Quantum Gravity yyoon@fas.harvard.edu General Physics 1 Dec25-07 06:00 AM
Loop quantum gravity and Planck-size black hole entropy jal Beyond the Standard Model 25 May9-07 10:10 AM
Loop Quantum Gravity. Son Goku Beyond the Standard Model 3 Sep22-05 06:13 PM
[SOLVED] Errors in loop quantum gravity entropy calculations Lubos Motl General Physics 2 Jul31-04 10:15 AM
quantum-gravity (entanglement) karl robold Beyond the Standard Model 0 Mar26-04 07:31 AM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
