Newtons 2nd Law: F=ma Along x,y or z Direction
The discussion revolves around the application of Newton's second law, F=ma, particularly in the context of forces acting on a body in different directions. Participants explore the implications of vector directions for acceleration and net force, using specific examples involving forces applied to a mass.
  • Participants analyze the net force acting on a body with opposing forces and question how to correctly apply the signs in the equations. There is a discussion about whether to consider the net force as positive or negative based on the direction of acceleration.
Some participants have provided clarifications regarding the signs used in the equations, while others are still grappling with the implications of directionality in vector quantities. There is acknowledgment of errors in previous calculations, and the conversation is ongoing with multiple interpretations being explored.
Participants are working under the constraints of a homework problem, which involves specific setups and assumptions about directionality in forces and acceleration. The discussion also references a problem from a textbook, indicating a need for clarity on the application of Newton's second law in different scenarios.
sweet-buds
F=ma can be written as F=ma(along x, y or z-direction, )
when applying this equation along say horizontal x direction, the direction of acceleration needs to be taken as it is a vector.
i mean say 2 forces of 5 N and 3 N are applied on a 2 kg body that moves towards left as 5 N is applied towards left and 3N towards right. Now
According to me ,
5-3=2(-a)
= 2=-2a
=-1 m/s^2=a
this -1 indicates that accn is towards left.
I am confused with the idea should eqn be 5-3 = -2a or 5-3 =2a. i would go with the former one.
Assuming right to be positive and left to be negative, and the set-up as such:
3 N ----> [2kg] <---- 5 N
Then we have F_net = m*a = 3 N + (-5 N) = - 2 N. You have a net force of 2 N in the negative direction (meaning it will be pushed to the left). Since -2 N = m*a and m = 2 kg, then we have -1 m/s^2. Since this is negative, once again, the body will accelerate to the left.
Does this make sense?
how is that possible? I would say since the 5N force is greater so the F_net=3-5
=-2 N, a force that act towards left. Now, -2=m*(-a)=>-2=2*(-a)=>1=a, as I pressume the body will move towards left due to net -2 N force and since acceleration is towards left, I have used a - ve sign before a.
My confusion arises in the second equation , F=ma where F is the net force acting on the body and let's say the force is in negative horizontal or vertical
direction, arent we suppose to assume the direction of acceleration also negative as acceleration is vector.
Ack! I am terribly sorry - I made a sign error when I added 3 and -5. You are correct! I edited the post with the necessary changes.
You are also correct when you say "he force is in negative horizontal or vertical
direction, arent we suppose to assume the direction of acceleration also negative as acceleration is vector."
help me urgent: Newton's 2nd law
direction, arent we suppose to assume the direction of acceleration also negative as acceleration is vector."[/QUOTE]
i got this problem in Haliday. There are 2 blocks connected by a rope. onr of the blocks is a sliding one and the other is a hanging one and the rope passes over a pulley and the pulley is connected at the edge of the table/surface. The sliding block moves towards the right and the hanging block down. Haliday has applied the Newtons second law to the two blocks.
The sliding block has mass M and hanging block a mass of m. haliday has said the the equation for hanging block is T-mg =-ma. i understand the fact that the hanging block is moving down in -ve y directio, that's why a istaken -ve here but doesn't that mean that mg>T for hanging block to move down. I mean shouldn't the equation be mg-T=-ma?
  • · Replies 42 ·
