Volume of the solid of revolution
The discussion revolves around finding the volume of a solid of revolution formed by the function f(x) = (1/x)e^(1/x) over the interval from x = 1 to x = 6. Participants are exploring the appropriate integration techniques and clarifying the setup of the problem.
  • Participants discuss the formulation of the volume integral and consider using substitution methods. There is a focus on ensuring the correct limits of integration and the proper expression for f(x).
Some participants have offered hints regarding substitution methods and have clarified the integral notation. There is an ongoing exploration of integration techniques, with no explicit consensus on a single approach yet.
Participants are working within the constraints of homework guidelines, which may limit the extent of assistance provided. There is a noted uncertainty regarding the application of integration by parts and the specifics of the substitution method.
benedwards2020
Find the volume of the solid of revolution obtained when the region under the graph of
[tex]f(x) = \left( \frac{1}{x} \right) e^\frac{1}{x}[/tex]
from x = 1 to x = 6
[tex]\pi \int (f(x))^2 dx[/tex]
Ok, the equation I gave above should be that of a definite integral with a=1 and b=6 (If anyone can tell me how to write that in Latex it would be much appreciated)
So, the volume is
[tex]\pi \int_1^6 \left( \frac{1}{x} \right) \left( e^\frac{1}{x} \right)^2 dx[/tex]
So, we can simplyfy this to
[tex]\pi \int_1^6 (x)^{-2} \times e^\frac{2}{x} dx[/tex]
Now I'm a bit stuck as to where to go from here. Do I use the integration by parts method? I think I'm getting bogged down in unnecessary calculations. Can someone give me a hint or point me in the right direction?
Try setting u = 1/x or something like that.
?? You didn't finish your sentence! Between what limits? Rotated around what axis?
So you are rotating around the x-axis?
And only the region between x= 1 and x= 6?
So, the volume is
[tex]\pi \int \left( \frac{1}{x} \right) \left( e^\frac{1}{x} \right)^2 dx[/tex]
No, If [itex]f(x)= \frac{1}{x}e^{1/x}[/itex] then both [itex]f^2(x)= \frac{1}{x^2}e^{2/x}[/itex]
With the values a=1 and b=6
[tex]\pi \int (x)^{-2} \times e^\frac{2}{x} dx[/tex]
Okay, good. Now you have first x squared also. By the way, the code to put the limits of integration in is "\int_1^6". In other words, treat the lower limit as a subscript and the upper limit as a superscript on the integral sign.
Looks to me like the substitution u= 2/x should work nicely.
Many thanks for your time and help... I've managed to solve using substitution as you suggested.
  • · Replies 105 ·
13K
