Net Electric Force on Charged Spheres
The problem involves calculating the net electric force on three negatively charged spheres arranged at the vertices of an equilateral triangle. Each sphere has a charge of 4.0 X 10^-6 C, and the sides of the triangle measure 0.20 m. The original poster attempts to determine the magnitude and direction of the net force acting on one of the spheres using vector components.
  • Participants discuss the use of vector components to find the net force and question how to determine the angle of the net force relative to the sides of the triangle. There are attempts to clarify the symmetry of the arrangement and its implications for the direction of the net force.
Several participants provide guidance on understanding the geometry of the problem and the implications of symmetry. There is an ongoing exploration of the angle calculations, with some participants expressing confusion while others offer insights into the relationships between the forces and angles involved.
Participants note the challenge of visualizing the problem and the need for clear diagrams to support their reasoning. There is mention of the original poster's uncertainty about drawing and interpreting angles in the context of the problem.
rum2563
Three spheres, each with a negative charge of 4.0 X 10^6 C, are fixed at the vertices of an equilateral triangle whose sides are 0.20 m long. Calculate the magnitude and direction of the net force on each sphere.
Fe = kq1q2 / r^2
I used vector components to try to solve this question.
I think that we only have to find the net force on one of the spheres since the radius and the charges are same throughout the system. Sphere 1 is the "main" sphere from which I want to find out the net force.
Force of Sphere 2 on 1:
F2 = kq1q2 / r^2
= (9 X 10^9)(4.0 X 10^-6)^2 / (0.2)^2
= 3.6 N
For the x-component of force of sphere 2 on 1:
F2x = 3.6 X sin 30°
= 1.8 N
For the y-component of force of sphere 2 on 1:
F2y = 3.6 X cos30°
= 3.12 N
The force that was exerted by sphere 3 on 1 is the same force as 3.6 N since all the values are the same. Only the direction is different.
Here is the vector sum:
x = -3.6 - 1.8 = -5.4
y = 3.12
c^2 = 3.12 ^2 + (-5.4)^2
= 6.2365
= 6.2 N
Therefore, the net force is 6.2 N.
BUT... how do I get the angle Θ, because in the book it says 150° away from each side.
Please anyone help. It's just a little problem. Thanks.
The symmetry of the triangular arrangement should allow you to find the direction of the net force immediately--no calculation required.
I have attached the picture of the system. Can you please elaborate a bit more please?
I am thinking that I have to subtract 30 from 180 to get 150. But I just don't know how to prove that in explainable terms.
Please help. Thanks.
Look at your diagram. Along what line must the net force on charge 1 act? (Draw it.) What angle does that net force vector make with a side?
lol. I am seriously confused. I am not sure how to draw but by using tan, I get 30 degress.
tan-1 = 3.12 / 5.4
= 30 degrees.
And I think that since the sphere 3 to sphere 1 line is horizontal, the angle which the net force makes with the horizontal line is 30 degrees. Therefore, 180 - 30 which is 150 degrees is the answer.
Am I on the right track? I know you said no calculations involved but this is the only way I am trying to figure this out.
You can also just find the angle from the force components that you've already calculated, assuming you've done that correctly. Use a little trig.
Ok, well then I think I almost got it right.
Thanks for your help. This is the first time I am studying electric force and I think that's pretty complicated.
Thanks anyways. All the best.
That's perfectly fine (I was just suggesting you do that while you were posting this.)
tan-1 = 3.12 / 5.4
= 30 degrees.
All good. But realize that another solution to your trig equation for tan(theta) is theta = 210 degrees: that's equivalent to 30 degrees below the -x-axis or 150 with respect to the side of the triangle.
But try this. By symmetry, you know that the net force must act right smack in the middle between the two other charges. Since you know the angle between the sides is 60 degrees, the net force must make an angle of 30 degrees below the horizontal axis. Which gives you your answer of 150 degrees with respect to the sides with (almost) no calculation.
Wow, thanks for your response. It actually made perfect sense to me. I am happy that you told me how it doesn't involve any calculation since 60 degrees must be divided by 2 since the net force vector goes exactly through the middle. Thanks very much.
  • · Replies 61 ·
