Lab Experiment for Preparation of Ammonia
by bhuwana65
Tags: ammonia, experiment, preparation
bhuwana65
bhuwana65 is offline
#1
Jul19-07, 10:52 AM
P: 7
Hello ,
We tried to demonstrate preparation of Ammonia by mixing Ammonium Chloride and Calcium Hydroxide in round bottom flask mixed in the proportion of 2:3 .
The flask was in a slanting position with the delivery tube attached to a decicator with Calcium Oxide for drying the gas.
A Flask was attached to the outlet of the decicator for gas collection.
There was no resultant ammonia collected in the collection flask despite a visible flow of gas from the round bottom flask to the decicator on heating.
Need help on identifying the failure of the experiment and suggestions on the rectifications needed to make the experiment sucessful
rgds
Bhuvana
bhuwana65@yahoo.com
Phys.Org News Partner Chemistry news on Phys.org
Patented research remotely detects nitrogen-rich explosives
Pocket-sized anthrax detector aids global agriculture
Structure of sodium channels different than previously believed
Cesium
Cesium is offline
#2
Jul19-07, 11:26 AM
P: 274
You need to heat your solution (you did add water right?) of ammonium chloride and calcium hydroxide. Calcium hydroxide is rather insoluble so it's rather weak at making ammonia, but at near boiling temperatures it should definitely work.
mrjeffy321
mrjeffy321 is offline
#3
Jul19-07, 11:55 AM
Sci Advisor
P: 882
How did you test for the presence of Ammonia in the collection flask?
bhuwana65
#4
Jul20-07, 10:24 AM
P: 7
Thanks for your prompt replies .
My replies as below :
1) since water is produced during the reaction I did not add water . If water is to to be added please advice on the proportion to be added.
2) the presence of ammonia was tested using red litmus paper which turned blue initially .
Await your further help.
Regards
Bhuvana
chemisttree
chemisttree is offline
#5
Jul20-07, 10:35 AM
Sci Advisor
HW Helper
PF Gold
chemisttree's Avatar
P: 3,725
Quote Quote by Cesium View Post
Not so. The solubility of lime (calcium hydroxide) decreases as temperature increases. Lime has its highest solubility at near freezing temperature...
chemisttree
#6
Jul20-07, 10:39 AM
Sci Advisor
HW Helper
PF Gold
P: 3,725
Quote Quote by bhuwana65 View Post
Regards
Bhuvana
When testing for the presence of ammonia gas, it is best to wet the litmus paper.
You really need to add some water to your experiment. Sugar (sucrose) will aid the solubilization of lime. I would prepare a 10% sucrose solution and add that to the lime. Stir for 5 minutes or so and then add the ammonium chloride. The lime does not need to completely dissolve. I would use a 5:1 ratio of sucrose solution to lime. The amount of ammonium chloride should be 1.5 times the amount of the lime added.
bhuwana65
#7
Jul20-07, 10:42 AM
P: 7
Can anybody suggest a site which give details of various quantum numbers and order of filling up the orbitals (for Grade 11 students)
bhuwana
bhuwana65@yahoo.com
Cesium
Cesium is offline
#8
Jul20-07, 11:17 AM
P: 274
Quote Quote by chemisttree
This is true, but increasing the temperature to increase the solubility was not my point. It is necessary to increase the temperature in order to increase the rate of reaction. I've performed a similar experiment before using ammonium nitrate and calcium hydroxide and at room temperature you only get a VERY weak smell of ammonia, but near boiling it really starts coming over.
So, bhuwana, I would suggest at least enough water to dissolve the ammonium chloride and to heat your solution. Calcium hydroxide works for producing ammonia but not as easily as more soluble hyroxides like sodium hydroxide.
bhuwana65
#9
Jul31-07, 11:49 AM
P: 7
Dear all,
Thanks a lot,my experiment withn ammonia preparation went off suceesfully and i could also perform fountain expt.
bhuwana
chemisttree
#10
Jul31-07, 12:19 PM
Sci Advisor
HW Helper
PF Gold
P: 3,725
What is the fountain experiment?
mrjeffy321
#11
Jul31-07, 05:28 PM
Sci Advisor
P: 882
Quote Quote by chemisttree View Post
An exert from the “Golden Book of Chemistry” (1960),
http://i62.photobucket.com/albums/h1...y321/PF/AF.jpg
bhuwana65
#12
Jan6-08, 02:15 AM
P: 7
For Class XII students ,I am conducting Qualitative salt analysis.While analysing various salt mixtures we had a problem with a particular mixture
It was Leadnitrate+Calcium carbonate.
The mixture does not dissolve in Cold Water/Hot water/Cold dilue Hcl/Hot Dilute Hcl.What i mean we do not get a clear solution to go to Group I,which is lead
In addition to that Lead precipates again In Group IVas lead sulphide in black colour( in presence of NH4cl+in excess of NH4OH+H2S).
It is very confusing.How to guide them .Pl.help
Bhuvana
chemisttree
#13
Jan7-08, 10:32 AM
Sci Advisor
HW Helper
PF Gold
P: 3,725
Lead is always a problem when you use HCL. The solubility product of lead chloride is 1.6X10^-5 so adding excess HCl to dissolve these will ultimately lead to problems.
Take your cue from the soluble salts of lead, especially nitrate. Try dissolving the calcium carbonate in nitric acid instead.
Good luck.
Sweet&Sour
Sweet&Sour is offline
#14
Feb19-09, 02:01 PM
P: 1
Hi
I'm also trying to prepare Ammonia and can you all please just say how you prepare it again I kind of got lost.
Thanks
Ayush Suwal
Ayush Suwal is offline
#15
Jul20-09, 09:30 AM
P: 5
uhh can anyone tell answer my question please. why is the mixture of ammonium chloride and calcium hydroxide a paste instead of a solution?
chemisttree
#16
Jul20-09, 10:25 AM
Sci Advisor
HW Helper
PF Gold
P: 3,725
Quote Quote by Ayush Suwal View Post
Because you didn't add enough water to completely dissolve the solids.
Ayush Suwal
#17
Jul21-09, 05:37 AM
P: 5
So u mean to say i gotta add more water???
Ayush Suwal
#18
Jul21-09, 05:42 AM
P: 5
but i got a question to answer here "Y IS THE MIXTURE A PASTE INSTEAD OF A solution
Register to reply
Related Discussions
Ammonia and polycarbonate reaction Chemistry 3
phenylamine ammonia basicity Biology, Chemistry & Other Homework 1
Concentration of ammonia in a solution Chemistry 7
Ammonia Fire Biology, Chemistry & Other Homework 2
safety rules for ammonia Biology, Chemistry & Other Homework 3
