What is Boil off in Liquid Hydrogen?
  • Context: High School
  • Thread starter Thread starter Booter
    Boil Hydrogen Liquid
The discussion revolves around the concept of "boil off" in liquid hydrogen, exploring its definition, implications, and the physical processes involved. Participants delve into the mechanisms of gas escaping from containers, the terminology surrounding gas release, and the conditions under which boil off occurs, including heat transfer and pressure dynamics.
  • One participant expresses confusion about the concept of boil off, associating it with gas loss from a container.
  • Another participant describes boil off as the gas that escapes before sealing a container or as a venting mechanism to prevent overpressure.
  • It is suggested that outgassing refers to gas escaping from materials, while offgassing pertains to the boil off of cryogenic liquids due to heat leakage.
  • Some participants note that sealing a container of liquid hydrogen could lead to catastrophic failure due to pressure buildup from boil off.
  • Terminology clarification occurs, with suggestions that "diffusion" or "permeation" might describe the leakage of gas through materials.
  • A participant explains that boil off in industrial terms refers to the amount of cryogenic liquid that converts to gas due to heat leak, with distinctions made between normal evaporation rates and vented gas amounts.
  • There is a discussion about the relationship between pressure and temperature in a closed container of liquid hydrogen, with questions about achieving equilibrium under extreme conditions.
Participants exhibit a mix of agreement and disagreement regarding the definitions and implications of boil off, outgassing, and the behavior of gases in sealed containers. No consensus is reached on the best terminology or the conditions under which equilibrium can be achieved.
Participants highlight the complexities of gas behavior in cryogenic conditions, including the effects of temperature and pressure on boil off and the potential for catastrophic failure in sealed containers. There are unresolved distinctions between various terms related to gas release.
Booter
Liquid Hydrogen Boil off ?
I am a little bit confused as to what boil off is, I can only assume it is the loss of gas but it is still unclear to me as to how a gas can escape from a steel container. Can anyone try to explain this to me better. Thank you very much
Welcome to PF, Booter.
I've always thought of 'boil-off' as simply the part that gets away before you can get the lid on, or as something vented to prevent an overpressure mishap.
Your question appears to be about what I call 'outgassing'. The molecules of hydrogen are small enough to fit through the intermolecular spaces in most materials. It's the same reason that you have to use special material for helium balloons to keep them from deflating right away. You can sort of think of it on a larger scale by figuring what would happen if you had a bunch of sand on a vibrating screen, the way archaeologists sift for fossils.
Assuming the container and you are still in one piece it will have an overpressure (boil-off) valve!
Depending on the size of the container and the quality of the insulation you might not be able to hear/feel anything coming out.
so once the container is sealed the only loss will be due to outgassing, and if I understand correctly this will be a very minute amount
Nerp --- "seal" a container of liquid hydrogen and be prepared for a very abrupt failure of the container. The "boil-off" is to carry off heat leaking into the container through the insulation.
Careful with the terminology.
Outgassing usually means (in a vacuum) any small amounts of air trapped in corners or absorbed on the surfaces being slowly released.
Offgassing means the boil off of a cryogenic liquid as heat leaks into it.
As bystander said - liquid hydrogen is the worst possible substance to trap in a sealed container. 1 litre of H2(l) will boil to fill a cube about 6" on a side!
Your lab will have rules about not traveling in elevators with liquid gas containers for this reason.
Sorry. So is there a name for that leakage that I was referring to, or is it just called 'leakage'? :confused:
I would probably call it "diffusion" but leakage is as good.
Permeation, permeability --- as H2 through Pd (and every other metal), Hg through Au, O2 through Cu, He through quartz --- and, given enough time, just about anything from a condition of high chemical potential through just about anything else to a state of lower chemical potential.
Hi Booter,
The term "boil off" is a term used in the industrial gas industry for the amount of cryogenic liquid which converts to a gas by boiling inside a cryogenic tank. It has a very specific meaning, but it also has a very general meaning.
Every vacuum insulated cryogenic container has some amount of heat leak, and that heat will boil away the cryogenic liquid. If you maintain a constant pressure in the tank over time then you'll obviously need to vent gas off the tank. That rate of venting is the very general use of the term.
Boil off can also have a very specific meaning though which regards the "normal (or nominal) evaporation rate" (NER). Cryogas International is an industry journal, and they have a pretty good write up on it here:
http://www.cryogas.com/news/basiccryogenics.php
Boil off in the sense of NER boil off rates can mean one of two things. It can be the actual mass of cryogenic liquid that boils off per unit time, or it can be the actual mass of vapor vented from the tank. The amount of liquid that changes state is actually slightly higher than the amount of vapor vented since some vapor will stay inside the vessel to displace the liquid that just boiled. Generally, the term "boil off" is the amount which boils and NER is the amount vented, which is slightly less.
Note that boil off has nothing to do with outgassing. Outgassing is a phenomena seen in vacuums whereby gas comes off of the surface of a solid material as indicated by mgb_phys.
Thanks for the clarification about 'outgassing', guys. I'm not sure where I got the impression that it meant what I thought it did, but it's been with me a long time. :redface:
Liquid carbohydrates can lead to hydrogen (sulfide)
outgassing, too. :)
so although the liquid hydrogen would become gassious hydrogen I assume in a closed container that it would increase in pressure until an equilibrium was met between temperature and pressure. on that point even though boil off would occur would the temperature also increase in the pressure vessel? Thank you for all the great replies
How is an equilibrium going to exist when liquid hydrogen is roughly -420 F? The liquid will all boil off, convert to gas, and as the gas warms up, pressure will continue to rise. The only way to come to some equilibrium temperature and pressure is for the temperature to rise to ambient such that there's no more heat transfer.
  • · Replies 32 ·
