Thread Closed
Length of a spring under its own weight
Share Thread Thread Tools
Jul20-07, 02:31 PM   #1
I was thinking over lunch today about this old problem from intro physics but I can't remember whether or not this is the correct solution.
What is the final length L of a spring of mass M and spring constant k, initially of length L0 after it is left to hang under its own weight?
2. Relevant equations
3. The attempt at a solution
Divide the unstretched spring into infinitesimal segments dl. Each of these segments will stretch an infinitesimal distance dx under the weight of an infinitesimal mass dm by the relation g dm = k dx. Let [tex]\lambda[/tex] be the linear density of the spring, so that [tex]dm = \lambda \,dl[/tex]. Then,
[tex]g \lambda \,dl = k \,dx[/tex], and
[tex]dx = \frac{g}{k}\lambda dl[/tex].
Integrating LHS from 0 to X and RHS from 0 to L0, we find that [tex]X = \frac{g}{k}\lambda L_0[/tex], so the final length of the spring is L = L0 + X or
[tex]L = L_0(1 + \frac{g}{k}\lambda) = \frac{g}{k}M + L_0[/tex].
Is that right?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Jul20-07, 03:19 PM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
I'm no student of the calculus, but your solution is identical to the case where the spring is massless and its weight is concentrated at the far end. That doesn't sound right. I believe your extension X should be 1/2 of your calculated value, i.e. X =Mg/2k. Comments welcome.
Jul20-07, 03:26 PM   #3
The com is at L/2, but only half of the spring is effectively pulling that mass up, so 2kx=mg, which gives you x=mg/2k.
Jul20-07, 03:28 PM   #4
Yeah, now that I think about it, that should be completely wrong, since the segments at the top are under greater load than the ones at the bottom. I'll think about it again in a bit.
Jul20-07, 03:30 PM   #5
Quote by gabee View Post
Is that right?
I think youre forgetting that each element has more than just dm*g acting on it (the masses of the elements below it are acting on each element too).
Jul20-07, 05:57 PM   #6
Right, that's what I mean. Okay, so including the fact that ALL the masses below a certain point contribute to the stretching of the segment at that point, we have
[tex]k \,dx = \bigg( \frac{l}{L_0} \bigg) g \, dm[/tex]
[tex]dx = \frac{gl}{L_0 k} \frac{M}{L_0} \, dl[/tex]
[tex]dx = \frac{Mgl}{{L_0}^2 k} \, dl[/tex]
[tex]x = \frac{Mg}{{L_0}^2 k} \int_0^{L_0} l \, dl[/tex]
[tex]x = \frac{Mg}{{L_0}^2 k} \frac{{L_0}^2}{2}[/tex]
[tex]x = \frac{Mg}{2k}[/tex]
Ahh, thanks guys
Thread Closed
Thread Tools
Similar Threads for: Length of a spring under its own weight
Thread Forum Replies
[SOLVED] Length of Spring Introductory Physics Homework 4
Natural Length of a spring Calculus 2
natural frequency of a spring(self-weight only) Introductory Physics Homework 9
Spring, length and speed Introductory Physics Homework 6
Finding the max length of a spring Introductory Physics Homework 3
