Calculating Proton's Motion in Uniform Electric Field - Answer Check & Help
  • Thread starter Thread starter cowgiljl
A proton traveling at 3E6 m/s enters a uniform electric field of 3E5 N/C, resulting in a calculated distance of 0.157 meters before it comes to a momentary halt. The force acting on the proton is 4.8E-14 N, leading to a deceleration of 2.87E13 m/s². The time required for the proton to stop is determined to be 1.04E-7 seconds. These calculations utilize fundamental physics equations related to motion in an electric field.
  • Understanding of Newton's Second Law (F = ma)
  • Knowledge of kinematic equations for uniformly accelerated motion
  • Familiarity with electric fields and forces (F = qE)
  • Basic algebra for solving equations
  • Study the effects of electric fields on charged particles
  • Learn about kinematic equations in detail
  • Explore the concept of electric force and field strength
  • Investigate advanced topics in particle motion under various forces
Students of physics, educators teaching electromagnetism, and anyone interested in the dynamics of charged particles in electric fields.
cowgiljl
A proton traveling at 3E6 m/s enters a region where the electric field has a magnitude of 3E5 N/C. The electric field is uniform and slows the proton's motions.
a)calculate the distamce the proton will travel before coming to a momentary halt?
B)Calculate the decel. of the proton and the time for it to trqavel this distance
F=qE = 1.6E-19 * 3E5 = 4.8E-14 N
a = F/m 4.8E-14 / 1.67E-31 a = 2.87E13 m/s
D = Vf^2 - Vi^2 / 2A = 3E6^2 / 2 * 2.87E13 = .157 m
I am not sure how to do part B or what formula to use
thanks joe
Assuming "decel." means deceleration, you already found it in part (a). To find the time it travels before stopping, use this formula:
[tex]V_t = V_0 + at[/tex]
For part B, you can use the equation for deceleration, which is a = (Vf - Vi)/t, where a is the deceleration, Vf is the final velocity, Vi is the initial velocity, and t is the time.
To find the deceleration, you can use the same formula as in part A, which is a = F/m. So, a = 2.87E13 m/s.
Next, you can use the distance calculated in part A, which is 0.157 m, as the displacement (A) in the deceleration equation. The final velocity (Vf) is 0 m/s since the proton comes to a halt, and the initial velocity (Vi) is 3E6 m/s.
Plugging these values into the equation, you get: 2.87E13 = (0 - 3E6)/t
Solving for t, you get t = 1.04E-7 seconds. This is the time it takes for the proton to come to a halt.
Hope this helps!
