Thread Closed
On limits
Share Thread Thread Tools
Apr7-04, 09:10 AM   #52
On limits
Suppose a and b are different real numbers and for any e>0 we know |a-b|<e then a not= b.
proof:
If a is not b then |a-b|>0.
Let d be the difference.
Let e = d/2 then |a-b|=d and |a-b| < d/2 > 0, hence d > 0
and also |a-b|/2 > 0.
therefore non-zero/2 > 0.
Apr7-04, 09:15 AM   #53
Recognitions:
Homework Helper Homework Help
But your hypothesis is false: if a and b are distinct real numbers then it is not true that for every e>0 |a-b|<e. You do understand what the quantifier for all means?
Apr7-04, 09:17 AM   #54
Recognitions:
Actually that 'proof' of yours should go down in history: you assume a and b are distinct numbers, make a false claim about them and use that false claim to prove that a and b a different, which is part of the hypothesis... fantastic
Apr7-04, 09:18 AM   #55
Recognitions:
What are you trying to prove there anyway, now you've edited it? cos looking at it you can't really tell.
Apr7-04, 09:21 AM   #56
How do you mean it is unknown?
I'm fairly sure it is at ... If you let be your base unit then it is really easy to mark it on.
Or do you just mean there is no given ratio between 1 and in terms of decimals?
What I say is very simple: Pi is a notation an element, which its exact place in the real line is unknown.
More then thet, any element, that can be represented by infinitely many elements, its exact place in the real line is unknown, for example:
3/9 place is well-known 3/10 place is unknown.
Apr7-04, 09:26 AM   #57
Recognitions:
Why is 1/3's place known? How do you know where 1 is? Or zero? The real numbers aren't actually physically a line, Organic. You are confusing the representation of something with the something... Oh, no, you're going to talk about x and model(x) again aren't you?
Actually the statement above is trivially true because it is of the form A=>B whre A is false....
Apr7-04, 09:27 AM   #58
The two different a and b are both < e.
Therefore |a-b| = d < e, but both d and e > 0.
Apr7-04, 09:28 AM   #59
Recognitions:
Quote by Organic
What are you on about?
Do you know what a number line is? It is not something physical...
Apr7-04, 09:31 AM   #60
Recognitions:
Quote by Organic
but that isn't deducible from your hypothesis: just because |a-b|<e does not state that a and b are both less than e. (take e=1 a=b=100,000,000). so it's a further pointless assumption.
Try writing out the statement of the lemma again, and its proof making sure all the hypotheses are written correctly and that it is not vacuous (which it was first time)
and seeing as the statement was for all e, then you've just shown a=b=0
Apr7-04, 09:33 AM   #61
Yes exactly, Math is only a theory therefore x-itself does not exist is its scope, only x-model can be used by Math language.
Apr7-04, 09:34 AM   #62
Recognitions:
good, then the model of the real numbers that is in mathematics is cauchy sequences, and 0.9999...=1 in that model, and as the discussion started about that model that's the end of the story.
Apr7-04, 09:46 AM   #63
Thank you for this correction you are right.
When we writing |a-b| < e we mean that d < e.
If a and b are distinct real numbers then for any e > |a-b| = d > 0.
Apr7-04, 09:49 AM   #64
No, cauchy sequences do not prove that 0.999... = 1 without breaking infinitely many elements to become finitely many elements, by reaching the limit.
Apr7-04, 09:52 AM   #65
Recognitions:
Quote by Organic
let e=d>2, then you have
d/2>d and d>0. now think for a second.
d/2>d => d>2d => 0>d ,yet d>0.
Want to rethink that at all.
Apr7-04, 09:57 AM   #66
let e=d>2,
This in not the case because e>d always.
Apr7-04, 09:59 AM   #67
Recognitions:
Quote by Organic
As real numbers are defined... oh look, circles. Tell you what, why don't you tell us what you think the real numbers are? Since your definition must be equivalent to the one using cauchy sequences where 0.9999 =1 by definition you are in trouble. I think this is because when mathematicians speak of a model, in the sense of something satisfying the axioms, an example, they don't mean what you think the mean. ie a model in the sense of a model of turbulence, or something, which is only an approximation (at the moment). There is no approximation; you are confusing the concrete and the abstract. The Cauchy sequence argument is not some "best approximation" mathematically to the "physical" real numbers, they are the real numbers, in and of themselves, it is the things that you draw on the page using axes that are the approximation, not the other way round.
breaking, infinitely many, finite, that's you wishing something to be true that isn't, you are thinking unmathematically (perhaps intuiitive and physically in your opinion, but that isnt' mathematics).
Apr7-04, 10:04 AM   #68
Recognitions:
Quote by Organic
then your initial quantifier, for all e>0, is not correct is it?
Here is your initial post:
No restriction on e>d. at all and it says for any e>0 doesn't it?
Once more you move the goal posts half way through your argument when someone points out where it's gone wrong.
So want to start from the beginning and clearly write out what it is you are trying to prove again?
Because so far you're not doing very well. I mean what was the point of it anyway?
Thread Closed
Thread Tools
Similar Threads for: On limits
Thread Forum Replies
limits, yes another limits thread. General Math 25
Limits - Please Help! Calculus & Beyond Homework 3
limits and log Calculus 7
limits Introductory Physics Homework 25
Limits Introductory Physics Homework 0
