How Does Throwing a Toolkit Affect an Astronaut's Speed in Space?
The discussion centers on the application of the Conservation of Linear Momentum to determine the final speed of an astronaut after throwing a toolkit in space. An 80 kg astronaut initially drifts at 2 m/s towards a stationary shuttle while carrying a 20 kg toolkit. When the astronaut throws the toolkit at 6 m/s towards the shuttle, two calculations yield different results: 1 m/s and 4 m/s, depending on the sign used for the toolkit's velocity. The correct approach emphasizes consistent sign usage in momentum equations.
  • Understanding of Conservation of Linear Momentum
  • Familiarity with vector velocity concepts in physics
  • Basic algebra for solving equations
  • Knowledge of reference frames in physics
  • Study the principles of Conservation of Linear Momentum in different reference frames
  • Learn about vector addition and subtraction in physics
  • Explore examples of momentum conservation in space scenarios
  • Review the effects of mass and velocity on momentum calculations
Physics students, educators, and anyone interested in understanding momentum dynamics in space environments.
Confused_07
80 kg astronaut carrying a 20kg tool kit is initially drifting toward a stationary space shuttle with a speed of 2 m/s. If sh throws the tool ki toward the shuttle with a speed of 6 m/s as seen from the shuttle, her final speed is?
If it is seen from the shuttle, does that mean the 6 m/s is a negative or a positive?
I used the Conservation of Linear Momentum
m1Vf1 + m2Vf2 = m1Vo1 + m2Vo2
Vf1 = (m1Vo1 + m2Vo2 - m2Vf2) / m1
= [(80*2) + (20*2) - (20*6)] / 80
= 1 m/s
**If I use a -6 instead, the answer is 4 m/s. Which is right?
= 1 m/s
one is correct and one is incorrect. but which? Let me do this dumb Socratic thing and lead you to the answer by asking you questions...
Why did you choose the initial velocity as positive? Why not use v0=-2m/s?
Does the overall sign really matter? (I'll answer that..) No.
You just have to make sure that the signs are consistent. If you choose to call the initial velocity positive (i.e. +2m/s) and the toolbox is moving in that same direction that you called positive, well, then...
