Question about cue ball collisions
  • Context: Undergrad
  • Thread starter Thread starter JamesL
    Ball Collisions
The discussion centers on solving a physics problem involving elastic collisions, specifically between a cue ball and an eight ball. The cue ball, initially moving at 3 m/s, collides with a stationary eight ball, resulting in the cue ball's final speed of 1.4 m/s. Participants confirm that the problem should be approached using the conservation of momentum and energy principles, breaking down the momentum into X and Y axes to find the angle of the eight ball's trajectory post-collision.
  • Understanding of elastic collisions in physics
  • Familiarity with conservation of momentum and energy principles
  • Knowledge of vector decomposition in two dimensions
  • Basic skills in solving algebraic equations
  • Study the principles of elastic collisions in detail
  • Learn how to apply conservation of momentum in two dimensions
  • Explore vector decomposition techniques for physics problems
  • Practice solving problems involving kinetic energy and momentum
This discussion is beneficial for physics students, educators, and anyone interested in understanding the mechanics of collisions and energy conservation in elastic interactions.
JamesL
Heres the question:
Assume an elastic collision (ignoring friction and rotational motion).
A cue ball initially moving at 3 m/s strikes a stationary eight ball of the same size and mass. After the collision the cue ball's final speed is 1.4 m/s.
Find the eight ball's angle with respec to the original line of motion of the cue ball.
I can't really post a diagram for you guys to see, but the cue ball is a little above the eight ball (from a birds eye view, left to right). So when the collide the eight ball is moving at a downwardish angle (this is the angle i am supposed to find) and the cue ball is moving upwards.
This question kind of threw me off bc in class we are studying work and kinetic energy etc. All of our homework problems have been about that so far. I can't seem to find a way to incorporate those concepts into this problem.
Should it just be done as a conservation of momentum problem?
Can anyone point me in the right direction?
Yes, use the conservation of both energy and momentum. The only difference is that this time, you need to divide the momentum into two axes, X and Y:
[tex]m_1v_1_x + m_2v_2_x = m_1u_1_x + m_2u_2_x[/tex]
[tex]m_1v_1_y + m_2v_2_y = m_1u_1_y + m_2u_2_y[/tex]
And finally energy:
[tex]\frac{1}{2}mv_1^2 + \frac{1}{2}mv_2^2 = \frac{1}{2}mu_1^2 + \frac{1}{2}mu_2^2[/tex]
You can eliminate a couple of unknowns here, since you know the second ball was initally stationary. You also know that the first ball only have speed in one of the axes. Additionally, I think you also know the angle of impact between the two balls, which means you know the direction of their velocities after the impact. So:
[tex]v = \frac{v_x}{\cos \theta}[/tex]
[tex]v_y = v_x\tan \theta[/tex]
  • · Replies 20 ·
  • · Replies 32 ·
  • · Replies 49 ·
