Properties of subtraction?
by lLovePhysics
Tags: properties, subtraction
lLovePhysics
lLovePhysics is offline
#1
Jul25-07, 02:56 PM
P: 167
Are there any communative properties of subtraction because there are many formulas like the slope and distance formulas where you can switch the two terms around right? For example:
Slope Formula: [tex]m=\frac{y1-y2}{x1-x2}[/tex]
You can switch the terms around so that it would be y2-y1, x2-x1 right?
Also for the distance formula:
[tex]\sqrt{(x1-x2)^{2}+(y1iy2)^{2}[/tex]
Btw, the numbers are suppose to be subscripts.
Phys.Org News Partner Mathematics news on Phys.org
Researchers help Boston Marathon organizers plan for 2014 race
'Math detective' analyzes odds for suspicious lottery wins
Pseudo-mathematics and financial charlatanism
cristo
cristo is offline
#2
Jul25-07, 03:05 PM
Mentor
cristo's Avatar
P: 8,287
No, subtraction does not commute, but you could say something like [itex]|x-y|=|y-x|[/itex].
The reason you can swap the terms in the first equation you give is, since y1<y2 and x1<x2, swapping both the values of x on the top and y on the bottom will introduce a minus sign in both the numerator and denominator, which will cancel.
In the distance formula, you are squaring the difference between x1 and x2, and y1 and y2, which will make sure the answer is always positive.
neutrino
neutrino is offline
#3
Jul25-07, 03:08 PM
P: 2,048
Subtraction is not commutative. In your example of the slope formula, you're just multiplying the numerator and denominator by -1. In the case of the dist. formula, you're using the property the square of any non-zero real number is positive.
P.S. For subsripts, use underscore, as in x_1. [tex]x_1[/tex]
VietDao29
VietDao29 is offline
#4
Jul26-07, 02:23 AM
HW Helper
VietDao29's Avatar
P: 1,422
Quote Quote by lLovePhysics View Post
Are there any communative properties of subtraction ...
Well, as others have pointed out, the answer is no, there isn't. You can pick up a simple example and see:
3 - 2 = 1
whereas: 2 - 3 = -1.
Well, 1 and -1 are, of course, different. So, no, subtraction is not commutative. :)
CompuChip
CompuChip is offline
#5
Jul26-07, 02:53 AM
Sci Advisor
HW Helper
P: 4,301
But you can also see that
[tex]3 - 2 = - (2 - 3)[/tex]
which you can read as shorthand for
[tex]-1 \times (2 - 3).[/tex]
Now this does always hold and explains why the formulas in your first post work out:
  • What happens if you multiply numerator and denominator by the same number in a fraction?
  • What happens if you square the opposite of a number (e.g. [itex]x^2 = x \times x[/itex] versus [itex](-x)^2 = (-x) \times (-x)[/itex].
Register to reply
Related Discussions
'difference' and subtraction General Math 20
more vector help (subtraction) Introductory Physics Homework 5
computer subtraction Electrical Engineering 3
How does the properties of glass affect its properties?? General Physics 3
Confusing subtraction Linear & Abstract Algebra 3
