Understanding D-brane Probes: A Beginner's Guide to String Theory Concepts
  • Context: Graduate
  • Thread starter Thread starter Creighton Hogg
    Probes
Probe D-branes are real objects in string theory, specifically Dp-branes, which are used to measure the properties of larger systems, such as the D9-antiD9 brane system. They are termed "probes" because they are lighter and less massive than the surrounding system, allowing them to interact without significantly altering the dynamics. The physics on the Dp-brane's worldvolume is crucial for understanding string interactions in the presence of these larger brane systems. This concept is essential for beginners studying string theory, particularly in the context of hep-th/0403247, QED and String Theory.
  • Understanding of D-branes and their dimensional labeling (Dp-branes)
  • Familiarity with string theory concepts and terminology
  • Basic knowledge of quantum field theory, particularly Quantum Electrodynamics (QED)
  • Awareness of the implications of backreaction in physical systems
  • Study the properties and roles of D-branes in string theory
  • Learn about the dynamics of D9-antiD9 brane systems
  • Explore the concept of worldvolume physics in string theory
  • Investigate the implications of subplanckian distances in string theory
This discussion is beneficial for students and researchers in theoretical physics, particularly those focused on string theory, quantum field theory, and anyone seeking to understand the complex interactions of D-branes.
Creighton Hogg
Stupid Question #2 for today:
I started trying to read hep-th/0403247, QED and String Theory, last night
but I really don't understand this concept of probe D-branes.
When they say that they're taking a probe Dp-brane in the background of a
D9-antiD9 brane system, is the Dp-brane part of the background too or is
it just a mathematical construct, kindof a reverse method of images, meant
to help analyze the physics of the system. If it's part of the
background, I don't understand why it's being called a probe, but if it's
just a construct I don't understand why they're describing the physics on
its worldvolume. Sorry, but I'm rather confused at this point.
[moderator note: a probe is an object - a real object, not just a virtual
gedanken experiment - that is meant to measure and see the properties of
the background, and it is probe because it should be light or invisible
enough so that it does not affect the background, or at least we can
neglect such a "backreaction". Nevertheless, in string theory you are only
allowed to consider probes that are allowed by the theory - not some
fictitious angels. For example, string theory predicts that there are no
objects that are more localized than some concrete (sub)planckian
distance. This really means that shorter distances don't exist in the
geometrical sense. Everyone: please feel free to give a different answer. lm]
Thank you for your question. D-brane probes are an important concept in string theory and can be confusing for beginners. Let me try to clarify it for you.
A D-brane is a type of object in string theory that can be thought of as a hypersurface, or a higher-dimensional membrane, on which strings can end. These D-branes can have different dimensions, labeled by a number p, and are often represented as Dp-branes.
Now, when we talk about a probe Dp-brane in the background of a D9-antiD9 brane system, we are essentially talking about placing a Dp-brane in the vicinity of this D9-antiD9 system. The Dp-brane is a real object and is indeed part of the background. However, it is called a "probe" because it is much lighter and less massive than the D9-antiD9 system, and therefore does not significantly affect the dynamics of the system. It is like using a small and delicate instrument to measure the properties of a larger and more complex object.
The reason why we describe the physics on the Dp-brane's worldvolume is because that is where the strings can end and interact with the D-brane. This allows us to study the behavior of strings in the presence of the D9-antiD9 system by analyzing the interactions between the strings and the probe Dp-brane.
I hope this explanation helps to clear up your confusion. Remember, it is always important to ask questions and seek clarification when learning about complex concepts like string theory. Keep reading and exploring, and you will gain a deeper understanding of D-brane probes and other concepts in string theory.
  • · Replies 21 ·
  • · Replies 24 ·
