Are Two Copies of the Virasoro Algebra Equivalent to Diff(S^1)xDiff(S^1)?
  • Context: Graduate
  • Thread starter Thread starter Zig
    Algebra Classical
The discussion revolves around the relationship between two copies of the Virasoro algebra and the group of diffeomorphisms of the cylinder, specifically whether they are equivalent to Diff(S^1) x Diff(S^1). Participants explore concepts related to conformal transformations, diffeomorphisms, and the implications for string theory.
  • Exploratory, Technical explanation, Debate/contested
  • One participant suggests that the classical Virasoro algebra is the Lie algebra of the group Diff(S^1) and expects that two copies would correspond to Diff(S^1) x Diff(S^1), but questions this assumption.
  • Another participant clarifies that the group generated by two copies of the Virasoro algebra is not the full group of diffeomorphisms of a two-dimensional worldsheet, but rather a group of conformal transformations that preserve angles.
  • It is noted that conformal transformations must transform the metric to another metric in the conformal gauge, indicating a limitation on the group generated by the Virasoro algebra.
  • Participants discuss the implications of preserving lightlike directions in the context of conformal transformations and how this relates to the structure of the Virasoro symmetry.
  • There is a suggestion that the group of conformal transformations of the cylinder can be understood as two copies of Diff(S^1), corresponding to the diffeomorphisms of the two lightcones.
  • One participant expresses curiosity about the classification of the difference in size between the diffeomorphism group in D=2 and the conformal group, pondering whether the diffeomorphism group has a nondenumerable dimension.
  • A participant mentions the context of computing the partition function of free bosonic field theory in 1+1 dimensions on the cylinder and expresses confusion regarding the relationship to tori.
Participants exhibit a mix of agreement and uncertainty regarding the equivalence of the two groups, with some clarifying points about the nature of conformal transformations while others raise questions about the implications and classifications involved.
There are limitations regarding the assumptions made about the groups involved, particularly in terms of the definitions of diffeomorphisms and conformal transformations, as well as the scope of the discussion being focused on two dimensions.
Zig
[SOLVED] Classical Virasoro Algebra
The classical virasoro algebra is the Lie algebra of the group
Diff(S^1), right? So I expected that if I look at the direct sum of two
copies of the Virasoro algebra, I should get the Lie algebra to
Diff(S^1)xDiff(S^1), from standard Lie theory.
Instead, it seems that two copies of the Virasoro algebra generates the
group of holomorphic maps on the cylinder. Are these two groups really
the same? Is there an easy way to see it?
On Sat, 27 Mar 2004, Zig wrote:
> ... Instead, it seems that two copies of the Virasoro algebra generates the
> the same? Is there an easy way to see it?[/color]
Dear Zig,
that's a good question. Several comments should be said.
1. First, the group generatated by (two copies of) the Virasoro algebra is
not the group of all diffeomorphisms of a two-dimensional worldsheet
because such a group would be much much bigger (there is much more freedom
to reparameterize 2 coordinates - they can mix in various ways); it is
just a group of conformal transformations, i.e. the diffeomorphisms that
preserve the angles, i.e. the diffeomorphisms that preserve the original
metric up to a spacetime-dependent scaling. If you consider the standard
Minkowski metric on the cylinder, the conformal transformations must
transform the metric to another metric in the conformal gauge, g_{mn} =
exp(2.phi(s,t)) eta_{mn} where (s,t) are worldsheet coordinates and
eta_{mn} is diag (1,-1). The conformal transformations are those that have
not been fixed by the gauge choice g_{mn} = exp(2.phi(s,t)) - most of them
have been fixed, and therefore the conformal transformations form a very
small group of the original reparameterization group in 2 dimensions.
2. Second, what does it mean to preserve the angles (or the equivalent
conditions from [1]) on the Minkowski worldsheet? In two dimensions it
simply means that the null (lightlike) directions must be mapped to
themselves. Using the coordinates s+t and s-t on the worldsheet (we won't
use the standard symbols sigma^+ and sigma^- here because it is actually a
longer, less convenient notation in e-mail), we see that the conformal
transformations from [1] must map (s+t) to a function of (s+t), and (s-t)
to a function of (s-t), so that the null lines (s+t)=const - and also
(s-t)=const - remain lightlike for arbitrary choices of "const".
3. Otherwise, the new (s+t), called (s'+t'), can be an arbitrary function
of (s+t), and the same thing holds for for (s'-t') and (s-t). It means
that the group of conformal symmetries of the Minkowski cylinder is
determined by an arbitrary diffeomorphism on the coordinate (s+t), and an
independent, commuting diffeomorphism on the coordinate (s-t).
4. Well, up to a periodicity condition. If the periodicity of the
spacelike direction "s" was L, then the identification in terms of
(s+t,s-t) is that (s+t,s-t) is the same point as (s+t+L, s-t+L). Your
diffeomorphisms must preserve this periodicity. Because the
diffeomorphisms acting on s+t and s-t are independent, and they must
preserve this combined periodicity, these diffeomorphisms must respect, in
fact, the periodicity separately. Therefore you get two copies of the
Virasoro symmetry (diffeomorphisms of a circle) - one of the copies
generates the arbitrary diffeomorphisms of the circle of allowed values of
"s+t", and the other does the same for "s-t".
5. The Virasoro generators are operators whose Hermitean conjugates are
the operators from the same sector: it's because the Hermitean conjugate
(=inverse) of the unitary transformation "reparameterize (s+t) in some
way" is again "reparameterize (s+t) in another way". Even if we
Wick-rotate and work with the Euclidean worldsheet, where it looks like
that the antiholomorphic (was: right-moving) sector is complex conjugate
to the holomorphic (was: left-moving) sector, the operation of *Hermitean*
conjugation in fact includes the operation t_E -> -t_E (the Euclidean time
runs backwards), and therefore the Hermitean conjugate of a Virasoro
generator from one of these two families (i.e. acting on the holomorphic
coordinate) is still an operator acting on the same group.
Feel free to ask more refined questions.
Best wishes
Lubos
______________________________________________________________________________
E-mail: lumo@matfyz.cz fax: +1-617/496-0110 Web: http://lumo.matfyz.cz/
eFax: +1-801/454-1858 work: +1-617/496-8199 home: +1-617/868-4487 (call)
Lubos Motl wrote:
> ... that's a good question. Several comments should be said ...[/color]
Hi Lubos!
thanks for the detailed reply. I am enthusiastic about the string
theory newsgroup. I hope you don't mind elementary questions from
students like me.
> metric up to a spacetime-dependent scaling.[/color]
yes, I think i can appreciate this fact. It is OK to refer to them as
holomorphic maps, though, right? in 2D, a conformal transformation is
holomorphic, so I can either think of them as maps which preserve the
metric up to a scale, or maps that preserve the complex structure.
> small group of the original reparameterization group in 2 dimensions.[/color]
yeah, I suppose it is a very small subgroup. If we were in D>2, the
group of conformal maps would be finite dimensional. a much much
smaller group. I wonder if there is a precise way to classify the
conformal group. perhaps the diffeomorphism group has a nondenumerable
dimension?
> Because the
> "s+t", and the other does the same for "s-t".[/color]
OK, that explains it! So the group of conformal transformations of the
cylinder is two copies of Diff(S^1), because it is really
diffeomorphisms of the two lightcones. this was a very helpful explanation.
> Feel free to ask more refined questions.[/color]
Thanks again for the reply. I don't seem to have a more refined
question. Maybe I can ask another question? my professor's explanation
of this has left me mystified.
In computing the partition function of free bosonic field theory in 1+1
dimensions on the cylinder, we identify the in and out states in the
theory, so that our partition function is really calculated on a torus.
(I am taking this from p. 244 of "Mirror Symmetry" by Hori et al.) We
are doing a lot with tori, and the book and my professor's explanation
are opaque to me.
Anyway, thanks for your time, I hope you don't find it bothersome for
students questions on your newsgroups.
-z
> students like me.[/color]
It was a pleasure, and I hope that after a week there will be many people
actively participating.
> metric up to a scale, or maps that preserve the complex structure.[/color]
Absolutely. On a Minkowski spacetime/worldsheet, a conformal
transformation also preserves the metric up to a scale, which means that
it must preserve the light cone - the set of all null directions at each
point.
> group of conformal maps would be finite dimensional.[/color]
Right. The conformal group of a d-dimensional Euclidean space is
SO(d+1,1), and that of a d-dimensional Minkowski space is SO(d,2): you
always add (1,1) dimensions to the rotational/Lorentz symmetry.
If you combine the new 1+1 dimensions into light-like directions +,-, then
the conformal group SO(d+1,1) or SO(d,2) has the following generators:
J_{ij} - the rotational (or Lorentz) generators
J_{+i} - the momenta P_i; note that they commute with each
other because g_{++}=0
J_{+-} - this is the dilatation operator, rescaling the whole
space(time) by an overall factor
J_{-j} - well, these are the extra nontrivial conformal generators
In two Euclidean dimensions, you obtain the conformal group SO(3,1) which
is isomorphic to SL(2,C) / Z_2, while in 2 Minkowski dimensions you obtain
SO(2,2) which is SL(2,R) x SL(2,R) (over some Z_2's). SL(2,C), for
example, is what maps the sphere CP^1=S^2 onto itself.
However in two dimensions you can extend the conformal group to an
infinite-dimensional group of all holomorphic maps; such transformations
are well-defined at least locally. Such an extension is not possible in
d>2.
> a much much smaller group. I wonder if there is a precise way to
> classify the difference in size between the diffeomorphism group in
> D=2 and the conformal group. perhaps the diffeomorphism group has a
> nondenumerable dimension?[/color]
The diffeomorphism group is much bigger. You can imagine the dimension of
the diffeomorphism group to be "d" times the number of points in your
d-dimensional spacetime: at each point, you can define "d" components of
an infinitesimal vector field that generates a reparameterization of
coordinates. The conformal group is much smaller - you saw that its
dimension equals the number of points on "two circles", so to say, which
is much smaller than the number of points on a two-dimensional worldsheet.
In d>2 the dimension of the diffeomorphism group grows even more while the
conformal group becomes finite-dimensional: the discrepancy between these
two group is increasingly big as "d" grows.
In 1 dimension, the group coincide because every 1D diffeomorphism
(reparameterization of 1 coordinate) is conformal :-).
> diffeomorphisms of the two lightcones. this was a very helpful explanation.[/color]
Exactly.
> theory, so that our partition function is really calculated on a torus.[/color]
Great, but I hope there was no specific question here - at least I've
found no question mark(s). ;-)
Cheers,
Lubos
> always add (1,1) dimensions to the rotational/Lorentz symmetry.[/color]
This might sound silly, but is there an easy geometric "picture" that
helps you see why you "add (1,1) dimensions to the rotational/Lorentz
symmetry"? I understand that it works out that way, but I can't visualize
it.
> d>2.[/color]
Now I've seen this claim before that the infinite dimensional extension of
the conformal group is not, generically, well-defined globally but how
does this work? It sounds like this infinite dimensional group is the
automorphisms of C, and so it only applies to charts diffeomorphic to C.
Is that right or am I all washed up?
>>d>2.[/color]
>[/color]
Hi Creighton-
I am sure Lubos will be able to answer this better than I, but let me say
some stuff too anyway.
A map from C to C that may be written as a local holomorphic map can be
Laurent expanded around z=0, so that f=Sum a_n*z^{n+1}. Such a function
will satisfy the Caucy-Riemann equations where it is defined, and so be
a conformal map. The space of these local holomorphic maps is infinite
dimensional. But these maps may blow up at z=a. If we restrict to
n>-1, then our maps are only well defined on the cylinder C-{0}. If we
also want our function to behave at infinity, then we can substitute
w=-1/z, and find that we also must require n<1.
Thus, the conformal maps that are globally defined are generated by a
finite dimensional subset of the full conformal group. If we allow our
conformal maps to have poles at z=0 and infinty, then we regain the full
infinite dimensional group.
[moderator note: I would probably talk about n>=0 and n<=2 in the Laurent
expansion for the infinitesimal variations of "z" as a function of the
same "z", but otherwise morally I would agree with the framework of your
explanation. Cheers, lm]
>>theory, so that our partition function is really calculated on a torus.[/color][/color]
> found no question mark(s). ;-)[/color]
Zig:
Ooops! Right, a question! OK, the part that I have been scratching my
head over, is why are we allowed identify the in/out states? The prof
said something about the fact that the partition function involves a
trace, which doesn't distinguish the states, I think, although I was a
little lost. I just didn't get it.
thanks again
Lubos Motl tries to answer:
There is only one Hilbert space to work with, and the partition sum is the
trace of the operator exp(-beta.H) that acts on this single Hilbert space.
The operator exp(-beta.H) may be understood as the evolution operator thru
an imaginary time i.beta, and therefore is represented by a path integral
defined on a cylinder that is made of the circle of the original closed
string, times a Euclidean time interval. Yes, tracing means that you
impose periodic boundary conditions (and antiperiodic boundary conditions
for all fermionic fields).
I don't know precisely why you want to start with two Hilbert spaces. In
my approach I never had two distinct Hilbert spaces, and your problem is
therefore unknown to me. ;-) Even when we consider scattering - in which
it makes sense to distinguish "in" and "out" states - these two Hilbert
spaces are isomorphic, and an "out" state |psi> is nothing else than the
action of the S-matrix (the unitary evolution over an infinite time
interval) on the "in" state |psi>.
  • · Replies 26 ·
  • · Replies 61 ·
11K
  • · Replies 0 ·
