Coefficient of kinetic friction between box and floor
The problem involves a box of oranges being pushed across a horizontal steel surface, experiencing a constant deceleration. Participants are tasked with calculating the coefficient of kinetic friction based on the forces acting on the box.
  • Participants discuss the forces acting on the box, including the push force and frictional force. There is an exploration of the relationship between acceleration, net force, and friction. Questions arise regarding the direction of acceleration and the correct interpretation of forces.
Some participants have provided guidance on the calculations and have pointed out the importance of considering the direction of acceleration. There is a progression in the calculations presented, with adjustments made based on feedback. However, there is no explicit consensus on the final value of the coefficient of kinetic friction.
Participants are working within the constraints of the problem statement, which includes specific force values and the requirement to find the coefficient of kinetic friction. The discussion reflects an ongoing examination of assumptions related to the forces involved.
Edwardo_Elric
A 98 N box of oranges is being pushed across a horizontal clean steel surface until it stops. As it moves, it is slowing down at a constant rate of 1.1m/s each second. The push force has a horizontal component of 25N and a vertical component of 20N downward. Calculate the coefficient of kinetic friction between the box and the floor.
summation of Fx = 25N - fk = ma
= 25N - fk = (10kg)(1.1m/s^2)
fk = 14N?
summation of Fy= 0 = -Fw - Fdown +normal force
normal force = 20N + 98N = 118N?
fk = (uk)(Fn)
(14N / 118N) = uk
uk = 0.119
You're on the right track, but not quite there yet. The box is slowing down. What's the direction of the acceleration and the net horizontal force acting on the box?
thanks phantomjay
= 25N - fk = (10kg)(-1.1m/s^2)
fk = (1.1m/s^2)(10kg) +25N
fk = 36N
uk = (36N/118N)
uk = 0.305
is this right?
Yep, looks real good now, although you should round off the uk value to 0.3. Nice work.
  • · Replies 16 ·
