I on this problem about angular speed.
The problem involves a 22 kg child jumping onto a 110 kg rotating disk with a radius of 2.9 m, initially rotating at 2.1 rad/s. To find the new angular speed of the disk-child system, apply the conservation of angular momentum. The moment of inertia for the flat disk is calculated using the formula I = 0.25 * m * r^2. The angular momentum of the child at the radius of the disk must be considered to determine the final angular speed after the child jumps onto the disk.
  • Understanding of angular momentum conservation
  • Knowledge of moment of inertia calculations
  • Familiarity with rotational dynamics
  • Basic physics concepts related to mass and radius
  • Study the conservation of angular momentum in closed systems
  • Learn how to calculate moment of inertia for various shapes
  • Explore the effects of external forces on rotational motion
  • Review examples of angular speed calculations in physics problems
Physics students, educators, and anyone interested in understanding rotational dynamics and angular momentum principles.
dungtran88
A 22 kg child jumps onto the rim of a 110 kg rotating disk of radius 2.9 m. If the angular speed of the disk before the child's jump was 2.1 rad/s what is the angular speed of the disk-child system?
I got no idea how to start this problem or what formula to use. please help me solve this problem before the day is over. thank you
well the child jumping seems just too much.well anyways i assume that there is suffciient friction between the tyres and the child(i assume him as a point mass :eek:)
just apply conservation of angular momentum about the centre of the disk.
since all forces torque are internal
Look up the definition of angular momentum and moment of inertia.
What is the angular momentum of the child at the radius of the roundabout?
Since angular momentum is conserved what has to happen to the momentum of the roundabout to provide the new angular momentum of the child?
ps. Unless I have missed something, you have to know that the moment of inertia of a flat disk = 0.25 * m * r^2
  • · Replies 20 ·
  • · Replies 25 ·
12K
