Compression of an electrostatic charged sphere
The discussion revolves around the behavior of an electrostatically charged sphere, particularly focusing on the implications of compressing the sphere and the relationship between electric potential and energy expenditure during this process. Participants explore concepts related to voltage, electric potential, and the movement of charges within the context of a charged sphere.
  • One participant proposes a system involving a charged sphere and an outer sphere, questioning how the voltage inside the cavity behaves when the sphere is compressed.
  • Another participant asserts that the outer sphere creates a constant voltage inside, leading to a discussion about the implications of this constant voltage on energy expenditure when compressing the sphere.
  • There is a claim that reducing the radius of the sphere does not require energy because the potential inside remains constant, despite the voltage decreasing.
  • A participant questions the concept of voltage at infinity and the conditions under which potential energy is defined between charges.
  • Clarifications are made regarding the definitions of electric potential and voltage, with a participant explaining that a decrease in radius results in an increase in electric potential, thus requiring energy to compress the sphere.
  • Another participant acknowledges the need to account for energy expenditure when moving charges, emphasizing the importance of considering the potential at both the initial and final points of movement.
Participants express differing views on the relationship between voltage, electric potential, and energy expenditure during the compression of the charged sphere. There is no consensus on the implications of these concepts, and the discussion remains unresolved.
Participants highlight the complexity of calculating energy expenditure in relation to changing electric potentials, indicating that assumptions about voltage behavior and energy requirements may vary based on the specific conditions discussed.
cala
"compression" of an electrostatic charged sphere
Everytime i propose a new motion machine from my ignorance or misunderstunding of physics, your explanations solve some questions, but open new others:
I proposed a system that acumulated electrons on a sphere surrounded by an electrons charged outter sphere, then connecting them, all the electrons will pass to the outter sphere.
Now I know that the outter sphere will create a voltage into the cavity that will not let the electrons go into the inner sphere, unless you force them aplying energy. (Urkil knows how hard it was to explain me that).
OK, so the electrons on the outter sphere will create a constant voltage inside.
Now, from my last post, a new question cames to my head:
If the voltage inside the cavity is constant, we have to expend no energy to move a free electron that were inside this cavity.
Then, imagine you can "shrink" the sphere. As the inside voltage the electrons generate is constant, it will cost you nothing to move the electrons, but once you've reduced the sphere, the voltage is more negative.
How this process happens? Will the electrons know that the voltage will decrease before it really decreases?. (Think about the graphic of potential respect the distance to the centre of the sphere, and you'll see that reducing the radius, the potential will decrease, but it stays always horizontal, so "in principle" it will cost you nothing to "shrink" the sphere).
Ignore me if this seems weird but, if the electrons are on the out of the sphere, they must be not moving, therefore there must be no current ...
Right ?
Yes, there is no current.
I'm talking about a 10 cm charged sphere with electrons.
From the 10 cm to infinite, the voltage goes from V- to 0
From the 10 cm to 0, the voltage remains at V-
Then, reducing the R of the sphere (imagine from 10 cm to 5 cm) cost you no energy, because the potential inside is constant, it doesn't matter the V is decreasing, it's constant on every value from R to 0.
(you're not moving the electrons to a lower value of V, you are creating that V value by moving the electrons).
Why should you expend work to reduce R, if the V- inside the sphere remains constant on everypoint (but decreasing its value, it's true) on every moment?.
What exactly do you mean that there is a voltage with infinity ?
As far as i remember we explain voltage as being an electrical potential energy between two charges.
How do you make sure that there is a certain charge in infinity and that the charge on your sphere has a potential energy to the charge in infinity ?
Greetings !
Cala, I'm not certain what exactly you're
talking about, but allow me to just make
some general relevant clarifications.
First, V is electric potential.
What you may call voltage is U which is
the difference in electric potential.
Now, within a sphere U = 0 at every point,
however the electric potenital V is the
same at every point below or equal to R
of the sphere.
Now, if you decrease R - V will grow
because V = K * Q / R .
Now, since the potential is different
when R is smaller (V is larger) it means
that to achieve this radius decrease you need
to put in energy which can be calculated by
multiplying the potential difference U = V2 - V1
and multiplying it by the charge of the
sphere, so E = Q * U . (Think of it, you're
pushing opposing charges closer together by
overcoming their mutual electric repulsion.)
Hope this helps.
Live long and prosper.
Thanks Drag, you helped a lot.
You just answer exactly what i was talking about.
So you've got to waste energy as if you were moving this charges from initial V to final V, although the V is created by the same charges, and not yet there.
Thanks.
Originally posted by cala
and not yet there.
What do you mean ?
To compute what energy you have to apply when you move a charge, you take the initial point, then look for the V at that point, then look at the final point where you'll move the charges, and there is another V value, and then make the calculus.
In the situation I explain, if you make the calculus by this method, the final V is not the V that is on final point with the charges on initial point. To make the calculus, you take the final V that will be there when the charges arrives there, not the V that is on final point when the charges are still on initial point (because the final V with charges on initial point will be the same as on the initial point, because the voltage inside the cavity is V elsewere).
I hope it helps.
  • · Replies 16 ·
  • · Replies 27 ·
17K
