Thread Closed
curve banking problem???
Share Thread Thread Tools
Jul27-07, 12:25 PM   #1
a curve of radius 30m is banked so that a 950kg car traveling 40 km/h can round it even if the road is so icy that the coefficient of static friction is approximately zero. Find the range of speeds at which a car can travel around this curve without skidding if the coefficient of static friction between the road and the tires is 0.3
2. Relevant equations
This part i really need help in pls may i ask for any equations to use i cant even understand the problem. I can't interpret the free body diagram pls give me a formula ^^
3. The attempt at a solution
none i tried drawing a slope with an object but i don't know how to get the angle of the slope...
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Jul27-07, 12:33 PM   #2
Mentor
What class are you taking? What equations are introduced in the chapter that this question is from? You need to show more effort before we can help you much.
Jul27-07, 01:04 PM   #3
think about this
when the car has maximum speed, friction is down the slope and when speed is minimum, friction is up the slope
Jul27-07, 01:51 PM   #4
Recognitions:
Homework Helper Homework Help
First ignore the friction and calculate the slope of he curve from the icy case. Draw a diagram to show the forces on the car.
Jul27-07, 11:15 PM   #5
How do i calculate the slope pls.. i'm taking physics natural science and the last formula our pro gave us was the coefficient of friction times normal force is equal to force of friction. so i don't know how to get the slope of the problem i don't even know how to derive where the slope came from sorry
Jul27-07, 11:19 PM   #6
Recognitions:
This example shows how to draw the diagram
http://farside.ph.utexas.edu/teachin...es/node92.html
Jul28-07, 01:30 AM   #7
thank you for the diagram it has been very helpful thank you very much i at least have an idea now on how to sole ^^
Jul28-07, 02:56 PM   #8
Recognitions:
Extending it to the case of friction just involves adding the extra foces, remember that friction will act parrallel to the road in a direction to stop the car slipping.
As you said above, friction force is the normal force * coefficent of friction.
Jul29-07, 03:08 AM   #9
Quote by mgb_phys View Post
I guess frictional force considered in this question is the force acting perpendicular to the road which avoids the car slippin towards or away from centre of the circular track(or any kind of track, maybe call it instantaneous center) at lowest and highest speed at the curve respectively.
the frictional force mgb_phys is considering is the force which gets the car going
Thread Closed
Thread Tools
Similar Threads for: curve banking problem???
Thread Forum Replies
curve problem Calculus & Beyond Homework 5
Banking curve problem Introductory Physics Homework 1
banking curve problem cont'd ???? Introductory Physics Homework 1
"Banking" Problem Introductory Physics Homework 4
Banking corners Problem regarding assignment Introductory Physics Homework 9
