2-D Waves: Relation of power with radius
The discussion focuses on the relationship between power and radius in the context of 2-D waves, exploring how power varies with distance from a source. Participants examine theoretical aspects of wave behavior in different dimensions, including plane waves and their implications for power distribution.
  • Some participants propose that power is directly proportional to amplitude squared for all waves, questioning how this relationship holds in 2-D cases.
  • One participant notes that plane waves are not solutions to the wave equation in more than one dimension, suggesting that scattered waves may take a different form.
  • It is mentioned that, in two dimensions, the amplitude of waves falls off as 1/sqrt(r), leading to the conclusion that power would fall off as 1/r.
  • Another participant confirms that in three dimensions, power falls off as 1/r², while in two dimensions it falls off as 1/r, and remains constant in one dimension.
  • One participant introduces the Poynting vector as a method to analyze how power radiates through surfaces in different dimensions, explaining the reasoning behind the fall-off rates.
Participants express some agreement on the general behavior of power in relation to radius across different dimensions, but there is no consensus on all aspects of the discussion, particularly regarding the implications of wave forms and their solutions.
The discussion includes assumptions about wave behavior and the definitions of power and amplitude, which may not be universally accepted or fully resolved. The mathematical steps leading to the conclusions about power fall-off are not fully detailed.
Readers interested in wave physics, particularly in the context of dimensional analysis and power distribution in waves, may find this discussion relevant.
PrinceOfDarkness
As I understand, power is directly propotional to amplitude squared for all waves. In the 2-D case, how will power depend on 'r'?
For plane waves, the wavefunction is exp(ik.r) and multiplying it with its complex conjugate gives a constant amplitude and thus a constant power (I think). But who says that all 2-D waves are plane waves!
In special cases, power can be constant, but I guess, in general, it must have a dependence on 'r'. I read in AP French's book 'Vibrations and Waves', somewhere in the last chapter where he discusses the solutions of wave equation in two and three dimensions, that far from the source the amplitude falls off as 1/sqrt(r). So Amplitude squared would be 1/r and thus power will fall as 1/r.
Is that correct? :confused:
um... nobody says that. Indeed, plane-waves with respect to the distance from some origin (e.g., [tex]e^{ikr}[/tex]) are not solutions to the wave-equation in more than one dimension; the scattered (or radiation) part of the wave may have the form of a plane wave *multiplied by another function*, but never a plane-wave alone in more than one-dimension.
As you stated, in two dimensions the scattered wave does infact have the form
[tex] \psi\approx\sqrt{\frac{1}{r}}e^{ikr}\;.[/tex]
I.e., a plane wave in radial distance multiplied by one over the squareroot of the distance.
sure. Thus in two dimensions the power radiated is always finite, not infinite and not zero, as it should be. Similarly in three dimensions having radiation fall-off like 1/r leads to finite power radiated, and in one dimension having radiation fall off like 1/r^0=1 leads to finite power radiated.
Thank you.
Correct me if I am wrong: Power falls off as
1/r^2 in 3-D
1/r in 2-D
Constant w.r.t. 'r' in 1-D?
You've been very helpful. I've been confused about this question for a while now!
Thank you.
1/r^2 in 3-D
1/r in 2-D
Yeah, I believe so. What you want to look at is the Poynting vector
[tex] \vec S=\vec E \times \vec H\;.[/tex]
If you integrate this over a surface it tells you the energy which flows through the surface per unit time (power). One can thus figure out how fast the radiated power falls off by reasoning thusly:
In three dimensions consider a very large spherical surface which encloses a radiating object. The energy flowing through the surface is all due to radiation because we have chosen it to be very far away. The area of the surface is [tex]4\pi r^2[/tex] thus the energy radiated must fall off as [tex]1/r^2[/tex].
Similarly in two dimensions we consider a very large circle whose "surface" length is
[tex]2\pi r[/tex] thus in two dimensions the energy radiated falls off as 1/r.
Similarly in one dimension we consider a "surface" (which is just two points) very far away whose "area" doesn't change with distance thus the energy radiated doesn't change with distance.
You can work out further cases in higher (non-physical) numbers of space dimensions...
Cheers.
That is very helpful. I never knew one could think of the relationship between power and raidus that way.
  • · Replies 20 ·
  • · Replies 0 ·
