2 particle system: Photon + Massive particle
  • Context: Graduate
  • Thread starter Thread starter kmarinas86
    Particle Photon System
The discussion revolves around the interactions between a photon and a massive particle, exploring concepts such as momentum transfer, energy conservation, and the implications of these interactions on the motion of the massive particle. The scope includes theoretical considerations and conceptual clarifications regarding the behavior of particles in such a system.
  • One participant proposes a scenario where a photon emitted by a massive particle could lead to perpetual motion, questioning the validity of this idea.
  • Another participant challenges the diagrams presented, suggesting they demonstrate unphysical behavior and questioning the assumption that reflected photons retain the same frequency as incident photons.
  • There is a discussion about the equations for conservation of momentum and energy, with participants seeking clarification on how these apply to the system described.
  • A participant mentions the need to consider whether the massive particle (an atom) has internal structure and how that might affect the conservation laws applicable to the scenario.
  • One participant asserts that there is only one law of energy conservation, emphasizing the importance of considering the atom's state after interaction.
  • A suggestion is made to derive the Compton Scattering relation as a relevant framework for understanding the interactions in this context.
Participants express differing views on the physical implications of the photon-massive particle interaction, with no consensus reached on the validity of the initial assumptions or the interpretations of the diagrams. The discussion remains unresolved regarding the specifics of momentum and energy conservation in this scenario.
Limitations include unclear definitions of the outputs in the problem and the assumptions regarding the behavior of the photon and massive particle during interaction. The discussion also highlights the need for a more detailed understanding of the massive particle's properties.
kmarinas86
Consider a two particle system:
---- photon ----------- massive particle ---------------------
------- photon -------- massive particle ---------------------
---------- photon ----- massive particle ---------------------
------------- photon -- massive particle ---------------------
---------------- photon massive particle ---------------------
------------------- photon massive particle ------------------
A photon is emitted and absorbed by a particle. I assume that the massive particle would be pushed in the process, however, when the photon is emitted in the opposite direction:
------------------- photon -- massive particle ---------------
---------------- photon ----- massive particle ---------------
------------- photon -------- massive particle ---------------
---------- photon ----------- massive particle ---------------
------- photon -------------- massive particle ---------------
That's perpetual motion! So it has to be wrong.
The alternative possibility I can think of is this:
As a photon approaches a massive particle which will absorb it, it will (pull it in?)
-------------- photon massive particle -----------------------
And then when it is emitted, it will pull it out?
This seems to be more symmetrical, is this what happens? It certainly isn't perpetual motion. But people tell us of radiation pressure, though solar sails must be reflective.
Alternatively, could the photon be emitted in the other direction:
-------------- massive particle photon -----------------------
------------ massive particle -- photon ----------------------
------------ massive particle ----- photon -------------------
------------ massive particle -------- photon ----------------
But then this to is perpetual motion. Advice?
Science news on Phys.org
It isn't clear what your diagrams are supposed to demonstrate (or rather, they demonstrate something unphysical: the massive particle should continue moving with constant velocity after the event, and not just be shifted to the side briefly), nor why you think this is perpetual motion, but I'd guess that the root of your error is in presuming that the reflected photon has the same frequency as the incident photon.
Can you write down the equations for conservation of momentum?
Well the photon has no mass, but it does have momentum. Would that be [itex]p=hf/c[/itex], where [itex]p=momentum[/itex] [itex]h=planck's constant[/itex], [itex]f=frequency[/itex], and [itex]c=speed of light[/itex]? We would have then:
[itex]m_i v_i + p_i=m_f v_f + p_f[/itex]
Is there supposed to be more than one equation?
how about conservation of energy. why don't you tell us a little bit more about your "massive particle." Does it have any internal structure or is it just a point?
An Atom.
There are many conservation of energy laws. Also, the outputs are not defined specifically in the problem, so I'm not sure which ones to use.
kmarinas86 said:
An Atom.
no. there are not. there is one law: Energy is conserved.
In your case you will have to take into account whether or not the atom is left in an excited state.
What you're trying to do is basically derive the Compton Scattering relation, so check out hyper-physics if you're stuck.
  • · Replies 35 ·
  • · Replies 29 ·
  • · Replies 87 ·
9K
  • · Replies 58 ·
  • · Replies 18 ·
