What are the Two Methods for Calculating the Center of Mass of a Semi-Circle?
The discussion revolves around calculating the center of mass of a semi-circular band, with participants exploring two methods: an intuitive approach and a standard formula. The original poster expresses difficulty in reconciling the results from both methods.
  • Participants discuss the use of a path integral for the formula method and question the validity of the intuitive approach. There is a focus on understanding the implications of mass distribution and the definition of a chord in relation to the problem.
Some participants have provided clarifications regarding the nature of the semi-circular band versus a solid half-circle. There is acknowledgment of the need to consider mass distribution more carefully, particularly in relation to the center of mass. The discussion is ongoing with no clear consensus yet.
Participants are working under the assumption that the center of mass calculations must account for the unique properties of a band versus a solid shape. There is also mention of needing to verify the correctness of the formula method presented by the original poster.
alfredska
I'm having difficulty in making two methods of the calculation of center of mass come out equivalently. One method is via intuition and the other is via standard formula.
Find the center of mass of a semi-circular band of length L and mass M, and represent it in terms of [tex]\alpha R[/tex].
http://www.olypen.com/mdpsoul/physhelp/band-cm.png
http://olypen.com/mdpsoul/physhelp/book.png
http://olypen.com/mdpsoul/physhelp/intuit.png http://olypen.com/mdpsoul/physhelp/formula.png Can anyone track down the problem here?
Do you have the equation for the area enclosed by a chord?
Calculate what chord is required to have an area of half the semicircle.
Chord?
I must not understand you. Area via chord formula? I'm using a path integral for the formula method, are you suggesting something is wrong there? Please elaborate.
Chord? As in a string laid out in an arbitrary manner?
A chord is a line drawn across 2 points i=on the circumference of a circle, the chord area is the area between the chord and the circumference ( which becomes a semi circle in the case where the line is the diameter )
The area of this chord area is quite easy to derive http://mathworld.wolfram.com/Chord.html, what you are trying to find is the distance of the chord from the centre such that the area is 1/4 the are of a circle.
Band
Realize this is a band of length L, in the shape of a semi-circle. I am not seeking the center of mass of solid half circle, rather the center of mass of a "rod" bent into a semi-circle.
It is NOT correct that at the center of mass, mass above=mass below. Take a one dimensional example, point mass m at x=0, and mass 2m at x=1. We all know that the center of mass is at x=2/3. But mass above 2/3 is not equal to mass below 2/3. The mass needs to be weighted by its distance from the center.
Mass Above not equal to Mass Below
Dick,
I think you have explained why my intuitive method is incorrect. Splitting the mass in half as I have done, still leaves the upper portion further away from the CM than the lower half, and no weighting was done to take that into account. Thank you.
I am under the assumption that the formula method I presented is correct. Any verification by another member would be appreciated.
Thanks again.
The other method looks fine to me.
Oops - sorry, that does make a difference!
