Electrical engineer, most introvert job?
The discussion revolves around identifying which jobs within electrical engineering may require the most solitary work involving analysis and calculations. It explores various roles and their associated tasks, considering both technical and regulatory aspects.
  • One participant inquires about electrical engineering jobs that involve significant time spent on analyses and calculations.
  • Another participant suggests that lab work is typically done solo, indicating a preference among some engineers for solitary tasks.
  • A different viewpoint asserts that being an introvert may not align with the demands of a successful electrical engineer.
  • One participant outlines various electrical engineering roles that require extensive bureaucratic or regulatory analyses, such as those in medical devices and avionics, which may involve compliance with safety regulations.
  • Technical calculations and analyses are noted to be prevalent in microwave design, quantum electronics design, and digital signal processing implementations.
  • IC design is mentioned as requiring significant simulations and analyses, particularly for high-speed and mixed-signal applications.
  • Another participant humorously suggests that sewer electronics work, which involves field tasks, may allow for considerable solitude away from colleagues and the public.
Participants express differing views on the relationship between introversion and success in electrical engineering, with no consensus on which specific jobs are the most solitary or require the most analysis.
The discussion includes various assumptions about job roles and the nature of work in electrical engineering, with some participants focusing on technical aspects while others emphasize regulatory considerations.
roll
Which job in electrical engineering would you guys think requires most time for yourself doing analyzes and calculations?(nerd work:!))
Lab work is almost always done solo. Most true electrical engineers don't want to do it for that very reason.
- Warren
Introvert? Not if you want to be a successful EE.
"analyses and calculations" eh?
Well there's a whole LOAD of EE jobs where you might
need to spend a LOT of time doing bureaucratic / regulatory
oriented analyses and calculations e.g. medical devices
that need FDA or other kinds of approvals, avionics where
you have to go through a lot of FAA or other kinds of
process / documentation, safety regulated stuff like
equipment for use in explosive environments or so on.
Now if you're just talking about TECHNICAL calculations
and analyses that aren't mostly related to compliance
or regulatory engineering...
Microwave design tends to involve a fair amount of
modeling especially at the higher frequencies for the more
complex systems, satellites, etc.
Quantum electronics design, potentially.
DSP implementations that involve EE or complex
mixed signal signal processing design.
Doing IC design involves a lot of simulations and analyses
usually, especially very high speed stuff or mixed
signal stuff at high density and high performance.
As for introvert, there's always doing sewer electronics
for things like flow measurement, anti-corrosion,
etc. Lots of field work, and you'll be left WELL alone
by your colleagues, the public, your spouse, your dog, ...
  • · Replies 20 ·
