Thread Closed
Geometry Problem
Share Thread
Aug2-07, 06:18 PM   #1
Mentor
Geometry Problem
Hi,
This is not really a problem for the template (it is not even homework). I have come across the elementary geometry problem shown in the figure below.
I am wondering whether there is some way to solve for a and b uniquely. Although I was able to come up with an expression for every single angle in the diagram in terms of a or b, the only constraint I have found so far is the obvious one: a + b = 90 degrees. That alone leads to infinitely many solutions. Wondering whether there was another constraint I had missed, I tried an arbitrary solution a = 40, b = 50, and it works. It seems more likely that any thing in the solution set to a + b = 90 is fine, rather than me having stumbled upon the only unique solution there is.
The problem as stated does not ask for the values of a and b, it asks only whether:
a > b
a < b
a = b
OR
there is not enough info to make a determination
(yes this is one of those stupid GRE "quantitative comparision" questions)
The solution proposed by the GRE people is to exaggerate the difference between the 91 degrees and the 89 degrees by drawing the former angle larger, requiring that the nearly-square rectangle be redrawn as a rectangle much wider than it is tall. Once this has been done, it becomes "clear" that a > b.
I am wondering whether there is a less crude way of arriving at this conclusion (one that makes use of geometric principles)
Thanks
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Aug2-07, 11:16 PM   #2
Homework Helper 2012
Recognitions:
Homework Helper Homework Help
Am I confused? If the figure is supposed to be a rectangle, then all of the triangles are isosceles. So 2a+89=180 and 2b+91=180. a>b. Am I missing something that is making this hard?
Aug3-07, 04:09 AM   #3
Recognitions:
We don't know that the angles at the corners are right angles.
Aug3-07, 08:35 AM   #4
Recognitions:
Geometry Problem
If its an arbitrary quadrilateral then a>b is not necessarily true. Start drawing non-rectangular cases.
Aug20-07, 06:22 PM   #5
Mentor
Quote by Dick View Post
No, I don't think you are missing anything. It was supposed to be a rectangle, so that's the answer. Thanks.
Thread Closed
Similar discussions for: Geometry Problem
Thread Forum Replies
Geometry problem General Math 14
a problem in geometry Introductory Physics Homework 7
Geometry problem!! General Math 5
Geometry Problem General Math 3
