What is the final speed of the box at 10m?
The problem involves a force exerted by a rope lifting a 2.0 kg mass vertically over a distance of 10 m, with a force that varies from 20 N to 30 N. The original poster seeks to determine the final speed of the box at this height.
  • The original poster expresses confusion regarding how to approach the problem due to the non-constant force and acceleration. Some participants suggest using work-energy principles and conservation of energy, while others clarify the concept of work as the area under the force-distance graph.
The discussion is ongoing, with participants exploring different interpretations of the problem and offering guidance on relevant concepts such as work and energy. There is no explicit consensus yet on the approach to take.
There is a mention of a lack of calculus in the course, which may limit the methods available for solving the problem. The original poster also notes a specific answer, which may influence the direction of the discussion.
avsj
A force is exerted by a rope lifting a 2.0kg mass a vertical distance of 10m from the ground. A graphs shows F (N) vs d (m). THe F starts at 20 N and goes to 30 N in a straight line as d goes from 0 to 10m. What is the final speed of the box at 10m?
F=ma
kinematics equations
I am thoroughly lost as to how to deal with this one. The force applied is not constant, so the acceleration will also not be constant. I'm guessing there is another way of looking at it... would really appreciate a hint in which direction to start... thanks.. the answer is 7.3m/s by the way
Work is equal to the integral over distance of force. Use conservation of energy to compare this with mgh and then use KE=mv^2/2.
what do you mean work is equal to the integral over distance of force, what is the integral?
No calculus in this course? Then if you graph force versus distance, work is the area under the curve. That's what an integral is.
  • · Replies 16 ·
