Help with reverse siphon break?
  • Thread starter Thread starter Raavin
    Break Reverse
The discussion centers around the feasibility of creating a reverse siphon system that allows a liquid to siphon into a smaller container and stop automatically when the liquid reaches the level of the tube opening, without the use of valves. The scope includes practical applications and experimental setups.
  • Experimental/applied
  • Raavin proposes a method to siphon liquid into a smaller container and stop the flow at a certain level without using valves, suggesting the use of siphoning and capillary effects.
  • Cliff suggests making the larger container air-tight to allow the siphoning effect to cease once the liquid reaches the level of the tube opening, noting that this method works with certain viscosities and container designs.
  • Raavin acknowledges the feasibility of Cliff's idea and recalls similar mechanisms used in pet water feeders, indicating a potential for experimentation.
  • Another participant mentions that while the method may work once, repeating the process could present challenges.
Participants express varying levels of confidence in the proposed methods, with some agreeing on the potential of the air-tight container approach while others highlight concerns about the practicality of repeated use.
Limitations include the dependence on the viscosity of the liquid and the specific design of the containers involved, which may affect the effectiveness of the proposed methods.
Individuals interested in fluid dynamics, experimental setups for siphoning, or those looking for innovative solutions to liquid transfer without mechanical components.
Raavin
Hey there,
Not sure if this is possible but...
I was wondering if there was a way to set something up so that one liquid would siphon into a lower container and stop when the liquid reached the level of the tube opening without using any sort of valve?
Basically I need a large volume of liquid to feed into a small volume bottle then shut off when the smaller bottle gets to a certain level. I think there may be a way to do it using either or both the siphoning effect and capillary effect.
The main point is to minimise (actually eliminate) moving parts like valves.
Any ideas?
Raavin
You could just make the larger container air-tight. Now as the liquid drains from it through the tube, it gurgules as the air goes back up the tube to make up the displacement of liquid removed. Once the liquid reaches the level of the tube opening, no more air is available to allow any more liquid to be displaced.
I have a gas can for my lawn mower that works this way. It works ok. With something of a higher viscosity and a smaller opening it would work better, like trying to get motor oil out of those plastic bottles if you tip them completely upside-down instead of pouring them into the funnel.
HTH
Cliff
To do it once, is feasable, repetitions are another story...
Mmmm, yes, that might just work. For some reason I was getting stuck on the larger container 'siphoning' the fluid out rather than taking the feed tube out of the bottom of the container. Now that I think about it, you can get pet water feeders that you attach an inverted bottle to and it feeds in water when the water gets below the level of the opening.
Nice work Cliff_J. I'll have to get experimenting.
Cheers,
Raavin :D
  • · Replies 17 ·
28K
  • · Replies 27 ·
  • · Replies 42 ·
22K
  • · Replies 28 ·
