Register to reply
Conservation of momentum vs KE
by Oerg
Tags: conservation, momentum
Share this thread:
Oerg
#1
Aug9-07, 12:41 PM
P: 364
there is this requirement in my textbook that states:
show an understanding that, whilst momentum is always coneserved in interactions between bodies, some change in kinetic energy usually takes place.
Can anyone explain to me why this is so? If the momentum of a system is conserved before and after an interaction, why is the kinetic energy not usually conserved?
2. Relevant equations
m1u1+m2u2=m2v2+m1v2
K.E.before=K.E.after
3. The attempt at a solution
Phys.Org News Partner Science news on Phys.org
Wildfires and other burns play bigger role in climate change, professor finds
SR Labs research to expose BadUSB next week in Vegas
New study advances 'DNA revolution,' tells butterflies' evolutionary history
Niles
#2
Aug9-07, 12:55 PM
P: 1,863
I think they are asking for the Q-value, when talking about particle physics; the difference between the mass of a decaying particle and the sum of masses of the daughter particles.
malawi_glenn
#3
Aug9-07, 12:59 PM
Sci Advisor
HW Helper
malawi_glenn's Avatar
P: 4,739
Total energy is conserved, the kinetic energy can be converted into another kind of energy; potential energy, heat etc.
Oerg
#4
Aug9-07, 01:02 PM
P: 364
to the second poster: Hmm maybe.. but is there another explanation not involving particle physics?
to the third poster: if kinetic energy has been converted to something else, would not the velocity of the objects be lower than that if kinetic energy is conserved? That would mean a decrease in total momentum too is it not?
malawi_glenn
#5
Aug9-07, 01:10 PM
Sci Advisor
HW Helper
P: 4,739
No... the velocity can be distributed different among the objects involved in the collision. Do you own a textbook on newtonian mechanics? I suggest you read a bit in that, or maybe google a bit.
In kinematics, you put up these two conditions:
1. Total linear momentum initial = Total linear momentum final
2. Total energy inital = total energy final
Sometimes you even have a third condtion, total Anlgular momentum, which is also conserved.
Oerg
#6
Aug9-07, 01:52 PM
P: 364
oh yes thanks for explaining that means although a typical question might ask about 2 objects in interaction, and if they say that kinetic energy is not conserved, that means that we have to include additional objects into the discussion eg. sound waves propagating in air, etc. i understand now thanks a lot. Just that I was assuming that they were only considering the 2 objects before and after and that it didnt make sense if the 2 objects were to lose kinetic energy and still have the same total momentum.
learningphysics
#7
Aug9-07, 02:19 PM
HW Helper
P: 4,124
Quote Quote by Oerg View Post
You don't have to consider additional objects. Even when only considering two objects (no other objects), kinetic energy is not necessarily conserved. Kinetic energy can be converted into heat within the two objects... or some other form of energy within the two objects.
For a closed system: Total energy is conserved and momentum is conserved.
Kinetic energy is not necessarily conserved.
malawi_glenn
#8
Aug9-07, 02:23 PM
Sci Advisor
HW Helper
P: 4,739
Also consider a person standing on the ice on skates and trowing an object. Beacause of conservation of linear momentum, the person vill move in the opposite direction of the object she/he trowed. But kinetic energy is a scalar, not a vector, so we can not speak of "kinetic energy in direction y" etc. In this situation, total energy is conserved (chemical energy stored in the persons body is transformed into mechanical energy)
Oerg
#9
Aug9-07, 09:37 PM
P: 364
Then is it true to say that in a perfectly inelastic collision, total momentum is not conserved since all kinetic energy is converted to other forms of energy? If the body possesses no kinetic energy, it wouldnt be moving and the RHS of the moementum equation would be zero compared to the LHS value unless we were to consider air particles that might rocket off during the collision.
lightgrav
#10
Aug9-07, 10:37 PM
HW Helper
lightgrav's Avatar
P: 1,117
If the (VECTOR, including direction!)
momentum after a totally INelastic collision is zero,
then the momentum sum (+/- !) before the collision must've been zero.
That is, they initially were travelling in opposite directions, and stopped.
By the way, "totally inelastic" does NOT mean "stops" ...
it means "stick together" , as in "v_1,final = v_2,final " .
You might try conserving momentum with v1=10m/s and v2=0,
(both m=2kg) to see what fraction of original KE is lost.
Then try it with v1=15m/s and v2=5m/s ... "as seen by the bumblebee"
learningphysics
#11
Aug9-07, 10:40 PM
HW Helper
P: 4,124
No that's not true.
Total momentum is always conserved in a closed system... so suppose there is a collision between two bodies... and after the collision, neither body has any momentum... the total momentum is 0... that means that the total momentum before the collision was 0 also. That doesn't necessarily mean that the particles weren't moving before the collision... for example two particles of equal mass moving with the same speed in opposite directions, together have a total momentum of 0. Remember that momentum is a vector (magnitude and direction), and it is the total momentum as a vector that is conserved.
Oerg
#12
Aug9-07, 11:03 PM
P: 364
ok i get it, thanks for all who have posted, i appreciate your help!
Register to reply
Related Discussions
Conservation of momentum vs conservation of kinetic energy Introductory Physics Homework 18
Law of the Conservation of Angular Momentum > Principle of Conservation of Momentum General Engineering 0
Simulatenous Conservation of Momentum and Conservation of Energy Engineering Systems & Design 9
Conservation of energy or conservation of momentum Introductory Physics Homework 2
Conservation of momentum (with conservation of energy) Introductory Physics Homework 1
