Register to reply
Schrodinger equation with Electric/Magnetic Potential
Share this thread:
PsiPhi
#1
Aug12-07, 07:45 AM
P: 20
Consider a particle of charge [tex]e[/tex] and mass [tex]m[/tex] in crossed [tex]E[/tex] and [tex]B[/tex] fields, given by [tex]E = (0,0, E)[/tex], [tex]B = (0,B, 0)[/tex], [tex]r = (x, y, z)[/tex].
Write the Schrodinger equation.
2. Relevant equations
Schrodinger's equation: [tex]\left[ -\frac{\hbar^{2}}{2m} \nabla^{2} + V(r,t) \right] \Psi(r,t) = i\hbar\frac{\partial}{\partial t} \Psi(r,t)[/tex]
3. The attempt at a solution
I have obtained the expressions for the electric (scalar) potential and magnetic (Vector) potential and substituted them in as the V(r,t) that appears in Schrodinger's equation. The trouble I'm having at the moment is that would V(r,t) just be a sum of electric and magnetic potential? Also, the question also mentions I should introduce a gauge to simply the equation, but I'm not sure how this gauge transformation would look like.
Thanks.
Phys.Org News Partner Science news on Phys.org
World's largest solar boat on Greek prehistoric mission
Google searches hold key to future market crashes
Mineral magic? Common mineral capable of making and breaking bonds
Gokul43201
#2
Aug12-07, 09:42 AM
Emeritus
Sci Advisor
PF Gold
Gokul43201's Avatar
P: 11,155
No, you don't add the potentials. Go back to Jackson/Griffiths' E&M: what happens to the canonical momentum of a charge in a vector potential, A? And have you heard of the Landau gauge?
dextercioby
#3
Aug12-07, 09:48 AM
Sci Advisor
HW Helper
P: 11,895
To reformulate what Gokul said, what is the hamiltonian for a nonrelativistic electrically charged massive particle in a em field. Having got that, obtaining the quantum hamiltonian is a piece of cake.
PsiPhi
#4
Aug21-07, 05:34 AM
P: 20
Hey,
Sorry I haven't replied in a few days. But, i've been flat out with other subjects. OK, back to this problem, I have found a solution to this where they used Lagrangian-Hamiltonian to formulate the solution. And it seems like they obtain a Hamiltonian of [tex]H = q\phi + \frac{1}{2m} \left[ p - qA\right]^{2}[/tex], where q is the charged particle, m is the mass, p is the momentum and A is the vector potential. I'm stepping through each of the steps since I don't want to just hand the answer in like that without understanding it. I'm sorta stuck on the derivation at part [IV-2], where they take the total time derivative of the vector potential. Can someone shed some light on why they do this? In the question specified above the E field and B field are constant, can I still consider a time varying vector potential to solve for constant crossed E and B field?
Oh the link for the derivation is at http://people.seas.harvard.edu/~jone...s3_unit_4.html
Thanks.
dextercioby
#5
Aug21-07, 03:20 PM
Sci Advisor
HW Helper
P: 11,895
Nope, time dependence is not an issue in any case. Just remember the relations between the fields and the potentials. You need the potentials, having the fields.
PsiPhi
#6
Aug23-07, 08:49 AM
P: 20
Hey,
I've got the generalised quantum Hamiltonian for the case above. Now, I want to obtain the relevant scalar/vector potentials given the E/B fields specified above. I have solved the vector potential expression, and related all the corresponding B and A components to their respected Cartesian components.
I get these 3 different equations for the components of B (x, y, z)
[tex]B_{x} = \partial_{y}A_{z} - \partial_{z}A_{y}[/tex]
[tex]B_{y} = - \left(\partial_{x}A_{z} - \partial_{z}A_{x}\right)[/tex]
[tex]B_{z} = \partial_{x}A_{y} - \partial_{y}A_{x}[/tex]
The left hand side of the above equation can be modified to read
[tex]0 = \partial_{y}A_{z} - \partial_{z}A_{y}[/tex]
[tex]B = - \left(\partial_{x}A_{z} - \partial_{z}A_{x}\right)[/tex]
[tex]0 = \partial_{x}A_{y} - \partial_{y}A_{x}[/tex]
Now the problem i'm having is, how can i recombine all these equations together to obtain a value for A, where A is the vector potential as a function of x,y,z and t (time). This is needed since the expression of the Hamiltonian needs A.
Anyone have some tips for this solution?
Gokul43201
#7
Aug23-07, 09:03 AM
Emeritus
Sci Advisor
PF Gold
Gokul43201's Avatar
P: 11,155
This is where the choice of gauge comes in. In the Landau Gauge, A has only one non-zero component, making it simpler to work with.
PsiPhi
#8
Aug24-07, 01:16 AM
P: 20
Have you got a link I could look up on where they use Landau gauge? The gauges i'm familiar with are Coulomb and Lorenz only.
thanks.
dextercioby
#9
Aug24-07, 02:43 AM
Sci Advisor
HW Helper
P: 11,895
In the Landau gauge the scalar potential [itex] \varphi [/itex] is set to 0. And the vector potential [itex] \mathbf{A} [/itex] is required to obey the Coulomb condition.
Gokul43201
#10
Aug24-07, 08:43 AM
Emeritus
Sci Advisor
PF Gold
Gokul43201's Avatar
P: 11,155
I guess it's not the Landau gauge that you want, but probably a close extension of it....sorry. I forgot about the E-field in the problem. To cut to the chase, what happens if you choose say, A = (zB,0,0)?
PsiPhi
#11
Aug25-07, 04:44 AM
P: 20
Taking the Curl of (zB, 0, 0) it returns B = (0, B, 0), which agrees with the B field specified. But also, we can take the curl of (0, 0, -xB) and this yields B = (0, B, 0). Is the zB one correct or -xB one correct or both are correct? I'm thinking it has something to do with the symmetry of the system.
However, if I do proceed with using A = (zB, 0, 0) and the scalar potential [tex]\phi = -zE [/tex]. (Note: the time partial derivative term in the expression relating E and the scalar potential is cancelled out since A isn't not dependent on time since B is constant, there [tex]E = -\nabla \phi [/tex])
Thus, the generalised time-dep. Schrodinger eq. is:
[tex]i\hbar\frac{\partial}{\partial t} \Psi\left( \vec{r}, t\right) = \left[ -\frac{\hbar^{2}}{2m}\nabla^{2} + i\hbar\frac{e}{2m} \left(\vec{A}.\vec{\nabla}+ \vec{\nabla}.\vec{A}\right) + \frac{e^{2}}{2m} \vec{A}^{2} + e\phi\right]\Psi\left( \vec{r}, t\right) [/tex]
where e is the charge of the particle, m is the mass of the particle. Using the Coulomb gauge: [tex] \vec{\nabla} . \vec{A}\right) = 0 [/tex]. Therefore, the above equation can be reduced to:
[tex]i\hbar\frac{\partial}{\partial t} \Psi\left( \vec{r}, t\right) = \left[ -\frac{\hbar^{2}}{2m}\nabla^{2} + i\hbar\frac{e}{m} \left(\vec{A}.\vec{\nabla}\right) + \frac{e^{2}}{2m} \vec{A}^{2} + e\phi\right]\Psi\left( \vec{r}, t\right) [/tex]
where [tex] \nabla. \left( \vec{A}\Psi \right) = \vec{A}. \left( \vec{\nabla}\Psi \right) + \left(\vec{\nabla} . \vec{A}\right)\Psi = A. \left(\vec{\nabla}} \Psi\right) [/tex]. (This eliminates the 2 in the denominator of e/2m of the middle term of the square brackets).
Thus, finally substituting the vector and scalar potential into the time-dep. Schrodinger equation with the Coulomb gauge applied, I obtain:
[tex]i\hbar\frac{\partial}{\partial t} \Psi\left( \vec{r}, t\right) = \left[ -\frac{\hbar^{2}}{2m}\nabla^{2} + i\hbar\frac{e}{m} \left(zB \frac{\partial}{\partial x} \right) + \frac{e^{2} z^{2} B^{2}}{2m} - eEz\right]\Psi\left( \vec{r}, t\right) [/tex]
I was wondering if the logic was correct in obtaining the final Schrodinger equation?
Thanks.
dextercioby
#12
Aug25-07, 09:05 AM
Sci Advisor
HW Helper
P: 11,895
Am i blind, or i don't see a way to eliminate that 2 in the denominator you speak about.
Gokul43201
#13
Aug25-07, 10:03 AM
Emeritus
Sci Advisor
PF Gold
Gokul43201's Avatar
P: 11,155
I think it does get eliminated. With [itex] \vec{\nabla} . \vec{A}\right) = 0 [/itex], you have [itex]\vec{A}.\vec{\nabla} \psi + \vec{\nabla}.\vec{A}\psi = 2\vec{A}.\vec{\nabla} \psi~~ [/itex] ... or am I making some mistake too?
PsiPhi
#14
Aug25-07, 11:45 PM
P: 20
Yep, you get [tex] 2 \vec{A} . \nabla [/tex]. Then this will cancel out, just wondering if my final equation seems logical? With all the steps taken into account, also how about if A was equal to A = (0, 0, -xB) which still yields B = (0, B, 0)
Gokul43201
#15
Aug26-07, 10:50 PM
Emeritus
Sci Advisor
PF Gold
Gokul43201's Avatar
P: 11,155
It looks fine to me. The choice of a different vector potential should not affect the physics (guage invariance).
PsiPhi
#16
Aug27-07, 02:31 AM
P: 20
Sweet thanks for all the help Gokul and dexter. There's a couple more parts to the overall question, i'm about to get started on these parts. If I get stuck again, I'll ask you guys.
Thanks again, for all the help.
Cheers.
PsiPhi
#17
Sep10-07, 12:35 AM
P: 20
Hello again, I was wondering if you guys could check the logic of what i've done so far for the question i'm about to propose. I'm a little stuck on how to reduce the equation further:
So here's the question: (ii) Separate variables and reduce the Schrodinger equation to a one dimensional problem.
The Schrodinger equation that was shown before can be imbedded into the time-independent case:
[tex]E \Psi\left( \vec{r}\right) = \left[ -\frac{\hbar^{2}}{2m}\nabla^{2} + i\hbar\frac{e}{m} \left(zB \frac{\partial}{\partial x} \right) + \frac{e^{2} z^{2} B^{2}}{2m} - eEz\right]\Psi\left( \vec{r}\right) [/tex]
where E on the LHS is the energy eigenvalue. For this PDE we seek solutions that are of the form
Thus, substituing this solution into the above equation and dividing it by [tex] \Psi (x, y, z) = X(x)Y(y)Z(z) [/tex] again I obtain:
[tex]E \Psi\left( \vec{r}\right) = \left[ -\frac{\hbar^{2}}{2m}\left(\frac{1}{X(x)}\frac{\partial^{2}}{\partial x^{2}} X(x) +\frac{1}{Y(y)}\frac{\partial^{2}}{\partial y^{2}} Y(y) + \frac{1}{Z(z)}\frac{\partial^{2}}{\partial z^{2}} Z(z) \right)+ i\hbar\frac{e}{m} \left(zB\frac{1}{X(x)} \frac{\partial}{\partial x}X(x) \right) + \frac{e^{2} z^{2} B^{2}}{2m} - eEz\right]\Psi\left( \vec{r}\right) [/tex]
Now the problem i'm having is that i split this up further to the individual components (i.e. x, y, z), am I allowed to disregard the terms that aren't dependent on the other components. Say for the x dependence I can eliminate the constants 3rd and 4th term in the square brackets but still keep the 2nd term since there is a partial derivative with respect to x. If i do this i get these 3 equations:
[tex]E_{x} = -\frac{\hbar^{2}}{2m} \frac{1}{X(x)} \frac{d^{2}}{d x^{2}} X(x) + i\hbar \frac{e}{m}zB\frac{1}{X(x)}\frac{d}{d x} X(x)[/tex]
[tex]E_{y} = -\frac{\hbar^{2}}{2m} \frac{1}{Y(y)} \frac{d^{2}}{d y^{2}} [/tex]
[tex]E_{z} = -\frac{\hbar^{2}}{2m} \frac{1}{Z(z)} \frac{d^{2}}{d z^{2}} Z(z) + i\hbar \frac{e}{m}zB\frac{1}{X(x)}\frac{d}{d x} X(x) + \frac{e^{2} z^{2} B^{2}}{2m} - eEz[/tex]
This doesn't look like a 1-D problem to me, I still see the partial derivative with respect x in the z-cartesian equation. Can anyone give me any hints on how to reduce this any further, or if i've gone down totally wrong pathway.
Thanks.
RooperDooper
#18
Aug20-09, 06:33 AM
P: 1
I have exactly the same problem, with the same fields. Determining the Schrödinger equation is relatively straight foreword. Now the problem is to solve the equation to determine the wavefunction \Psy. I have a hint to separate variables to reduce it to a one dimensional problem. It is straight foreword to separate out the spatial and temporal parts, but the spatial equation then looks horrible. Can anyone help?
Essentially the equation to be solved is:
a1*grad^2(\Psy(x,y,z))+a2*z*d/dx(\Psy(x,y,z))+(a3-a4*z^2+a5*z)*\Psy=0
where the an's are constants.
Register to reply
Related Discussions
Finite wire in magnetic field, determine time and electric potential Introductory Physics Homework 5
Time independent schrodinger equation: delta potential Quantum Physics 6
A question about the adding of potential in Schrodinger equation Quantum Physics 1
Question about Schrodinger equation, potential and energy Quantum Physics 39
The nature of electric magnetic radiation,it's rest mass and potential to sl General Physics 12
