Proof of Order Isomorphism Claim for Well Ordered Sets
  • Context: Graduate
  • Thread starter Thread starter dmuthuk
    Isomorphism
The discussion revolves around proving a claim about order isomorphisms between well-ordered sets. Participants explore the definitions and properties of well-ordered sets, the nature of bijective maps, and the implications of such mappings in the context of order preservation. The scope includes theoretical aspects of order theory and mathematical reasoning.
  • One participant presents a proof claiming that a map U from one well-ordered set to another is a similarity if it bijectively maps initial segments of elements.
  • Several participants question the definition and existence of the map U, suggesting that it is not clearly defined in the initial proof.
  • Concerns are raised about the assumption of surjectivity in the proof without justification.
  • Another participant proposes an alternative proof strategy involving induction to establish a bijection between well-ordered sets.
  • Some participants argue that the existence of the function U can be assumed, while others emphasize the importance of explicitly stating such assumptions in proofs.
  • References to external sources, such as Halmos's "Naive Set Theory," are made for potentially simpler proofs.
Participants express disagreement regarding the clarity and justification of the proof presented. There is no consensus on the necessity of explicitly proving the existence of the function U or the assumptions made in the initial proof.
Limitations include the lack of clarity in defining the map U and the assumptions regarding its properties. The discussion reflects varying perspectives on the necessity of establishing the existence of such mappings in the context of well-ordered sets.
dmuthuk
Hi, I am trying to prove a claim about order isomorphisms (similarity) between well ordered sets. I have an argument for it, but it seems needlessly complicated and I was wondering if anyone might have a simpler proof. Before stating the claim and my proof, I will define a few things:
1. A well ordered set is a partially ordered set for which every non-empty subset has a least element.
2. Two posets are similar if there exists a bijective map between them that preserves order in both directions. Such a map is called a similarity.
3. Let [tex]X[/tex] be a poset with order [tex]\leq_X[/tex] and let [tex]a\in X[/tex]. Then, the initial segment determined by [tex]a[/tex] is the set [tex]s(a)=\{x\in X: x\leq_X a, x\neq a\}[/tex]. (i.e. all elements strictly smaller than [tex]a[/tex])
4. If [tex]X[/tex] is a poset, and [tex]E\subset X[/tex], then a proper lower bound of [tex]E[/tex] in [tex]X[/tex] is an element which is strictly smaller than every member of [tex]E[/tex].
CLAIM:
Let [tex]X[/tex] and [tex]Y[/tex] be well ordered sets such that neither is similar to an initial segment of the other. Consider a map [tex]U:X\to Y[/tex] such that for each [tex]a\in X[/tex], [tex]U[/tex] maps the set [tex]s(a)[/tex] in [tex]X[/tex] bijectively to the set [tex]s(U(a))[/tex] in [tex]Y[/tex]. Then [tex]U[/tex] is a similarity.
My PROOF:
First, we must show that [tex]U[/tex] is indeed a bijection. Suppose [tex]a<b[/tex] for some [tex]a,b\in X[/tex]. Then, [tex]a\in s(b)[/tex] and since [tex]U(s(b))=s(U(b))[/tex], [tex]U(a)\in s(U(b))[/tex]. So, [tex]U(a)<U(b)[/tex]. Since, [tex]a[/tex] and [tex]b[/tex] can be interchanged, we conclude that [tex]U[/tex] is one-to-one. Notice that this also shows that [tex]U[/tex] preserves order in the direction [tex]X\to Y[/tex]. Now, assume that [tex]x,y\in U(X)[/tex] such that [tex]x<y[/tex]. Let [tex]x=U(a)[/tex] and [tex]y=U(b)[/tex] for some [tex]a,b\in X[/tex]. Since [tex]U[/tex] is one-to-one, [tex]U^{-1}(s(y))=s(b)[/tex]. So [tex]a\in s(b)[/tex] and we have [tex]a<b[/tex].
Assertion: [tex]U(X)=Y[/tex]. Well, if [tex]Y-U(X)[/tex] is non-empty, it has a smallest element [tex]t[/tex]. Then, for all [tex]y<t[/tex], [tex]y\in U(X)[/tex]. Suppose [tex]U(a)\in U(X)[/tex] for some [tex]a\in X[/tex]. Then, [tex]s(U(a))\subset U(X)[/tex]. If [tex]U(X)[/tex] has a proper lower bound [tex]k[/tex], then [tex]t\leq k[/tex], which means [tex]t\in s(U(a))[/tex] in particular, which contradicts the choice of [tex]t[/tex]. So, [tex]U(X)[/tex] does not have any proper lower bounds. Therefore, [tex]U(a)<t[/tex] and we conclude that [tex]U(X)=s(t)[/tex]. This, however, implies that there is a similarity between [tex]X[/tex] and an initial segment of [tex]Y[/tex] which contradicts our initial assumption about [tex]X[/tex] and [tex]Y[/tex]. So, the assertion is true, and [tex]U[/tex] is similarity.
Any help would be appreciated, thanks.
I'm not sure that I see that U is defined at all. Am I missing some obvious statement (probably via transitive induction) that allows you to state what U(a) is? I think there is, but you've not said it.You also assume surjectivity without justification at some point (penultimate sentence of the first paragraph of your proof).
The proof in my mind goes like this:
define an identification between X and Y as follows.
1. Send the smallest element of X to the smallest element of Y.
2. By induction suppose we have an bijection between s(x) and s(y) for some x,y, then identify the smallest element in X\s(x) with the smallest element in Y\s(y).
Since neither X<Y nor Y<X, this must be an order isomorphism.
Actually, all I'm showing is that given any two well ordered sets, either X<=Y or Y<=X, or if you will there is only one isomorphism class of well ordered set per order type.
The claim defines [tex]U:X\to Y[/tex] as a map with the stated properties (i.e. it bijectively maps initial segments of elements to initial segments of their images). Since [tex]a\in X[/tex], isn't [tex]U(a)[/tex] defined?
I think you might be referring to the sentence, "Since [tex]U[/tex] is one-to-one, [tex]U^{-1}(s(y))=s(b)[/tex]". Well, by definition, [tex]U[/tex] maps the set [tex]s(b)[/tex] bijectively to [tex]s(U(b))=s(y)[/tex]. So, we certainly have [tex]s(b)\subset U^{-1}(s(y))[/tex]. Injectivity of [tex]U[/tex] guarantees equality as well.
Nope, you failed to understand me, or I failed to be make myself understood.
You assert that the map U is defined to map s(a) bijectively to s(U(a)). That supposes that U(a) makes sense, which it doesn't because you failed to define U(a).
Your assumption of srujectivity is precisely the point where you take x and y in Y, and then choose a,b in X so that U(a)=x, etc. That assumes surjectivity without any justification. Not least because you have completely failed to define what U is!
I think I'm certainly missing something here:confused: I'm still not sure about what you mean by "define". The fact is that [tex]U[/tex] is any map between [tex]X[/tex] and [tex]Y[/tex] such that for each [tex]a\in X[/tex] the correspondence between [tex]s(a)\subset X[/tex] and [tex]s(U(a))\subset Y[/tex] is bijective. I mean, if [tex]a\in X[/tex], then [tex]U(a)\in Y[/tex], whatever it is. That such a map exists of course can be shown using the transfinite recursion theorem.
Actually, I have chosen the points [tex]x,y\in U(X)[/tex].
How was I supposed to know that you knew such a U exists? You didn't invoke anything to do with transfinite induction.
The point is that the transifinte induction argument makes the question completely trivial - given any two well ordered sets one is a well ordered subset of the other.
There is only one map to define (well ordered sets are isomorphic upto unique isomorphism) and I defined it in my first reply.
I now notice my mistake about the surjectivity.
Sorry about the confusion, but why is it necessary to prove the existence of the function in this problem? I know it can be constructed using transfinite recursion, but why is that imporant here? Can we not assume its existence to begin with and then prove that its a similarity. Does it matter how it was constructed? Here's my thought on this. If such a function really did not exist, then we will be beginning with a false premise and the conclusion will automatically be true. So, I wonder if my confusion was related to logic.
It looks like the comparability theorem for well ordered sets.
If you're interested in simpler proofs, you might look at Halmos (Naive Set Theory), p.73.
There he presents two fairly detailed proof sketches, one that uses transfinite recurrsion theorem
and one that doesn't.
If you want to prove something to someone else it is usually a good idea never to assume anything without explicitly stating you are assuming it. Otherwise that person has no idea if you've written something that happens to be correct purely by fluke.
Moreover, the method by which it is constructed instantly shows that the result you're claiming to be true is in fact true without any further work.
Thus, it is not only good practice to help others, but helps you answer the question.
Suppose we construct U as we know we can. There are subsets M and N in X and Y resp. Such that U maps X - M bijectively to Y - N. Let us pick the minimal M and N. Clearly, at least one must be empty, otherwise we can extend U by picking the smallest element in each and identifying them. So, wlog M is empty. That means X maps bijectively onto Y-N. If Y is empty, then this is a bijection between X and Y and if N is not empty then this identifies X with an initial segment of Y, Y-N=s(min(N)).
Hey! Actually, that's precisely the theorem (in Halmos) that I have been trying to work out the details for:smile: This statement in particular was in fact the last portion of his first proof in which he sort of left it to the reader. Thanks.
