| Thread Closed |
How long would we live without the sun |
Share Thread | Thread Tools |
| Aug21-07, 05:40 PM | #1 |
I was trying to come up with a solution to the timeline when hypothetically speaking the sun would stop shining ( or emitting radiation). Now, gravitational issues aside (the sun as a body still there), how long would it take for median temperature to drop beyond freezing point around the globe? How long would it take for the oceans to completely freeze, and how long would it take for the air to become liquid or solid?
I'm wondering if anybody did a research on this topic, I searched the internet but could not find anything about the subject. Also, as the sun burning hydrogen in its core it becomes more efficient, therefore, gets hotter (as I understand). Somewhere I saw that it increasing its output about 10% in billion years. How long would animals have left on this planet, and how would it affect us humans in.... let's say 10,000-50,000 years from now. Thank you very much |
| Aug21-07, 06:28 PM | #2 |
Mentor
The timeperiods where the sun's output varies enough to matter enough to worry about killing us is in the billions of years. And what is going to kill us is the increase in output and volume of the sun. The sun is literally going to swallow the earth.
| Aug21-07, 06:38 PM | #3 |
Assume earth is a black body radiator, calculate rate of energy loss. Multiply the latent heat of freezing water by the seven oceans.
If the sun stopped shining, animals would run out of plants within the season. A small human population might last long enough to harness fusion themselves, though it sounds like a tenuous existence. Bit pointless though, since that isn't the predicted fate for the sun; provided we can start colonies extraterrestrial colonies in the near future, we'll likely have time to find other suns. |
| Aug21-07, 06:38 PM | #4 |
I saw another notion that as the sun expands in size it would "push" the earth beyond its present orbit....
Now, back to my freezing question: What would be immediate effects of absense of sunlight and how long do you think it would be before our world would become a perfect cryogenics lab? |
| Aug21-07, 06:42 PM | #5 |
Well, the Earth would initially lose energy at the rate given by the Stefan-Boltzmann law, or something on the order of about 2.3 x 1017 watts, with some (slightly unreasonable) assumptions. This is a high estimate.
http://www.google.com/search?hl=en&s...29&btnG=Search Assuming the Earth were a solid ball of iron, it would have a heat capacity of 0.450 J/g-K. Other materials have larger heat capacities, so this is a low estimate of the heat capacity of the Earth: 7.2 x 1029 J. http://en.wikipedia.org/wiki/Heat_ca...#Heat_capacity http://www.google.com/search?hl=en&s...29&btnG=Search Solving the differential equation gives me a cooling time, from 300K down to 270K (the freezing point of water) of some five thousand years. This means almost nothing though, since it doesn't really matter when the entire Earth's volume reaches the freezing point of water; the crust would long ago have become so cold that life could not exist on it. It's not really all that calculable (there are too many heat transfer questions I cannot answer), but I'd bet the surface would be inhospitable to most life in a matter of days. Solving it down to 2.7K gives me a time of about 6 x 1017 seconds, or about 20 billion years. This is not a very accurate calculation, but the true value will certainly be in the billions of years. In other words, it won't support life for more than a couple days, but it'll be "hot," relative to the vacuum of space, for an extremely long time. - Warren |
| Aug21-07, 06:48 PM | #6 |
How much heat does earth radiate into space (as black body). Would you please specify a formula for that..
Thank you. |
| Aug21-07, 06:52 PM | #7 |
Recognitions:
Power = sigma * T^4 * 4pi R^2
Where sigma = stefan boltsman constant 5.670 ×10−8 Wm-2K-4, R is the radius of the earth ( about 6400Km) So currently about 2 x 10^17 Watts but this will decrease as the temperature drops The earth is mixture of silicon/iron so has a specific heat capacity of around 500J/kg/K, and has a mass of 6 x10^24 Kg So it has to lose 3X10^27J to drop 1 degree C |
| Aug21-07, 06:55 PM | #8 |
Moderator note: I have merged these two threads into one. Alex Nesh, please do not post the same question in more than one place.
- Warren |
| Aug21-07, 07:13 PM | #9 |
Would heat capacity of air and water play a major role in the heat "giveaway" since the earth crust acts as a good insulator from its interior and covered substantially by water. Also, would the temperature on "dark" earth resemble the temperature of unlit side of the moon? Do "airless" planets experience heat exchange from the dayside to the night side to any measurable extend?
Thank you. (sorry I have many questions) |
| Aug21-07, 07:17 PM | #10 |
Since the volume of air and water are so tiny compared to the volume of rock, it would make little difference. Besides, the dominant mode of heat loss from the surface would be radiative, not convective, so the material is irrelevant.
The surface temperature of the Earth would rapidly approach that of the surface of the unlit side of the Moon, yes. Planets without atmospheres still have heat exchange through their volume; through the rocks that make them up. This is a larger effect than that of the atmosphere. - Warren |
| Aug21-07, 07:31 PM | #11 |
The temperature of unlit side of the moon is not low enough to liquify any of the air components, correct? Now, the lowest point (of rapidly desending temperature) will reach in a matter of a few days? The presence of atmosphere on the outer planets or satellites (like Titan) makes litte difference on it's surface temps?
Thank you. (it's hard to get some anwers on myspace, you know) |
| Aug21-07, 07:36 PM | #12 |
I'm pretty sure the temperature on the unlit side of the Moon would be low enough to liquify any component gas of air, but I'd have to check on that.
The crust of the earth would cool well below the temperatures required to sustain life in only a couple of days without any sunlight, yes. (Maybe a week.) The presence of atmosphere on moons like Titan makes an enormous difference on the surface temperatures there; it just won't make too big a difference in how fast Titan would cool if there were no sunlight. Keep in mind that cooling is an exponential process; it occurs very, very quickly at first and gradually slows down. - Warren |
| Aug21-07, 07:44 PM | #13 |
.... and ambient temperature of space in solar system is 2.4K, so that's the temperature the earth would eventually reach at infinity, correct?
| Aug21-07, 07:45 PM | #14 |
2.725K. It would cool exponentially toward this forever, without reaching it. Yes.
- Warren |
| Aug21-07, 07:49 PM | #15 |
do you think the earth would change its orbit as the sun becomes red giant, or would it be engulfed by the "surface" of the sun altogether?
| Aug21-07, 07:54 PM | #16 |
I know of no mechanism that could push its orbit out. Neither radiation pressure nor the solar wind should have any meaningful effect on a body as large as the Earth.
- Warren |
| Aug21-07, 08:11 PM | #17 |
For what I understand, at the last stage of its cycle the the sun will lose almost a quater of its mass as the result of outer layer expansion, that would (in my opinion) change solar system orbits of the planets, do you think that would make sence?
| Thread Closed |
| Thread Tools | |
Similar Threads for: How long would we live without the sun
| Question about the sun and the earth long long ago. | General Astronomy | 3 | ||
| How long does a sperm live? | Medical Sciences | 9 | ||
| My first sports session in a long long time (groan) | General Discussion | 14 | ||
| How long is Ph.D qualifying exam? How long should I take for preparation? | Academic Guidance | 2 | ||
| How long does a cell live outside a living host? | Biology, Chemistry & Other Homework | 1 | ||
