| Thread Closed |
abstract algebra question |
Share Thread | Thread Tools |
| Aug24-07, 01:27 PM | #1 |
Show that {1,2,3} under multiplication modulo 4 is not a group but that {1,2,3,4} under multiplication modulo 5 is a group 2. Relevant equations a mod n=r ;a=qn + r 3. The attempt at a solution I'm going to assume when the problem says modulo 4, the problem is read as: a mod n=4 . I don't want you tutors to do the problem for me, I just want you to help me where I should start because I have no idea how set {1,2,3,4} is related to modulo 4 . I know a for modulo four is equivalent to: U(4)={1,2,3,4} I have no idea how to proved that U(4) ={1,2,3,4} is not a group under multiplication. |
| Aug24-07, 01:34 PM | #2 |
Recognitions:
In the multiplicative 'group' mod 4 {1,2,3}, calculate 2*2. Does 2 have an inverse? What prevents similar similar problems in the mod 5 group?
| Aug24-07, 01:36 PM | #3 |
Recognitions:
You take the symbols 1,2,3 and multiply them together as if they were integers (2*3=6) and then reduce the answer mod 4, so 2*3=6 which is congruent o 2 mod 4. Clearly this is not a group.
Note that what you talk about, {1,2,3.,4} NOT being a group under mult. mod 4, has no relation to the question which asks you to show that {1,2,3} with mult. mod 4 is NOT a group and that {1,2,3,4} with mult. mod 5 IS a group. |
| Aug24-07, 01:37 PM | #4 |
Recognitions:
abstract algebra questionYes, this is not 1,2,3 mod 4 so the set under the operation is not even closed |
| Aug24-07, 02:37 PM | #5 |
This is the brute force method, at will take some time.
Make a group table. Recall that for a group, each element in the group must appear only once in each row and in each column. If you see any element appearing more than once then you know the structure you have is not that of a mathematical group. There are more elegant ways to solve this, but when it comes to small finite groups, its fun to see the entire structure under the binary operation all at once. Cheers. |
| Feb26-09, 05:41 PM | #6 |
Show that {1,2,3} under multiplication modulo 4 is not a group but that {1,2,3,4} under multiplication modulo 5 is a group Alright, take, for example, Set {1,2,3,4,5} for modulo 6 and set {1,2,3,4,5,6} modulo 7. A group meets 4 basic requirements... 1. Closed 2. Associative 3. Has an identity 4. It has an inverse Looking at the first set....Prove that it is closed. To prove that this is closed, you must multiply each member in the set together one by one then divide it by the modulo (6). The remainder must be a number in the set. If not, the set is not closed. Example: 1*2=2 2/6= 0.3 r 2 The remainder (2) is in the set, repeat this 3*4=7 7/6= 1 r 1 The remainder (1) is in the set, repeat this 4*5=20 20/6= 3 r 2 (2) is in the set 2*3=6 6/6= 1 r 0 (0) is not in the set because (0) is not in the set, it is not closed and is not a group. Set #2. It is closed and can be proven by the previous step. Associative. I have been told, at this time in my studies, to assume this is associative. Indentity. I'm still trying to figure this one out, sorry.. Inverse. It's not 100% clear, but this is what I know... To find the inverse you take your starting number in the set, find another number in the set that, when multiplied together then divided by the modelo (7) has a remainder of 1. example: 1 - the inverse is 1 (I had to push the I believe button) 2 - 2*4=8 8/7= 1 r 1. Then, the inverse of 2 is 4. 3 - 3*5=15 15/7= 2 r 1. 3 is 5. 4 - above is shown 4 is 2. 5 - above is shown 5 is 3. 6 - the inverse is 6 (I believe button again) Anyway, I hope this helps. If anyone can help fill in the gaps (for my own personal benefit) I would greatly appreciate it. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: abstract algebra question
| Abstract Algebra -- isomorphism question | Calculus & Beyond Homework | 4 | ||
| abstract algebra question | Calculus & Beyond Homework | 7 | ||
| Abstract Algebra question | General Math | 2 | ||
| Another Abstract Algebra Question.... | Calculus & Beyond Homework | 1 | ||
| Abstract Algebra question? | Linear & Abstract Algebra | 13 | ||
