Is the Quotient Rule Necessary for Finding the Derivative of a Fraction?
The discussion revolves around finding the derivative of the function y=9/x+5, with participants exploring the necessity and application of the quotient rule in this context.
  • Participants discuss the use of the quotient rule versus alternative methods for differentiation. Questions arise regarding the correct interpretation of the function and the application of differentiation rules.
Some participants have provided guidance on showing work to identify errors, while others question the necessity of the quotient rule for this specific problem. There is an acknowledgment of a mistake in applying the quotient rule, and alternative approaches are suggested.
There is a mention of potential constraints regarding homework requirements that may influence the choice of differentiation method.
Ry122
Hi
Im trying to find the derivative of y=9/x+5
I tried using the quotient rule and
and the derivative of (x+5)^-1*9 but both methods don't work.
If you would show us some work, someone could point out the problem you are having.
Ry122 said:
Hi
Do you mean y=(9/x)+5 or y=9/(x+5)? From your post, I presume the latter.
As d_leet said, show us your work and we'll guide you.
its ok i found what i was doing wrong. I made a mistake with the quotient rule. i had u'v+v'u instead of u'v-v'u
By the way, I'm curious as to why you are using the quotient rule, unless it was a requirement for this problem. Normally the quotient rule is used in the following situation:
[tex]y = \frac{g(x)}{h(x)}[/tex]
In your case, g(x) is a constant and y' can be found directly. Let me ask this. How would you find y' if y = 1/x?
As a side note, I never use the quotient rule, because I can never remember how it works. I always use the product rule:
[tex]y = g(x)h(x)^{-1}[/tex]
  • · Replies 25 ·
  • · Replies 24 ·
