proved that a group is abelian
by Benzoate
Tags: abelian, proved
Benzoate
Benzoate is offline
#1
Aug29-07, 07:55 AM
P: 569
Prove that a group G is Abelian if and only if (ab)^-1 =a^-1*b^-1 for all a and b in G.
2. Relevant equations
No equations for this problem
3. The attempt at a solution
Suppose (ab)^-1 =a^-1*b^-1 . Let (ab)^-1 *e = a^-1*e *b^-1*e. The multiply (ba)^-1 on the left side of the equation and b^-1 *a^-1 on the right side of the equation.
then (ab)^-1=(ba)^-1 and a^-1 *b^-1 =b^-1 *a^-1
then ((ab)^-1 *(ba)^-1)*e= (a^1*b^-1 *e)*(b^-1*a^-1*e
therefore, by method of direct proof, (ab)^-1 =a^-1 *b^-1
Phys.Org News Partner Science news on Phys.org
Cougars' diverse diet helped them survive the Pleistocene mass extinction
Cyber risks can cause disruption on scale of 2008 crisis, study says
Mantis shrimp stronger than airplanes
matt grime
matt grime is offline
#2
Aug29-07, 08:00 AM
Sci Advisor
HW Helper
P: 9,398
I think you just showed that (ab)^-1 =a^-1*b^-1 implies (ab)^-1 =a^-1*b^-1.
At no point in the proof do you even mention what Abelian means. That is surely a warning sign, isn't it?
Benzoate
Benzoate is offline
#3
Aug29-07, 08:08 AM
P: 569
Quote Quote by matt grime View Post
Other than failing to mention that Abelian means a*b=b*a , what else is wrong with my proof
Timo
Timo is offline
#4
Aug29-07, 08:09 AM
P: 301
I'm a bit confused, too. Tip: Do the two steps necessary for showing the equivalence explicitely seperately, i.e.
1) Relation => Group is abelian
2) Group is abelian => Relation holds.
Using that [tex] \left( ab \right)^{-1} = b^{-1}a^{-1} [/tex] (make sure you understand why) that's two one-liners.
matt grime
#5
Aug29-07, 08:24 AM
Sci Advisor
HW Helper
P: 9,398
Quote Quote by Benzoate View Post
The simple fact that I can't decipher what it is that you tried to do, or what you think you did.
Timo
Timo is offline
#6
Aug29-07, 08:40 AM
P: 301
I think I managed to understand it:
- Assume the relation holds (2nd version is just a rewrite with inserted identities).
The multiply (ba)^-1 on the left side of the equation and b^-1 *a^-1 on the right side of the equation. Then (ab)^-1=(ba)^-1 and a^-1 *b^-1 =b^-1 *a^-1
- Furthermore, assume the group is abelian.
then ((ab)^-1 *(ba)^-1)*e= (a^1*b^-1 *e)*(b^-1*a^-1*e). Therefore, by method of direct proof, (ab)^-1 =a^-1 *b^-1
- Then the relation holds.
Benzoate. If I understand that correctly, then from my translation you should be able to see the problem with your proof: You only say that the two statements do not contradict each other (not even completely sure if it sais that, but let's assume it did) but don't say that they are equivalent (which is a much stronger statement). From your statement, it could as well be that the only group for which both statements are true is the trivial group (with only one element).
HallsofIvy
HallsofIvy is online now
#7
Aug29-07, 09:06 AM
Math
Emeritus
Sci Advisor
Thanks
PF Gold
P: 38,895
No, you cannot "assume the group is abelian" when you are trying to prove it is abelian!
Benzoate, it is true (and easy to prove) in any group that
(ab)-1= b-1a-1. You are given that (ab)-1= a-1b-1.
You should be able to combine those to show that ab= ba.
Benzoate
Benzoate is offline
#8
Aug29-07, 09:35 AM
P: 569
Quote Quote by Timo View Post
What if I were to supposed that (ab)^-1= b^-1 *a^-1. then I can say that if (ab)^-1 =b^-1*a^-1 , then b^-1 * a^-1 =(ba)^-1 => (ab)^-1 =(ba)^-1 also => b^-1*a^-1 =a^-1 *b^-1
Therefore , (ab)^-1 = a^-1 *b^-1
learningphysics
learningphysics is offline
#9
Aug29-07, 10:05 AM
HW Helper
P: 4,125
Benzoate, can you show how you get each step... You should show that:
(ab)^-1=a^-1*b^-1 => ab = ba
as the first proof... so start with the assumption that (ab)^-1=a^-1*b^-1, and show that this leads to ab = ba. I think you almost did this but I found it a little hard to follow.
and then for the second proof you should show that:
ab = ba => (ab)^-1=a^-1*b^-1
matt grime
#10
Aug29-07, 10:06 AM
Sci Advisor
HW Helper
P: 9,398
Why would you suppose that? It is clearly true: just compose (ab) with b^-1a^-1.
You see, I'm still lost as to what it is that you think you have proved.
Suppose G is abelian, show that this implies (ab)^{-1}= a^-1b^-1.
Now, say where you assume abelianness, and use words, like 'hence we have shown that G abelian implies....' so that people can understand what you have written and why you have written it and what you think you have shown.
Once you've done that, reverse the process, and show that (ab)^-1 = a^-1b^-1 for all a,b imples G is abelian. Again, use words, not just a string of a,b,^,-1,=,> symbols so that we follow what it is you think you're doing.
Anyone can string together abstract symbols - you should be trying to show that you understand what stringing them together does and why. Do good textbooks look like this? Do papers? No, they contain lots of words and explanations. For a reason: maths is hard to comprehend at the best of times, but next to impossible if you don't write clearly.
Register to reply
Related Discussions
Abelian group Calculus & Beyond Homework 9
Abelian Group; what to do if the set is G=R-{1/3}? Calculus & Beyond Homework 3
Abelian group where a*a=e Calculus & Beyond Homework 13
proved that a nonempty set containing rational number is a group under multiplication Calculus & Beyond Homework 12
Abelian group Introductory Physics Homework 8
