General formula for space-time distortion?
The discussion revolves around the general formulas for time distortion due to mass density and gravitational potential wells, particularly in the context of general relativity and its implications for timekeeping in varying gravitational fields. Participants explore theoretical aspects, mathematical formulations, and practical implications of these concepts.
  • One participant seeks general formulas for time distortion related to mass density and gravitational potential, citing an example involving atomic clocks and gravitational effects.
  • Another participant provides a formula based on the Schwarzschild metric, suggesting that time intervals are affected by gravitational fields, with specific calculations for clocks at different altitudes.
  • A different perspective is offered, noting that the provided formula is an approximation valid for weak fields and may not hold in extreme astronomical situations.
  • Concerns are raised about the historical context and theoretical foundations of special relativity, with one participant suggesting that Minkowski's theory is necessary to address paradoxes in special relativity.
  • Another participant challenges the historical description of relativity and expresses interest in learning more about the theoretical inconsistencies in the relativistic formula.
Participants express differing views on the validity of certain formulas and the historical context of relativity. There is no consensus on the correctness of the claims regarding the relationship between special relativity and Minkowski's theory, nor on the application of the discussed formulas in various contexts.
Some participants acknowledge the limitations of the formulas provided, particularly in extreme gravitational fields, and the need for further exploration of the underlying theories. There are unresolved questions regarding the historical development of relativity and its implications for understanding time distortion.
Cirion
Ok let me begin by saying I'm far from an expert on this subject... but I'm doing some personal research and have a question. Please answer without being TOO technical xD (I can do some calculus and somewhat advanced math but not like insanely complicated math.)
Anyways... does anyone know any general formulas for the distortion of time from a certain amount of mass density and the resulting gravity potential well? For instance I heard that in one year, two atomic clocks - with one clock being one mile above the other - results in 5 milliseconds in distortion. The gravitational potential in this case would be something like...
(2000m*10kg*9.81m/s^2) = 196200J = 5ms distortion / year. I don't even know what an atomic clock weighs or even if what I did is kosher math but that's the general idea.
So can anyone help me on how I would be able to do calculations on space-time distortions on a larger scale [ie, outer space]? Thanks
I wouldn't call it "distortion of time"..., but it is true that clocks at high altitude go faster than clocks at lower altitude (i.e., lower gravitational potential). The rate of the clock at elevation h is [itex]1 + gh/c^2[/itex] times faster than at the sea level. In the case h=2000m, this factor is about 1 + [itex]2 \cdot 10^{-13}[/itex], which translates into roughly 5us (5 microsecond) per year.
Eugene.
See for instance http://hyperphysics.phy-astr.gsu.edu/hbase/relativ/gratim.html
To rephrase it slightly
[tex]T_0 / T = \sqrt{1 - \frac{2GM}{Rc^2}}[/tex]
[tex]T_0[/itex] is the time interval on the close clock, and T is the time interval on a reference clock "at infinity". R is a measure of the location of the "near clock".<br /> <br /> This basically follows from the Schwarzschild metric. See for instance <br /> <br /> <a href="http://en.wikipedia.org/w/index.php?title=Schwarzschild_metric&oldid=151657557" target="_blank" class="link link--external" rel="nofollow ugc noopener">http://en.wikipedia.org/w/index.php?title=Schwarzschild_metric&oldid=151657557</a><br /> <br /> For weak fields, you can take R to be the distance that the clock is away from the center of the massive body. For strong fields, it's better to think of R as the Schwarzschild coordinate, which is defined by the fact that a circle of constant radius R has a circumference of 2 pi R, and a sphere of radius R has a surface area of pi R^2, as was mentioned in another thread.<br /> <br /> Note that meopemuk gives you an approximate formula. It's OK for the Earth, but if you try to apply it to an extreme enough astronomical situation, it may fail.[/tex]
The formula that I gave is an approximation of the order [itex]c^{-2}[/itex]. It can be derived from Newtonian gravity and basic quantum mechanics without any involvement of general relativity.
In QM we know that any non-stationary process (e.g., a clock) involves two or more stationary energy levels. In the simplest case, we can consider a two level system, where [itex]E_0[/itex] and [itex]E_1[/itex] are energies of the ground and excited levels respectively; [itex]m_0 = E_0/c^2[/itex] and [itex]m^1 =E_1/c^2[/itex] are their masses, and the characteristic frequency of the isolated clock is
[tex]f = \frac{2 \pi}{\hbar}(E_1 - E_0)[/tex]
Let us now consider the same clock in the Earth gravitational field. The total energies of this system in the ground and excited states, respectively, are
[tex]E_0' = Mc^2 + m_0c^2 - \frac{GMm_0}{R}[/tex]
[tex]E_1' = Mc^2 + m_1c^2 - \frac{GMm_1}{R}[/tex]
Then the clock's frequency in the gravitational field is
[tex]f' = \frac{2 \pi}{\hbar}(E_1' - E_0') = f(1 - \frac{GM}{Rc^2})[/tex]
For two clocks with the height difference of H near the Earth surface, the difference of their [itex]\frac{GM}{R}[/itex] factors can be approximated by [itex]gH[/itex], so the gravitational time dilation factor becomes [itex]1 - \frac{gH}{c^2}[/itex].
Eugene.
There are numerous paradoxes in Special Relativity, you will need to study Minkowski's
theory to be able to reconcile them all. I am not sure but I think that General Relativity
followed on from Minkowski's theory. Until these theories were developed no one could
make sense of SR, including I suspect 'the great man himself' who developed the theory.
The problem was that he could not find a 'Simple Universal' solution for every 'Relitavistic
System' occurring in space time problems. Fortunately Minkowski's theory is not too difficult
to understand, though I have not read it through myself. I am trying to find my own solution to the paradoxes invoked by SR, but it would be wise to follow my advice and do as I say,
and not as I do.
and not as I do.
This is a completely incorrect description of both the history and the physics.
Thank you for your input bcrowell, but could you please be a little more specific, I am very interested and keen to learn. I think that you may find that Special Relativity is incomplete
without Minkowskis "4 Vector Theory".
The Relativistic Formula "y=1/((1-(v^2/c^2))^1/2" seems insatisfactory to me, in so far as it
is not able to reconcile the paradoxes invoked by the basic theory.
If this formula is applied to more complex systems with 3 velocity components or more it
reveals inconsistencies in the basic theory. It is much more likely that all four of the
relativistic quantities, time dilation, lorentz contraction, momentum, and simultaniety work
together in a very specific way.
[tex] Hi How come the surface of the sphere is pi r<sup>2</sup> and not 4 pi r<sup>2</sup> ?<br /> Thanks[/tex]
Eugene.
I am trying to understand Rindler so is the g in this notation the acceleration??
Is this applicable to Rindler observers and coordinates??
Thanks
timeline101 said:
The Relativistic Formula "y=1/((1-(v^2/c^2))^1/2" seems insatisfactory to me, in so far as it is not able to reconcile the paradoxes invoked by the basic theory.
What paradoxes ?
Fortunately Minkowski's theory is not too difficult to understand, though I have not read it through myself.
How can you know it's not too difficult to understand if you haven't read it through ?
I am ... keen to learn.
Don't believe you. Why haven't you done it then ?
Mentz114 said:
What paradoxes ?
OK Mentz
Seems that whatever I say you are just simply going to contradict, however I will qualify one of my statements a little more for you; when I said that "Minkowskis 4 Vector Theory was
not too difficult to understand" by that I meant that it did not involve any advanced maths.
I had prior instruction to that effect before examining the theory in any detail.
I hope that clears up that specific point for you. You were correct to make that observation.
However if you were not aware of paradoxes in SR then it would
seem logical to me that you would never have heard of Minkowski anyhow.
As for your last point, it is both unqualified and irrelevant.
timeline101 said:
OK Mentz
This is just hand-waving. What are you talking about ? Name one of these paradoxes.
I don't think anyone ever listed them by name, the only parodox that was named was "The Twin Parodox" but i don't think that was a parodox, it was too simple and was only based
on 2 inertial frames with just 1 of those frames changing to a different frame. SR is really
only of any use in non changing inertial frames. Where non inertial i.e 'accelerated frames'
are used the system breaks down completely when there are more than 3 reference frames.
If you don't believe me try doing some thought experiments with the help of a few diagrams
im sure you will see my point. You will get contradictory results. I have also noticed that the
Lorentz Contraction cannot be used arbitrary in place of Time Dilation as is commonly thought, i can explain this to you if you wish.
Nonsense. SR is internally consistent, there aren't any paradoxes or mathematical contradictions.
Don't bother.
Don't bother.
Your problem, not mine. As one day you will find out. END OF DEBATE.
  • · Replies 30 ·
  • · Replies 58 ·
  • · Replies 95 ·
9K
  • · Replies 20 ·
  • · Replies 62 ·
  • · Replies 32 ·
  • · Replies 23 ·
