concentration/dilution problem
by Benzoate
Tags: None
Benzoate
Benzoate is offline
#1
Sep4-07, 04:21 PM
P: 569
What is [H1+] in a solution prepared by mixing the following solutions
* 21.3 mL of 6.40 M HCl
* 30.8 mL of 5.20 M HCl
* 15.8 mL of 7.50 M HCl
* 34.6 mL of water
2. Relevant equations
C(final)= C(initial) * V(initial)/V(final). I think V(final) will be the volume of H2O for all 3 concentrations
3. The attempt at a solution
C(final,1)= 7.50 M*(15.8 mL/34.6mL) = 3.42 M
C(final,2) = (5.20 M) * (21.3 mL/34.6mL) = 3.20 M
C(final,3)= 6.40 M * (30.8 mL/34.6mL)= 5.70 M
C(final,total)= 5.70 M + 3.20 M + 3.42 M = 12.32
I don't think I calculated the concentration of [H+] correctly.
Phys.Org News Partner Science news on Phys.org
Review: With Galaxy S5, Samsung proves less can be more
Making graphene in your kitchen
Study casts doubt on climate benefit of biofuels from corn residue
chemisttree
chemisttree is offline
#2
Sep4-07, 05:30 PM
Sci Advisor
HW Helper
PF Gold
chemisttree's Avatar
P: 3,725
Quote Quote by Benzoate View Post
...I think V(final) will be the volume of H2O for all 3 concentrations.
You need to correct this before you go any further. There are four liquids given in your problem. Assume no change of volume due to mixing. For example, 54 mL and 65 mL of two solutions combined will produce 119 mL of solution.
Next you need to find the number of moles of acid added from each different solution.
Express the concentration in terms of M (moles/liter).
Benzoate
Benzoate is offline
#3
Sep4-07, 06:29 PM
P: 569
Quote Quote by chemisttree View Post
so the final volume is going to be the same for all 3 concentrations?
here is my attempted solution:
C(final ,1) =C(initial, 1) * (V(initial, 1)/V(final)
C(final ,2) =C(initial, 2) * (V(initial, 2)/V(final)
C(final ,3) =C(initial, 3) * (V(initial, 1)/V(final)
C(final , total) =C(final ,1) + C(final ,2) + C(final ,3)
Benzoate
Benzoate is offline
#4
Sep4-07, 06:36 PM
P: 569
for the concentration of H2O , what do you assumed about the initial concentration of H2O ?
chemisttree
#5
Sep4-07, 11:44 PM
Sci Advisor
HW Helper
PF Gold
P: 3,725
Another way to think of it would be to find the number of moles of HCl contributed by each of the four solutions.
#moles = concentration(moles/liter) X Volume (liters)
Simply do this math for each of the solutions and sum the moles of HCl. Add the volume for each of the solutions to determine Vfinal.
Remember, you are combining all of these solutions into one final solution. With that in mind, what significance does "C(final ,3)" or "C(final ,2)" or "C(final ,1)" have? Why are you performing this calculation? It doesn't make sense.
and this,
is not correct. I have never seen any expression like this... anywhere. Think about it. If I were to take a 100 mL solution of 3.5M HCl and split it into 20, 5 mL solutions of 3.5M HCl, would recombining them give me 100 mL of (20 X 3.5M HCl)? Or would it only give me back the original 100 mL of 3.5M HCl?
atavistic
atavistic is offline
#6
Sep5-07, 09:52 AM
P: 106
Is the answer .13632g correct for part a)
Register to reply
Related Discussions
concentration problem Calculus & Beyond Homework 2
A CO2 Concentration Problem Earth 0
Dilution problem Biology, Chemistry & Other Homework 0
Dilution Problem Biology, Chemistry & Other Homework 0
another successive dilution problem Biology, Chemistry & Other Homework 2
