What is the relationship between power series and exponential functions?
The discussion revolves around the relationship between power series and exponential functions, particularly in the context of a homework problem involving limits and probability distributions. Participants are exploring the validity of certain mathematical expressions and their implications in probability theory.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants are questioning the equivalence of a power series expression to an exponential function as n approaches infinity. There is also discussion about the expected value of a random variable in relation to a probability density function.
Some participants are providing clarifications and corrections regarding the mathematical expressions used, while others are expressing confusion about the notation and limits involved. There is an ongoing exploration of the assumptions behind the expressions presented.
There are indications of missing information, such as a potential missing 'n' in the denominator of a limit expression, which participants are discussing. The context includes homework constraints that may influence the interpretations being explored.
tigigi
1. I this from my homework solution.
(1-t/s)^n = exp(-t/s)
as n goes to infinity
I don't understand. I checked the exponential power series. It should be :
exp(x) = summation (x^n / n!)
n=0 to infinity
How come it could be a exponential function ?
2. another is that why
<t> = integral from 0 to infinity (t*P(t) dt) ?
average t
P(t)dt = probability that an electron has no colission till time t *
probability that it has a collision between time t
probablitiy has no collision is exp(-t/s)
t+dt = exp(-t/s) *dt/s
Thanks a lot !
1. This is obviously wrong:
[tex]\sum_{n=0}^{\infty}(1-t/s}^n \ne \exp(-t/s)[/tex]
You don't need to expand the series. Use t/s=0.5. The series evaluates to 2, which is obviously not [itex]1/\sqrt e[/itex].
I suspect you are missing something here.
2. In general, the expected value of some random variable [itex]X[/itex] with respect to some probability density function [itex]p(t)[/itex] is defined as [itex]\int X p(t)dt[/itex], where the integration is performed over the domain of the PDF. Here, you want the expected value of the time until a collision for an exponentially distributed collision time. BTW, the PDF is [itex]p(t)=\exp(-t/s)/s[/tex], not [itex]\exp(-t/s)[/itex].[/itex]
oops, I should make the notation more clear.
the ans says that
( 1- dt/s )^n = exp ( -t/s ) as n goes to infinity
there's no summation here.
I'm wondering where this comes from ?
This is still not right. This is:
[tex]\exp\left(-\;\frac t s\right) \equiv \lim_{n\to\infty} \left(1-\frac 1 n\;\frac t s\right)^n[/tex]
It's not a matter of "more clear"- you didn't say anything about a limit before!
Oh, and now you have "dt/s" where before you had "t/s". Was that a typo?
Of course, for fixed t and s, 1- t/s is just a number. If that number is larger than 1, the limit is [itex]\infty[/itex], if that number is less than 1, the limit is 0, if that number is equal to 1, the limit is 1. It certainly is not "e-t/s".
It is true that [itex]\lim_{n\rightarrow \infty} (1+ \frac{x}{n})^n= e^{x}[/itex]
Replacing x by -t/s, we get
[tex]\lim_{n\rightarrow \infty} (1- \frac{x}{ns})^n= e^{-t/s}[/tex]
Is it possible that you are missing an "n" in the denominator?
I got it. Thanks a lot ! :)
yes, I think so. There's an n missing in the denominator.
hye D H...i need ur help...do check your private inbox...plssss...
  • · Replies 68 ·
