| Thread Closed |
Force of child on a swing |
Share Thread |
| Sep8-07, 07:14 PM | #1 |
An inventive child wants to reach an apple in a tree without climbing the tree. Sitting in a chair connected to a rope that passes over a frictionless pulley (Fig. P4.79), the child pulls on the loose end of the rope with such a force that the spring scale reads 350 N. The child's true weight is 310 N, and the chair weighs 160 N. (a) Show that the acceleration of the child-chair system is upward and find its magnitude. (b) Find the force the child exerts on the seat of the chair. 2. Relevant equations F=ma 3. The attempt at a solution I solved for Part A and got it correct by going: 700-470=47.96a a=230/47.96 a=4.7956 which I rounded to 4.8 m/s^2 I'm having trouble with Part B. Here is the work I did so far: 310-350=-40 -40+160=120 N 350-120 N = 230 N However, this is wrong and I'm not sure where I went wrong. If someone could help me, I'd be very thankful. |
| Sep8-07, 07:34 PM | #2 |
Recognitions:
For part b, what are the forces acting on the chair? You should have 3 forces. Use net force = ma, for the chair alone... you know a = 4.8m/s^2
| Sep8-07, 07:34 PM | #3 |
Admin
I assume the spring scale is connected to the rope?
B. The chair is being accelerated under the child, so the mass of the child experiences the acceleration of gravity and the acceleration of the chair. So the weight of the child must include both accelerations. Meanwhile the child is pulling on the rope, with a force of 350 N, which you did correctly. |
| Sep8-07, 07:46 PM | #4 |
I assume the three forces are 700 N (tension in string), 310 N (child's weight), and 160 N (weight of the chair).
So, I set it up like this F=ma 700 N - 160 N - 310 N = (160/9.8) x 4.80 which gives me 230 N = 78.384 I'm really confused about what I should do at this point. |
| Sep8-07, 07:55 PM | #5 |
Recognitions:
The trick to these force problems is not to assume anything. Go with only what you know for sure. What are the forces exerted on the chair? The rope is connected to the chair. It exerts a 350N force on the chair (I'm assuming one end is connected to the chair, and the girl holds the other end right?). Gravity exerts a force of 160N on the chair. And the girl exerts a force whose magnitude you need to find out. Don't assume it's the weight of the girl... you don't know that. so F = ma 350N - 160N - Fgirl = ma solve for Fgirl |
| Sep8-07, 07:59 PM | #6 |
Recognitions:
Always draw a freebody diagram of the body being analyzed. In this case, the chair.
| Sep8-07, 08:05 PM | #7 |
OK
I set it up like this: 700 N - 160 N - Fgirl=(160/9.8) x .4.80 540 N = 78.367 + Fgirl Fgirl=462 N This is still wrong though, so maybe I should be using 350 as my tension force instead of the 700 I used in the previous part of the question?? |
| Sep8-07, 08:06 PM | #8 |
Recognitions:
Sorry, I should have pointed it out.
| Sep8-07, 08:08 PM | #9 |
Hey, for part a
can anyone explain why it's 2(350)-W=Net force? I draw FBD, and got like this Fchild - T = Fnet T-W = Fnet |
| Sep8-07, 08:11 PM | #10 |
Ok, so now I set it up this way:
350 N - 160 N -Fgirl=(160/9.8) x 4.80 m/s^s and when I solved for Fgirl I got 111.6327 Webassign says this is wrong still so I must still be doing something wrong. |
| Sep8-07, 08:17 PM | #11 |
Recognitions:
| Sep8-07, 08:18 PM | #12 |
Recognitions:
| Sep8-07, 08:21 PM | #13 |
I got it, it was supposed to be carried out to 111.63 but I had rounded to 112.
| Sep8-07, 08:22 PM | #14 |
Recognitions:
| Thread Closed |
Similar discussions for: Force of child on a swing
| [SOLVED] 400N child on swing | Introductory Physics Homework | 12 | ||
| father pushing child on swing problem | Introductory Physics Homework | 3 | ||
| Estimating the force of a baseball swing | Introductory Physics Homework | 4 | ||
| Force of a Baseball Swing | Introductory Physics Homework | 11 | ||
| What is Swing State? | Current Events | 2 | ||
