Finding length of tube, air column, standing waves
The discussion centers on calculating the length of an open-closed tube required to match the fundamental frequency of a vibrating wire. Given a 50-cm-long wire with a mass of 1.0 g and a tension of 440 N, the speed of sound is specified as 340 m/s. The fundamental frequency equation, ½L √(T/µ) = f, is utilized to derive the tube length, which must correspond to a quarter wavelength for the fundamental frequency in a closed tube. The correct tube length is determined to be 0.425 m or 42.5 cm.
  • Understanding of wave mechanics, specifically standing waves.
  • Familiarity with the fundamental frequency equation for vibrating strings.
  • Knowledge of the relationship between wavelength and tube length in closed-end tubes.
  • Basic proficiency in manipulating equations involving tension, mass, and frequency.
  • Study the relationship between wavelength and frequency in closed tubes.
  • Learn about the calculation of linear density (µ) for strings and its impact on frequency.
  • Explore the effects of tension on the frequency of vibrating strings.
  • Investigate the harmonic series in open-closed tubes and their corresponding wavelengths.
Students in physics, particularly those studying wave mechanics, acoustics, and sound wave behavior in tubes. This discussion is beneficial for anyone tackling problems related to standing waves and resonance in closed systems.
aliaze1
A 50-cm-long wire with a mass of 1.0 g and a tension of 440 N passes across the open end of an open-closed tube of air. The wire, which is fixed at both ends, is bowed at the center so as to vibrate at its fundamental frequency and generate a sound wave. Then the tube length is adjusted until the fundamental frequency of the tube is heard. What is the length of the tube?
Speed of sound is 340 m/s
½L √(T/µ) = f
Vsound = 340 m/s
I keep getting 0.362m or 36.2 cm but it is incorrect..any help?
Show your work step by step.
Hint: For a tube closed at one end, how does length relate to the wavelength for the fundamental frequency?
