How to Convert Notation for Differentiating Functions?
The discussion revolves around differentiating a function expressed in fractional notation, specifically y=2/x^2 -1/x^3 +1/2^3. Participants are exploring how to convert this notation into a form that is more compatible with differentiation techniques.
  • Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the use of negative indices to represent fractions, questioning how to transition from their notation to a more standard form. There are attempts to clarify the rules regarding negative exponents and their implications for differentiation.
Some participants have suggested rewriting the function with negative exponents to simplify differentiation. Others have noted the importance of using the power rule or the quotient rule, indicating a productive exploration of methods without reaching a consensus on the best approach.
There is a mention of algebraic rules related to negative exponents, but the specific rules are not fully resolved within the discussion. Participants are also navigating the constraints of their textbook's notation versus their own understanding.
fitz_calc
differentiate the given function: y=2/x^2 -1/x^3 +1/2^3
2(-2x^3) -1(-3x^4)
-4x^3 + 3x^4
my book says the answer is:
how do you go from my notation to the one my book uses?
I think instead of positive indices, you should have negative indices, then the step is obvious.
yes it's not x^2 it's x^(-2) and the same with x^3 should be x^(-3) since it's a fraction.
ahh I used the power incorrectly, yes the exponents should both be negative. i know there is some algebra rule that states if your exponent is negative then put the x value and exponent in the denominator -- what rule is this?
*here's another example:
y+1/3sqrt(x)
i get: -1/3(x^4/3)
Book:
why does the x^4/3 get put in the denominator?
y+1/3sqrt(x)
i get: -1/3(x^4/3)
Book:
can you re-type that please.
y+?
[tex]\frac{1}{a^n}=a^{-n}[/tex]
[tex]\frac{a^{-n}}{b^{-m}}=\frac{b^{m}}{a^{n}}[/tex]
If you follow what rocophysics laid out for you, and rewrite your original function before attempting to take the derivative, then you'll simply need to use the power rule for finding the derivative.
If you want to leave those x's in the denominator and not use the power rule, then you'll have to use the quotient rule instead (which you'll probably learn very soon.) In this case though, the power rule requires much less thought.
cool, thanks!
  • · Replies 25 ·
  • · Replies 24 ·
