Is Every Point Mapped to Itself in a Continuous Function on ℝ²?
  • Thread starter Thread starter ELESSAR TELKONT
    Continuity Function
The discussion revolves around a continuous function f mapping from ℝ² to ℝ², specifically focusing on the property that f(q) = q for all rational points q in ℝ². The original poster seeks to prove that this property extends to all points in ℝ², questioning how to link the continuity of the function with the approximation of real numbers by rational numbers.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the implications of continuity and the approximation of real numbers by rational sequences. Questions arise regarding the mapping of irrational numbers and how this relates to the proof of the identity property across all real numbers.
Some participants have suggested exploring the epsilon-delta definition of continuity to establish a contradiction if the original claim is assumed false. There is an acknowledgment of the need to make the approximation process precise, with various interpretations being explored without reaching a consensus.
There is a mention of the original poster's uncertainty about linking the properties of the function to the proof, as well as a note on the potential difficulty due to the poster's self-identified lack of recent practice in mathematics.
ELESSAR TELKONT
My problem is this. Let [tex]f:\mathbb{R}^{2}\longrightarrow \mathbb{R}^{2}[/tex] be a continuous function that satifies that [tex]\forall q\in\mathbb{Q}\times\mathbb{Q}[/tex] we have [tex]f(q)=q[/tex]. Proof that [tex]\forall x\in\mathbb{R}^{2}[/tex] we have [tex]f(x)=x[/tex].
I have worked out that because it is continuous, [tex]f[/tex] satisfies that
[tex]\forall \epsilon>0\exists\delta>0\mid \forall x\in B_{\delta}(a)\longleftrightarrow f(x)\in B_{\epsilon}(f(a))[/tex]
and then [tex]\forall q\in\mathbb{Q}\times\mathbb{Q}[/tex] we have
[tex]\forall \epsilon>0\exists\delta>0\mid \forall x\in B_{\delta}(q)\longleftrightarrow f(x)\in B_{\epsilon}(q)[/tex]
therefore we have to proof that [tex]\forall x'\in\mathbb{R}^{2}[/tex] we have
[tex]\forall \epsilon>0\exists\delta>0\mid \forall x\in B_{\delta}(x')\longleftrightarrow f(x)\in B_{\epsilon}(x')[/tex].
It's obvious that every element of [tex]\mathbb{R}^{2}[/tex] could be approximated by some element of [tex]\mathbb{Q}\times\mathbb{Q}[/tex] or sequence in this. But, how I can link this in an expression to get what I have to proof?
I'm not so sure about this but do we not know how the function maps irrational numbers, such as sqrt(2)?
TimNguyen, in fact we know (they are mapped to themselves, as f is the identity map) but this is exactly what Elessar Telkont wants to show.
Indeed you got the idea right: any real number can be approximated by a sequence of rational numbers (and therefore, pairs of reals can be approximated by pairs of rationals).
What I would do is: Try to make this process of approximation precise (describe it in terms of epsilon-delta). Now assume what you want to prove is not true, then this should give a contradiction with the continuity (which you have also written out in epsilon-delta).
I will take a look and post it more precisely later on (first, you give it a try yourself)
Hmm, it was much easier.
It is a familiar fact (or otherwise you should be able to easily prove it from the definition) that for continuous functions f, it holds that [tex]\lim_{n \to \infty} f(x_n) = f(\lim_{n \to \infty} x_n)[/tex] for a sequence [tex](x_n)_{n \in \mathbb{N}}[/tex].
So describe a real pair x as the (coordinate-wise) limit of a sequence [itex]x_n[/itex] of rational pairs, then
[tex]f(x) = f(\lim_{n \to \infty} x_n) \stackrel{*}{=} \lim_{n \to \infty} f(x_n) = \lim_{n \to \infty} x_n = x,[/tex]
where the identity marked with a star holds by the continuity of f -- QED.
[edit]For completeness, let me prove the claim about the limits (it's a nice exercise in epsilon-delta proofs, so you might want to try it yourself first):
Let [itex]\epsilon > 0[/itex]. Since f is continuous, there is some [itex]\delta[/itex] such that [itex]|| x - x_n || < \delta[/itex] implies that [itex]|| f(x_n) - f(x) || < \epsilon[/itex].
Now [itex]x_n[/itex] converging to x means that for this [itex]\delta[/itex] I can find an [itex]N[/itex] such that [itex]|| x_n - x || < \delta[/itex] as long as [itex]n > N[/itex].
So, through the [itex]\delta[/itex] from the definition of continuity, I have found an [itex]N[/itex] for my [itex]\epsilon[/itex] such that [itex]n > N[/itex] implies [itex]|| f(x_n) - f(x) || < \epsilon[/itex], in other words,
[tex]\lim_{n \to \infty} f(x_n) = f(x) = f( \lim_{n \to \infty} x )[/tex].
Sorry about that. My math is extremely rusty since I started graduate school in physics.
  • · Replies 58 ·
  • · Replies 17 ·
