Register to reply
Velocity and acceleration of two objects
by strigner
Tags: acceleration, objects, velocity
Share this thread:
strigner
#1
Sep15-07, 12:03 AM
P: 9
A car is travelling on cruise control at velocity v1. Ahead on the road, a distance x away, a truck is travelling at a slower constant velocity v2. What is the maximum constant acceleration the car needs to avoid hitting the truck?
2. Relevant equations
3. The attempt at a solution
The only thing I could think of solving was the time when they would collide. So I wrote like this:
v2*t + x = v1*t
x = t(v1 - v2)
t= x/(v1-v2)
I'm not sure if this is the right way to start the problem and if it is I don't know where I can go with this.
Phys.Org News Partner Science news on Phys.org
Climate change increases risk of crop slowdown in next 20 years
Researcher part of team studying ways to better predict intensity of hurricanes
New molecule puts scientists a step closer to understanding hydrogen storage
bob1182006
#2
Sep15-07, 12:52 AM
P: 492
there is one equation you are missing,
[tex]V_x^2=V_{0x}^2+2a_x\triangle x[/tex]
you can derive it from the equation of the position of a particle:
[tex]\triangle x = v_{0x}t+1/2at^2[/tex]
and the velocity of a particle
[tex]V=V_{0x}+at[/tex]
Solve the velocity equation for t, plug it into the equation for the position of a particle and you get that equation.
Back to the problem:
right now say neither car/truck accelerated/decelerated, will they hit each other?
try and determine some relationship between v1 and v2, what words does the problem use that gives you some relationship between v1 and v2?
The car will be going from velocity v1 to what? what velocity will it need at least to not hit the truck?
Once you have that use the equation to determine the acceleration that will be needed for the car. and be sure to make sure you have the sign right, will the car accelerate? or decelerate?
Register to reply
Related Discussions
Velocity of 2 objects Introductory Physics Homework 4
Velocity of 2 objects Introductory Physics Homework 6
How to find the acceleration of 2 objects under same force Introductory Physics Homework 4
Why objects with different mass fall with same velocity? Special & General Relativity 11
Acceleration and Moving Objects Introductory Physics Homework 2
