Calculate Velocity: Sandbag Position 1.25s After Release
  • Thread starter Thread starter Heat
    Velocity
The discussion revolves around a physics problem involving a sandbag released from a hot-air balloon. The balloon rises at a constant velocity, and the problem requires calculating the position of the sandbag after a specific time following its release. The context includes concepts of free fall, initial height, and the effects of gravity on the sandbag's motion.
  • Mixed
  • Participants explore the initial conditions of the problem, particularly the initial height of the sandbag and the correct application of kinematic equations. There are discussions about the values used for initial velocity and acceleration, as well as the interpretation of displacement over time.
Several participants have provided calculations and expressed confusion regarding the initial conditions and the application of formulas. Some have offered alternative interpretations of the initial height and velocity, while others have questioned the assumptions made in the calculations. There is an ongoing exploration of the correct approach to determine the sandbag's position and velocity after its release.
Participants are addressing potential errors in calculations, particularly concerning the initial height of the sandbag and the use of significant figures. There is also mention of previous problems that may influence current reasoning.
Heat
A hot-air balloonist, rising vertically with a constant velocity of magnitude v = 5.00 m/s, releases a sandbag at an instant when the balloon is a height h = 40.0 m above the ground After it is released, the sandbag is in free fall. For the questions that follow, take the origin of the coordinate system used for measuring displacements to be at the ground, and upward displacements to be positive.
Compute the position of the sandbag at a time 1.25 s after its release.
Velocity = Initial Velocity + Acceleration(Time)
or
From the problem I have been able to obtain the following values for the equation.
a = -9.8m/s^2
V initial = 0 m/s
X initial = 40m
time = 1.25s
so plugging these values in =
Vx = 0 + (-9.8)(1.25)
Vx = -12.25 m/s
Can anyone help me determine where I am making my mistake, or if it's all wrong. :(
how can x initial be 40m it states that the "height h = 40m"?
isn't that when x is released at 40m.
so x initial = 0? and x final = 40?
also for a prior problem,
I did use x initial as 40, but time in earlier problem was .165s
so I did x-40.0 = 0 + .5(-.98)(.165)^2
and got 39.8666. ?? Which was right according to solution.
well you're using the equation
[tex]x=x_{0}+v_{0x}t+\frac{1}{2}a_{x}t^{2}[/tex]
you need to replace the x's with y's so there is no confusion
[tex]y=y_{0}+v_{0y}t+\frac{1}{2}gt^{2}[/tex]
also, you don't want to assume that it hit the ground, it could still be in free fall. you can calculate when it does hit the ground though by finding when [tex]v_{y}=0[/tex]
ok so it would be
y= 0 + 5m/s) + .5(-9.8)(1.25s)
= -71.56
how can y be (-)?
what is y initial? and what is your equation supposed to be?
what kind of calculator are you using? i just calculated what you gave me and i got nothing close to that.
"how can x initial be 40m it states that the "height h = 40m"?"
I believe there was a misunderstanding before, as I was already considering y initial is 40m.
y = 40 + 5(1.25)+.5(-9.8)(1.25)^2
= 38.69375
= 38.69375
yes that's what i got, is that correct?
yes :biggrin:
Thank you.
a quickie, to determine velocity at .165
it would be Vy = V initial + at
= V = 5 + (-9.8)(.165)
the velocity at .165 seconds would be 3.383
does this sound correct?
yes that is what i would do, so if it's wrong we're both wrong :D
but [tex]v_{y}=v_{0y}+gt[/tex] is the formula that would give you [tex]v_{y}[/tex] is quickest.
thank you again, I managed to get that correct , so that means we are both right :)
yes! victory :)
another one, this time it tells me to recheck my calculations of sig figs
I need to find : How many seconds after its release will the bag strike the ground?
y-y initial = vinitiaal (time) + .5(g)(t^2)
I got:
-4.9x^2 + 5x + 45 = 0
I did quadratic formula and got
(-5 +- 30.11644069) / (-9.8)
t= -2.562 and t= 3.583
I choose positive time, and says to recheck my calculation or rounding errors sig figs. This only appears when answer is really near.
i would say t = 3.60 s since all your other values have at least 3 sigs
Incorrect. :(
I have one more try.
These are the answer I placed.
3.6 ...the program evaluated it as 3.60
3.58 ...the program evaluated it as 3.58
3.583310275 ...the program evaluated it as 3.58
but is the work correct, I tried going over and over, but I get the same number.:cry:
I got:
you put in your initial height as 45.0m, it should be 40.0m
I got:
Velocity Initial (hereafter called Vi) = -5.00m/s
Acceleration (hereafter called a)= 9.81m/s^2
Time (hereafter called t)= 1.25s
Displacement (hereafter called s)= x
s=Vi*t + 1/2*a*t^2
x=(-5)(1.25)+(1/2)(9.81)(1.25^2)
x=(-6.25)+7.66
x=1.41
Therefore s=1.41.
In 1.25 seconds after being dropped, the body undergoes a displacement of 1.41m meaning that it is 38.59m above the ground.
well you're substracting from your initial position, but why not go ahead and just compute it all together?
well that 45 was the mistake, once I replaced it with 40 it was all good to go. :) thanks to all of you.
the last part, I seem to be close to, but I believe I'm doing it the wrong way.
Question asks: What is the greatest height above the ground that the sandbag reaches?I would logically think that the greatest height above the ground that it reaches is 40m, as that's when it gets released.
The feedback I got this incorrect answer is to recheck calculation, or that I may have made rounding errors or sig figs..
and if I do it algebraically: it would look something like this ::
vx = vo + at
40.0 + (-9.8) (0)
= 40.0
  • · Replies 30 ·
13K
