Integral Ques: Show $\int_0^{\infty} x^4 \exp{-x^2} dx = \frac{3\sqrt{\pi}}{8}$
  • Thread starter Thread starter John O' Meara
    Integral
The discussion revolves around evaluating the integral $\int_0^{\infty} x^4 \exp{-x^2} dx$ and demonstrating its equivalence to $\frac{3\sqrt{\pi}}{8}$. The context includes references to kinetic theory and the relationship between the integral and root mean square velocity.
  • Participants discuss integration by parts as a method to evaluate the integral, with some questioning the appropriateness of using the given definite integral of $\int_{0}^{\infty} e^{-x^{2}}$ in their calculations. Others suggest rewriting the integral in terms of a product of functions to facilitate integration.
There is an ongoing exploration of different approaches to evaluate the integral, with participants providing hints and corrections to each other's reasoning. Some participants express confusion about the application of integration by parts and the need for an anti-derivative, while others attempt to clarify these points.
Participants note the importance of correctly applying integration techniques and the potential for missing factors in their calculations. There is also mention of specific constants related to kinetic theory, which may influence the integral's evaluation.
John O' Meara
Given that [tex]\int_{0}^{\infty} \exp{-x^2}dx =\frac{\sqrt{\pi}}{2} \\ \ \mbox{ show that } \ \int_0^{\infty} x^4 \exp{-x^2} dx= \frac{3\sqrt{\pi}}{8} \\[/tex]. From the kinetic Theory the root mean square velocity of the molecules [tex](\overline{v^2})^{\frac{1}{2}}[/tex] is the square root of the integral [tex]4\pi \frac{m}{2\pi kT} \int_0 ^{\infty} \exp{\frac{-mv^2}{2kT}}v^4 dv, where k is Boltzmann constant. T is the absolute temperature, m the mass of each molecule and v the speed of any molecule. Using the substitution [tex]x^2=\frac{mv^2}{2kT} \\ \ \mbox{ show that (\overline{v^2})^\frac{1}{2} = (\frac{3kT}{m})^\frac{1}{2} \\[/tex] Using integration by parts I get the following:<br /> [tex]\int x^4\exp{-x^2}dx =\lim_{x\rightarrow \infty} x^4|\frac{\sqrt{\pi}}{2} - \lim_{X\rightarrow \infty}\int 4x^3 dx \\ \ \mbox{ which does not give} \ 3\frac{\sqrt{\pi}}{8}[/tex]. Any help would be welcome.<br /> <h2>Homework Statement </h2><br /> <h2>Homework Equations</h2><br /> <h2>The Attempt at a Solution</h2>[/tex]
The missing integral is: [tex]4 \pi \frac{m}{2 \pi kT} \int_{0}^{\infty} \exp{\frac{-mv^2}{2kT}}v^4 dv[/tex]
NO, NO, NO!
You are given that the definite integral:
[tex]\int_{0}^{\infty}e^{-x^{2}}=\frac{\sqrt{\pi}}{2}[/tex]
When you do integration by parts, you need to find AN ANTI-DERIVATIVE of the integrand that you are to evaluate between the two limits.
The anti-derivative (a function!)[tex]\int{e}^{-x^{2}}dx[/tex] is NOT equal to the value of the definite integral you were given!
Thus, you must proceed differently:
Let us rewrite:
[tex]\int_{0}^{\infty}x^{4}e^{-x^{2}}dx=\frac{1}{2}\int_{0}^{\infty}x^{3}(2xe^{-x^{2}})dx[/tex]
Now, set:
[tex]u(x)=x^{3}, \frac{dv}{dx}=2xe^{-x^{2}}[/tex]
See if you can use this hint properly..
Thanks for the reply.
[tex]\mbox{ Let } \ v=\int2x\exp{-x^2}dx \ \mbox{ therefore } \ v=-\int\exp{u}du = -\exp{u}du \ \mbox{ but } u=-x^2 \ \mbox{therefore } \ v=-\exp{-x^2} \\[/tex]
For the second part [tex]x=v(\frac{m}{2kT})^{\frac{1}{2}} \ \mbox{ therefore } \ dv=dx(\frac{2kT}{m})^{\frac{1}{2}} \ \mbox{ and also therefore } \ v^3=x^3(\frac{2kT}{m})^{\frac{3}{2}} \\ \mbox{ and } v=\sqrt{\frac{2kT}{m}}[/tex].The result I get then is [tex]\frac{1}{2}(\frac{1}{2})^{\frac{3}{2}}\frac{3kT}{m}\\[/tex] which is out by the constant factor [tex]\frac{1}{2}(\frac{1}{2})^{\frac{3}{2}}\\[/tex].Thanks for the help.
Actually the missing integral is [tex]4\pi(\frac{m}{2\pi kT})^{\frac{3}{2}}\int \mbox{ e.t.c.}[/tex]
  • · Replies 105 ·
13K
  • · Replies 47 ·
  • · Replies 34 ·
