Find Average Velocity of X & Y Components
The discussion revolves around calculating the average velocity components in the x and y directions for a scenario involving a squirrel's movement, with specific coordinates provided at two different times.
  • Participants discuss the calculation of average velocity components using the formula for velocity, with initial attempts leading to confusion regarding the correct coordinates for x and y components.
Participants are actively engaging in the problem, correcting each other's mistakes, and exploring the calculation of direction for the average velocity. There is a focus on ensuring the answers adhere to the requirement of significant figures, and some guidance has been offered regarding the use of calculators.
There is mention of the need to express answers in two significant figures, and confusion arises regarding the use of radians versus degrees in the calculations.
Heat
A http://www.maniacworld.com/squirrel-obstacle-course.html has x- and y-coordinates ( 1.2 m, 3.9 m) at time t1=0 and coordinates ( 5.5 m, -0.60 m) at time t2 = 3.1 s.
For this time interval, find the x & y component of the average velocity.
Express your answer using two significant figures.
This is what I did
First I drew how I would imagine it would look like.
Then I decided xf-xi / tf-ti = vax
-.60 - 1.2 /3.1 = -1.8/3.1 = -.580
This is what I did
but -0.60 is y2, not x2...
ok
my mistake (obviously) :P
5.5 - 1.2 /3.1 = 4.3/3.1 = 1.38
Yeah, that looks right. Do the same for vy. The question asks for 2 significant figures though...
Ok I did the other questions regarding this crazy squirrel,
but this question got me
Find the direction of the average velocity. below the x axis.
I graphed it.
x com = 1.4
y com = -1.5
arc tan of (-1.5/1.4) = -.82
why is this wrong.?
Is that in radians? Does the question ask for degrees or radians?
Although the first parts asked for the answer in 2 significant figures... you should keep more decimal places for the next calculations...
ie: use arctan( -1.4516/1.387)
since it still says use two sigs
I did what you mentioned above and I got
-.8081519332
so I rounded to
-.81
still wrong.
and yes in degrees
-.8081519332
so I rounded to
-.81
still wrong.
and yes in degrees
But -0.81 is in the answer in radians... do you have the calculator set up for degrees? What is the anwer in degrees?
haha, I guess that is what I get for using my graphing calc, I forgot the last time I used it I set it up for radians. Thank you for your explation. :)
  • · Replies 25 ·
  • · Replies 33 ·
