Thread Closed
adjoint representation
Share Thread Thread Tools
Sep16-07, 04:03 PM   #1
Why has the adjoint representation a higher dimension than the basis matrices it acts on? for example here
Why is e_1 two dim and ad(e_1) four dim?
Isn't ad(X) Y a simple matrix multiplication here? But then multiplying 4x4 with 2x2 matrices, what does it mean?
thanks
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Sep16-07, 04:16 PM   #2
Think carefully. The elements of a Lie algebra are vectors. The given example happens to be gl(2), which allows those vectors to be interpreted as matrices, but the dimensionality of gl(2) is actually 4.
Sep16-07, 04:43 PM   #3
Hahh!
thanks genneth
Sep17-07, 02:04 AM   #4
Wait, still don't get it.
what the heck is, for example ad(e_1) x e_2?
How can we multiply 4 x 4 with 2 x 2 matrices?
And ae_1 + be_2 + ce_3 + de_4 is a 2x2 matrix right?
Sep17-07, 02:08 AM   #5
You need to hold two views of the algebra in your head -- and it's only for this example. gl(n) are nxn matrices. But they also form a vector space, of dimension n^2. Linear operators on that vector space are NOT matrices of nxn -- they would be (n^2)x(n^2). Thus, the adjoint representation are matrices of (n^2)x(n^2), acting on a n^2 dimensional vector space.
Sep17-07, 02:20 AM   #6
Recognitions:
Homework Helper Homework Help
This is the problem when people think too much in terms of bases. You are not mutlitpying a 4x4 matrix by a 2x2. You are letting a lie algebra acts as endomorphisms on a vector space. Think of reps, as as maps from gxV to V, in this case we send the pair (g,v) to [gv]. Things in the left slot are elements of g, and things in the right slot are elements of some vector space, which just happens to be g again in this case.
Sep17-07, 05:06 AM   #7
thanks again
but, how do I compute the adjoint representation in some basis (like basis given in example)?
Why is my vec space n^2?
Sep17-07, 05:38 AM   #8
Like I said, the elements of gl(n) are nxn matrices, which form a vector space. How many independent vectors can you find in it?
Sep17-07, 12:37 PM   #9
Recognitions:
Since you didn't state what your basis was, we can't tell you. But the very definition of the adjoint rep is that
ad(x).y=[xy]
Now, what is there left to discuss?
Sep17-07, 02:14 PM   #10
Here they give a basis for gl(2) from which they compute an adjoint representation. I can't see how they do it, how they go from 2x2 to 4x4 matrices.
Sep17-07, 02:43 PM   #11
You seem very fixated on the 2x2 matrices. Stop it! They stop being matrices as soon as you start thinking of them as a vector space, and then they're a 4 dimensional vector space. Imagine unfolding a matrix, like this:
(a b) ___> (a b c d)
(c d)
You can pick *any* 4 independent vectors for the basis, but the usual (1000), (0100), (0010) and (0001) are pretty good ones, as they're trivially independent, by inspection. If you run that map above backwards, you'll find them corresponding to the basis matrices given. Now, you're given the action of the adjoint representation in the original matrix view of things; construct the actual adjoint 4x4 representation by inspection on what the basis do to each other.
Sep18-07, 03:13 AM   #12
Recognitions:
Even more explicitly, what is [e_1,e_i] for i=1..4? Now you know what ad(e_1) does to the 4 basis vectors, so you can write down the matrix for ad(e_1). It would help if you remembere to think of ad(e_1) as an endomorphism of a 4-d space.
Sep18-07, 05:59 AM   #13
many thanks again, got it now
by the way, I just learnt here about structure constants, why has no one brought them up yet?
Sep18-07, 06:40 AM   #14
Recognitions:
Quote by Ratzinger View Post
.... structure constants, why has no one brought them up yet?
Because they are unnecessary for the discussion.
Sep18-07, 07:15 AM   #15
Why are they unnecessary? Don't they give you the matrix of adjoint representation once you have a basis?
I just found out I'm not alone being confused. Not long ago there was this thread on PF.
Especially here, that's exactly my problem (post 16)!!!
My problem I think arises because I am trying to translate what you are saying to an explicit representation in terms of matrices (I don't know when to correctly use the word "representation" anymore) . I do see what you are saying: there is a vector space which we take as being the Lie algebra itself. A rep is a map from L x V to V. Since [x,y] does send an element of V to V, we can take this as being a possible rep, and it's called the adjoint rep.
This makes complete sense to me as long as I leave it formal.
Now, my problem is if I try to translate this to the language of explicit matrices. They say that one must use the structure constants to build the explicit adjoint representation. These wil represent the map LxV -> V.
For sl_2(C) you gave for example [eh]=2e and so on.
All I am saying is that to me it seems that the explicit adjoint representation of that algebra will be 3x3 matrices. And now, to reproduce the different commutation relations of the group, we will have to represent
the elements e,f, h by the column vectors (1,0,0), (0,1,0), (0,0,1).
Then the map (x,y) = [x,y] wil be reproduced in that explicit representation by simply multiplying the 3x3 matrix representing x by the column vector associated to the element y.
and what Matt Grime writes in post 18 drives it home for me!
Let's do it (and I'll get it right this time - never do commutator relations in your head)
[he]=2e
[hf]=-2f
[hh]=0
So ad(h) sends e to 2e, f to -2f and h to 0, so appealling to our first linear algebra course, the matrix of ad(h) is just diag(2,-2,0) in this representation (ordering the basis as e,f,h).
Got it! Finally!
(concrete examples is how most people learn, I'm no exception here...wish that view would be shared by at least one author of those trillion books on lie groups and lie algebras out there...)
Sep18-07, 08:20 AM   #16
Recognitions:
How did you propose to get the structure constants? 'Structure constants' is just a fancy name for what you have to write down. Giving them a fancy name doesn't alter what you had to do in the slightest. I didn't mean that concept of structure constants is unimportant, but that there was absolutely no need to mention them, i.e. to give a name to what you were doing already.
Sep18-07, 08:27 AM   #17
It's the old issue that people over-rely on basis representations. The fact is that mathematicians don't choose to work in the abstract just because they're masochistic and weird -- there are genuine advantages. It's worthwhile spending time to try and free yourself from the need to have a basis, and therefore able to put numbers to things, and just work with the abstract concepts. After all, adjoint representations aren't even that high up on the hierarchy of increasingly abstract things, and as the abstraction climbs, it may get to a point where a basis is no longer even possible (i.e. you're not in a vector space any more)
Thread Closed
Thread Tools
Similar Threads for: adjoint representation
Thread Forum Replies
adjoint representation/lie algebra question General Math 21
Adjoint representation High Energy, Nuclear, Particle Physics 0
Proving that the Composition of Two Self-Adjoint Operators is Self-Adjoint Calculus & Beyond Homework 2
How does a scalar transform under adjoint representation of SU(3)? High Energy, Nuclear, Particle Physics 2
adjoint representation Differential Geometry 1
