Resistance of each IDENTICAL resistor?
The discussion revolves around a circuit containing five identical resistors connected to a 50 V battery that delivers 46 W of power. Participants are attempting to determine the resistance of each resistor.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss using the power formula P = IV and Ohm's law to find current and resistance. There is an exploration of the equivalent resistance of the circuit, noting the series and parallel configurations of the resistors.
Some participants have provided guidance on calculating the equivalent resistance by considering the series and parallel arrangements of the resistors. There is acknowledgment of the complexity in determining the total resistance and the need to express it in terms of the individual resistor value.
Participants mention the challenge of working through the problem late at night and the constraints of homework rules that may limit the information they can use. There is also a reference to the need for careful handling of fractions in parallel resistance calculations.
itsagulati
The circuit in the drawing contains five identical resistors. The V = 50 V battery delivers 46 W of power to the circuit. (Picture should show up somewhere)
Q: what is the resistance in each resistor
so far the only things i have thought of is P = IV...which gives me I...and I = V/R
I use the above equations to get to a Total resistance of 54.3 ohms...
i thought of several different ways to go about it from there and none of them have worked. dividing by 5 not going to work...
tried multiplying by 4 and dividing by 5 (5 total resistors, but when we add them in parallel we only have 4 being added into the total since two are in series).
anyways...basically i am lost...i've gotten through all 17 problems on the homework and cannot really think this one through...its 3:30 a.m...any help would be GREATLY appreciated!
Thanks!
P = IV so use I = P/V to get I.
Then one has to find the resistances using V = IR.
So all resistors have same resistance R, but the total resistance is not 5R or 4R.
So one has to find the equivalent resistor noting that R3 and R4 are in series, so the combined resistance is 2R.
Then that 2R is parallel (||) with R2 and R5. So find the equivalent resistance of that combination.
Then that combination is in series with R1, so the total resistance is R1 + Req(R2 + R3||R4 + R5), with each resistance being the same R.
First determine the equivalent resistance of the circuit. R3 and R4 are in series. Hence they add up to (R3 + R4) = 2R (where R is the value of each resistance in ohm). This 2R, R2 and R5 are in parallel. Determine their equivalent value using the relevant formula. Then this equivalent resistance is in series with R1. Add them up to get the equivalent resistance of the circuit (Reqv). Reqv will be in terms of R.
Power consumed = V^2/Reqv . As V is given, Power is given and Reqv is in terms of R, solve to get value of R.
Thanks!
Ok got it...took a moment to figure out the addition of the fractions in parallel...but sure enough it worked :)
I think the V^2 / R = P was the part that cracked it for me. P = IV wasn't seeming to swing it for me :)
In case anyone else needs it and for someone else to double check that I didn't do this wrong some how:
i did 1/r + 1/2r + 1/r = 5/2r ohms^-1 = 2R/5 ohms + R = 7R / 5
50^2 *5 / 46 = 7R
R = 38.82 Ohms
Thanks again to both of you!
  • · Replies 31 ·
  • · Replies 60 ·
11K
