Does Aristotle's Theory of Falling Objects Hold Up Against Galileo's Experiment?
The discussion centers on the comparison between Aristotle's theory of falling objects and Galileo's experiments. Participants argue that according to Aristotle, a heavier object (M) should fall faster than a lighter one (m), while Galileo demonstrated that all objects fall at the same rate regardless of mass when air resistance is negligible. The conversation also explores the mechanics of tension in cords, explaining that a sudden jerk on cord D results in its breakage due to high acceleration, while a steady pull on cord C leads to its failure due to the combined gravitational force and applied force.
  • Understanding of classical mechanics principles
  • Familiarity with Aristotle's and Galileo's theories on motion
  • Basic knowledge of forces and tension in physics
  • Concept of acceleration and its effects on objects
  • Study the principles of free fall and gravitational acceleration
  • Explore the concept of tension in strings and cables in physics
  • Investigate the historical context of Aristotle's and Galileo's contributions to physics
  • Learn about the effects of air resistance on falling objects
Students of physics, educators teaching classical mechanics, and anyone interested in the historical development of scientific theories regarding motion and gravity.
Destrio
Correct me if my thinking is wrong:
Q: If m is a light stone and M is a heavy one, according to Aristotle M should fall faster than m. Galileo attempted to show that Aristotle's belief was logically inconsistent by the following aruement. tie m and M together to form a double stone. Then, in falling, m should retard M, because it tends to fall more slowly than M; but according to Aristotle the double body is heavier than M and hence should fall faster than M.
A: I believe Galileo's reasoning to be incorrect because there is no upward pull in the dropping of the stone, just the force of gravity pulling them to Earth as a constant rate (ignoring air resistance), the rocks m, M, and m+M, should fall all at the same rate.
Q: A block with mass m is supported by cord C from the veiling, and a similar cord D is attached to the bottom of the block. Explain this: if you give a sudden jerk to D, it will break, but if you pull on C steadily, C will break.
A: If you give a sudden jerk, there is high acceleration, and the force applied is greater than the tension force, causing D to break. If you pull on D steadily, that is to say, with arbitrarily low acceleration, the force from the block due to gravity in addition to the applied force will cause cord C to break.
Any comments/critique is much appreciated. Thanks
Galileo was arguing against Aristotle's argument by taking it to its logical conclusion. You seem to be agreeing with Galileo's conclusion that all rocks fall at the same rate.
Not bad. A sudden jerk would require a large force to accelerate the mass, but such force exceeds the breaking strength of the lower string.
  • · Replies 18 ·
  • · Replies 19 ·
14K
