What is the Principle of Transmissibility in Applied Mechanics?
  • Thread starter DaNiEl!
  • Tags
    Principle
In summary, the principle of transmissibility states that a force applied to a rigid body will have the same effect if applied anywhere along its line of action. This is a common understanding that is not explicitly stated in the text. However, it is intuitively clear once explained.
DaNiEl!
23
Hello. Sorry if it is a bother, but I'm starting Applied Mechanics (statics) and my books states this "principle of transmissibility" with no proof (except for the one given in the dynamics volume which i don't have). could anyone provide me an explanation or point me in the direction of a website which explains where this comes from? my main problem with it is that, if you slide a force vector along a line which doesn't intersect the center of mass, you should get a different angular momentum...
i probably didn't understand it. either way, it would be useful to see the proof.
thank you in advance.
A force applied to a rigid body will have the same effect if applied anywhere along its line of action. That's a statement of the principle of transmissibility.
Note that sliding a force along its line of action does not affect the torque it creates. (You move it along its own line of action, not sideways.)
oh, i see. the explanation should lie in the fact that the arm length and the projection of the force on a perpendicular to r vary in the same proportion so the torque is always the same. it's good to see it intuitively, though a proof would be better (to confirm this hypothesys).
another thing which i have trouble with when i visualize it is that if a force perpendicular to r has no translational component, when u slide it along the line of action it should have some, or am i seeing it wrong?
Realize that the lever arm doesn't change as the force slides along its line of action. Equivalently, [itex]\vec{r}\times\vec{F} = Fr\sin\theta[/itex] is constant.
If I understand what your saying, what counts is [itex]r\sin\theta[/itex], which remains constant.
let's say you have a body at the origin and a force (1,0) applied at the point (0,1) (r=(0,1)). the external product is not null, but the internal product is. now if the same force is applied at the point (1,1)(r=(1,1)), the external product of the force with r (fxr) is still 1, but the internal product is not null this time. i need to know what i am doing wrong so i can understand this principle, because it seems to be used a lot throughout the book.
thanks in advance.
You're not doing anything wrong. What counts in determining the effect of a force on a rigid body is the external (or cross) product, which gives you the torque it produces. The internal product has no particular significance.
the reason i referred the internal product is that, "apart" from a multiplication of a constant (the inverse of the distance (||r||)), it should give the component of the force parallel to r. if i understood the principle of transmissibility, a force should have the same effect if placed on any point of it's line of action. unless i miss-understood this, the principle should account for the torque and the translational force. what you are telling me is that the principle refers only to the torque?
I assume that by "translational force" you mean the translational effect of the force (as opposed to the rotational effect, which is captured by the torque). That will certainly not change by just sliding the force, as long as you don't change its direction.
Realize that as the forces slides, the direction of [itex]\vec{r}[/itex] changes, so the component of the force along that direction will surely change. But that doesn't mean anything.
I don't understand what you are saying. you mean, the force component changes but the effect doesn't? this is too puzzling for me. i don't understand how the translational component change yet this having no importance. doesn't that change the movement of the body?
Imagine a fixed set of coordinate axes. As long as you just slide a force vector parallel to its line of action, its orientation with respect to those fixed coordinates does not change.
You are treating [itex]\vec{r}[/itex], the position vector describing the location of the point of application of the force with respect to the origin, as if it were a fixed direction in space. It's not!
Take the example you gave in post #5. You have a force (1,0) applied at point (0,1). The force points in the +x direction. Now if you apply the same force at point (1,1), it still points in the +x direction! No change in its translational components. (Beyond that, the torque it produces doesn't change--that's what the principle of transmissibility says.)
IMHO, "transmissibility" is a hilariously overblown term used only by engineers. (Just teasing! :wink:)
then, my missunderstanding seems to be at the basic level of forces and torque. what you are telling me is that when, as in my example, a force (1,0) acts on the point (0,1), it not only produces a rotation (torque=(-1) x 1 N.m) but a translation according to a force of 1N in the x direction?
That's correct. The rotational effect of a force depends on the torque it produces about some reference point, while the translational effect is always just parallel to the direction of the force (no matter where the force is applied.)
i was just reading about reducing a force to a binary-force system and this made sense. i always thought it was only the component parallel to the line from the center of mass to the force that counted but i guess i was wrong. makes me wonder if it has energy implications.
thanks for the help!
1. What is the "Principle of Transmissibility" in physics?
The "Principle of Transmissibility" is a fundamental concept in physics that states that the effects of a force on a body remain unchanged regardless of where the force is applied along its line of action. In other words, the point of application of a force does not affect its effect on the motion or equilibrium of a body.
2. How does the "Principle of Transmissibility" apply to forces acting on an object?
The "Principle of Transmissibility" applies to all types of forces, including contact forces and non-contact forces. It states that the effect of a force on an object is the same regardless of where the force is applied on the object.
3. Can the "Principle of Transmissibility" be applied to multiple forces acting on an object?
Yes, the "Principle of Transmissibility" can be applied to multiple forces acting on an object. This means that the combined effect of all the forces acting on an object can be determined by considering each force individually and applying the principle to each one.
4. Is the "Principle of Transmissibility" applicable to both static and dynamic situations?
Yes, the "Principle of Transmissibility" is applicable to both static and dynamic situations. It is a fundamental law of physics that holds true in all situations where forces are involved, whether the object is at rest or in motion.
5. What are some real-life applications of the "Principle of Transmissibility"?
The "Principle of Transmissibility" is commonly used in engineering and design, such as in the construction of bridges and buildings. It is also used in sports, such as in the design of golf clubs and tennis rackets, to ensure that the force applied by the player is transmitted effectively to the ball. Additionally, it is used in the analysis of mechanical systems and structures to determine the effects of different forces on their motion and stability.
  • Classical Physics
  • Classical Physics
  • Classical Physics
  • Classical Physics
  • Quantum Interpretations and Foundations
  • Classical Physics
