Can anyone help me with ny of these 4 genetics questions?
  • Biology
  • Thread starter stew
  • Tags
    Genetics
In summary, the conversation discusses different genetic traits and their expected phenotypic frequencies in offspring. In the first scenario, where mahogany-eyed and ebony-bodied Drosophila are mated, the expected phenotypes in 1000 offspring would be approximately 375 mahogany-eyed, 375 ebony-bodied, and 250 wild type females. Moving on to the second scenario, where loci A and B are sex-linked and 20 map units apart, the expected phenotypic frequencies in offspring resulting from different crosses are as follows:(a) AaBb(cis)female X ab/Y male - 25% A-B-, 25% A-b, 25% a-B-, 25% a-b(b
stew
1. The genes for mohogany eyes and ebony body are approximately 25 map units apart on chromosome III in Drosophila. Assume that a mahogany-eyed female was mated to an ebony-bodied male and the resulting F1 phenotypically wild type females were mated to mahogany, ebony males. Of 1000 offspring, what would be the expected phenotypes and in what numbers would they be expected?
2. Given that loci A and B in Drosophila are sex-linked and 20 map units apart, what phenotypic frequencies would you expect in male and female offspring resulting from the following crosses? (Assume A and B are dominant to a and b, respectively):
(b) AaBb(trans) X ab/Y male
(c) aabb female X AB/Y male
3. Assume that there are 12 map units between two loci in the mouse and that you are able to microscopically observe meiotic chromosomes in this organism. If you examined 200 primary oocytes, in how many would you expect to see a chiasma between the two loci mentioned above?
I got 2 for an answer. Is that correct?
4. Phenotypically wild F1 female Drosophila, whose mothers had light eyes(Lt) and fathers had straw(stw) bristles produced the following offspring when crossed to homozygous light-straw males:
phenotype: number:
light-straw 22
wild 18
light 990
straw 970
total: 2000
Compute the map distance between light and straw loci.
I got 1.1 mu for an answer. Is that correct?
Thanks in advance for any help.
Keep in mind our rules require you to show your own efforts first. Tell us how you got the answers you got.
I am happy to assist you with your genetics questions. However, it is important to note that I am unable to provide direct answers to specific homework or exam questions. Instead, I can provide you with guidance and explanations to help you understand the concepts and solve the problems on your own.
1. To answer this question, we need to use the principles of Mendelian genetics and the concept of recombination. In this scenario, the genes for mahogany eyes and ebony body are located on the same chromosome, but are 25 map units apart. This means that during meiosis, there is a 25% chance that these genes will be separated and end up in different gametes. This is known as recombination.
In the first cross, a mahogany-eyed female is mated with an ebony-bodied male. This will result in F1 offspring that are all wild type because both parents are heterozygous for the two traits. When these F1 females are mated to mahogany, ebony males, the expected phenotypes and numbers are as follows:
- Mahogany-eyed, ebony-bodied: 25% (recombination frequency of 25%)
- Mahogany-eyed, wild type: 25% (recombination frequency of 25%)
- Wild type, ebony-bodied: 25% (recombination frequency of 25%)
- Wild type, wild type: 25% (no recombination)
Therefore, out of 1000 offspring, we would expect to see approximately 250 mahogany-eyed, ebony-bodied flies, 250 mahogany-eyed, wild type flies, 250 wild type, ebony-bodied flies, and 250 wild type, wild type flies.
2. In this question, we are dealing with sex-linked genes, which are located on the sex chromosomes (X and Y). In Drosophila, the sex chromosomes are denoted as X and Y, with X being larger and carrying more genes. In this scenario, loci A and B are located on the X chromosome and are 20 map units apart.
In this cross, the female is heterozygous for both traits (AaBb) and the male is recessive for both traits (ab). Since the genes are located on the same chromosome, there will be no recombination. Therefore, the expected phenotypic frequencies in the offspring will be:
Question 1: What is genetics?
Genetics is the study of genes, heredity, and genetic variation in all living organisms. It is a branch of biology that focuses on how traits are inherited and passed down from one generation to the next.
Question 2: What are the four basic concepts of genetics?
The four basic concepts of genetics are:
- Genes are the basic unit of heredity
- Inheritance of traits follows specific patterns
- Genes can undergo mutations, leading to genetic variation
- Changes in the environment can affect gene expression and influence traits
Question 3: How are genes inherited?
Genes are inherited from our parents, with each parent contributing one copy of each gene. The combination of genes from both parents determines our genetic makeup and the traits we possess.
Question 4: What is a dominant gene?
A dominant gene is a gene that is expressed over another gene in the same location, or allele. This means that if an individual has one copy of a dominant gene and one copy of a recessive gene for a particular trait, the dominant gene will be expressed in their physical appearance or phenotype.
Question 5: How do mutations occur in genes?
Mutations can occur spontaneously during cell division or as a result of exposure to environmental factors such as radiation or chemicals. They can also be inherited from parents who carry a mutated gene. Mutations can result in genetic disorders or contribute to genetic variation within a population.
14K
  • Biology and Medical
